Mar 22, 2013, 09:30 AM
Lawrenceville, GA
Joined Nov 2007
Originally Posted by Luvmyhelis
Hey Rick, have you tried to push it below the deck yet with any authority? Just curious to see how far down it penetrated before it caught itself and moved back up? Plus have you flown it hard enough yet to where we usually see the Sk720 get scrambled slightly and begin SL drift? How does that effect things with the Gps system in place? If at all?
Not yet. I've been focused on Go Home. But, I've seen videos of those who have. It works.
The drift in my case was not a function of the GPS, but of the accelerometers in the Gyro. I reset the accels with the heli tilted slighty toward the tail rotor. Trial and error. I also carefully checked my C/G. After those two fixes, the heli no longer drifts.
The drift is less pronounced when you use a position hold where the GPS is active. In alt hold, there is some drift, but the heli is "supposed" to be moving in this mode, so drift should be irrelevant.
Rick
