Old Apr 03, 2010, 04:25 PM
Put a Quark in it!
nexgen's Avatar
USA, MN, Brainerd
Joined Feb 2008
man I want one of these. anyone wanna buy some blood, or an arm or leg?
nexgen is offline Find More Posts by nexgen
Old Apr 04, 2010, 07:24 PM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Watch the Skookum site for the revised manual.
I've been tweaking the piro settings. Almost perfect in both directions. I drove about 5 hours today home from Tennessee, and my fried brain was too far gone to try much else.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Apr 08, 2010, 12:00 PM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Sunday
Monday is still the scheduled release date for the SK720. If you had an early order, your unit should be on the way by Monday.
Sunday, I will start to post what I learned about setup.
Screen shots, etc. The manual is being re-written and the software has been updated several times. I don't want to post incorrect information.
Rick
Old Apr 08, 2010, 04:25 PM
Joined Oct 2000
Do I understand the self leveling right in that if i get in trouble, I center the stick, and the heli goes horizontal level?
second: is the collective tied into the self leveling feature.
Third: if you turn up the self leveling gain, what does this do for a novice flying? in other words, can you feel the heli trying to fly more horizontal as to cruize around?
Kenneth is offline Find More Posts by Kenneth
Old Apr 09, 2010, 08:48 AM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Kenneth,
So many questions!
I'm going to answer your questions, but your questions tell me that there is quite a bit that you don't understand. In this discussion, I am assuming that you elected to make all of your gain stettings through the PC software.
Let's assume you have a DX7 Tx. You can program the Gear and AUX2 switches to toggle allternative memory/settings banks in the SK 720. I am used to using the Gear switch for my legacy tail gyro to toggle from HH mode to Rate mode, so I set up my 720 to work the same way. My Gear switch toggles between Tail 1 bank and Tail 2 bank. Tail 2 settings make the tail gyro part of the 720 act in a Rate mode.
My AUX2 switch toggles the banks Cyclic 1 and Cyclic 2. In Cyclic 2, I set the autolevel function (80%). When the rate settings in Cyclic 1 and Cyclic 2 are exactly the same (this is important), I can toggle to the self-leveling/bailout function by switching AUX 2.
In the autolevel mode, the heli acts much like a co-axial. When you center the sticks, the heli returns to a horizontal position. You can fly the heli in this mode, and you can reduce the amount of autolevel gain to meet your preference.
If you are learning to fly, you might want autolevel at 90 to 100%. As you gain skills and confidence, you can reduce that gain gradually until the heli acts like a normal, CP machine.
Now, your specific questions: (I'm sorry this post is so long):
(1) Only if you have the autolevel function set. You can toggle this on and off as you desire.
(2) No. Autolevel is cyclic only (at this time).
(3) No, this does not act like a Blade CX3 where the huge flybar tends to bring the heli back to horizontal despite your best efforts. The heli will move as long as the stick is not centered. The movement stops when the stick comes back to neutral. The main difference is that with a standard CP heli, the heli retains its orientation until you bring it back with the Tx.
I hope I've answered your questions.
Rick
Old Apr 09, 2010, 02:41 PM
Joined Oct 2000
Gotcha thanks for taking the time to write. I have also been following the helifreak threads, but still was trying to understand it in my newbie pilot brain.
Old Apr 09, 2010, 08:44 PM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Manual Posted
Here it is:
http://www.skookumrobotics.com/products/sk720.html
Rick
Old Apr 09, 2010, 11:27 PM
mad heli scientist
Gadget01's Avatar
United States, OK, Oklahoma City
Joined Dec 2005
So the 1st production run is sold out, right? Do you have any timing info for the next run?
Gadget01 is offline Find More Posts by Gadget01
Old Apr 10, 2010, 01:11 AM
Danger! Danger!
FrankW's Avatar
Portland Intl, Oregon, United States
Joined Dec 2002
Will this be able to be plugged into the new Futaba S. Bus receivers?
FrankW is offline Find More Posts by FrankW
Old Apr 10, 2010, 05:38 AM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
HeliDirect says their second batch is also sold out. They are saying May 15.
I don't know about other vendors.
Rick
Old Apr 10, 2010, 05:39 AM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
I have no idea.
As the Futaba product was not available to us for testing, there is no way to know.
Rick
Old Apr 10, 2010, 06:46 PM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Software Install
OK, you'be been dreaming about the day when your SK 720 is FINALLY delivered. Can't wait to get it in the heli?
Wait. Please.
Check the package. Everything should be there.
Take the SK 720 unit and attach it to your PC using the USB cable. The USB cable will provide the power to the 720. Do not connect an external power supply at this time.
The 720 will look like a USB drive to your PC. If you see a warning about "scan and fix SK720", don't do it.
Run the setup program from your 720 memory.
Do NOT OPEN the case. You will lose the calibration and invalidate any warranty. Really. Don't do it. Thanks.
Old Apr 10, 2010, 06:51 PM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Step 2 - Servos
BEFORE you mount your 720, and BEFORE you connect your servos, tell the 720 what kind of servos you have. Both swash and tail.
Tell the setup software if the servo is digital or analog, and enter the speed.
You will select your tail servo from a dropdown menu.
Click on Send Setup.
Old Apr 10, 2010, 07:21 PM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Set Up Your Tx
Everything about this discussion assumes you have a DX7.
Set up a model in the Tx for your heli
Swash type: 1 Servo/Norm
All servos normal movement (do not reverse anything)
All Travel Adjust 100% for now.
All Subtrims 0
No expo
Set your throttle curve and pitch curve as desired.
Old Apr 10, 2010, 07:29 PM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Bind to the Tx
If you are flying a 450 or larger, you should use two satellite receivers.
http://www.spektrumrc.com/FAQ/tm.aspx?m=133
Attach the satellites to the 720.
From the Utility option on the top menu, select Bind Sat Rx's on Power Cycle.
Disconnect the 720 from your computer. When you power on, you will bind just like you were using a blind plug. Press the bind /range test button on the back when you power up. When the sat lights stay lit, the unit is bound to your Tx.
Note: the text at the top left is the name of the saved file containing the setup for this heli. Click on Send Setup or Press F1.
For Sale CSM SL 720 gyro $150 Shipped Giovanni Day Aircraft - Electric - Helis (FS/W) 1 Jul 02, 2011 07:18 PM
Discussion Skookum 720 Rickn816 Electric Plane Talk 2 Feb 07, 2010 09:01 AM
Sold NIB Extremeflight Torque 2812/720 RichR Aircraft - Electric - Power Systems (FS/W) 2 Jan 15, 2010 09:36 AM
Sold NIB Torque 2812/720 RichR Aircraft - Electric - Power Systems (FS/W) 0 Jan 13, 2010 12:00 PM
Sold Torque 2812/720 Brushless motor RichR Aircraft - Electric - Power Systems (FS/W) 2 Aug 27, 2009 09:19 PM
