Old May 19, 2003, 08:57 PM
Manchild is offline
Find More Posts by Manchild
Manchild's Avatar
Seattle, Washington
Joined Sep 2002
HeliHobby "high authority" tail motor pinion for Hummingbird
I don't get it...I ordered the "high authority" tail motor pinion for the IPS 7.2 volt motor which should have come with a 1.3 mm bore but it doesn't fit the motor. Anyone else have this problem? Did helihobby send me the wrong one or is there a secret to mounting the pinion?
Manchild is offline Find More Posts by Manchild
Old May 19, 2003, 11:12 PM
WeatherB is offline
Find More Posts by WeatherB
Logo Power!
Toronto, Canada
Joined Dec 2002
Hey,
The hole on the pinion is too small correct? The shaft on the IPS is 1.5mm... You can get the correct pinion from:
www.precisionmodelproducts.com/
WeatherB is offline Find More Posts by WeatherB
Old May 19, 2003, 11:22 PM
Manchild is offline
Manchild's Avatar
Seattle, Washington
Joined Sep 2002
Interesting...then I wonder why did Helihobby send me a 1.3 mm bore pinion for a 1.5 mm shaft motor? .... or is the "high authority" motor NOT and IPS motor and has a smaller bore than the IPS or EDF-50?
Old May 19, 2003, 11:34 PM
WeatherB is offline
Logo Power!
Toronto, Canada
Joined Dec 2002
Hey,
I wasn't able to get a clear answer either... All I know is that the stock Piccolo Pro and IPS motors are 1.5mm...
Old May 20, 2003, 06:34 PM
tomer is offline
Find More Posts by tomer
Joined Aug 2002
Let Sean now at info@helihobby.com he will take care of you for sure ...
tomer is offline Find More Posts by tomer
Old May 20, 2003, 06:56 PM
born2net is offline
Find More Posts by born2net
Joined Jan 2002
Hello again,
e-mail me so I can take care of you ... info@helihobby.com
Regards,
Sean - HeliHobby.com
born2net is offline Find More Posts by born2net
Old May 20, 2003, 11:33 PM
Manchild is offline
Manchild's Avatar
Seattle, Washington
Joined Sep 2002
Thanks all. I talked to someone at helihobby today and he said he'll send me new pinions. I'm not sure if it was Sean. I like the way they take care of you without much hassle. Thanks to Heli Hobby for not abandoning your customers (believe me, some do).
Old May 21, 2003, 04:41 PM
WeatherB is offline
Logo Power!
Toronto, Canada
Joined Dec 2002
Hey,
Did helihobby give you a refund or are they sending you the correct pinion? I am looking for a 10T 1.5mm pinion too...
I sent Precision Products an email four days ago and they still haven't replied. Any ideas where I can find the correct one?
Old May 21, 2003, 05:52 PM
born2net is offline
Joined Jan 2002
Yes, it was me and Thank you for your business,
The Part# is HH365 ...
LOTS MORE COOL stuff coming soon ...
Thank you for all the help guys,
Old May 21, 2003, 06:46 PM
WeatherB is offline
Logo Power!
Toronto, Canada
Joined Dec 2002
Hey Sean,
YGM...
Old May 21, 2003, 10:08 PM
KsFlyer is offline
Find More Posts by KsFlyer
AV8
KsFlyer's Avatar
Kansas
Joined Jul 2002
I'm new to this thread, but I carry all the different GWS motor setups as well as pinions. Is the pinion that is being used on this heli one that is a stock size?? I mean the same pinion used in IPS motor setups? If so, let me know what you need. I carry all stock GWS Pinion sizes.
www.av8hobbies.com
KsFlyer
KsFlyer is offline Find More Posts by KsFlyer
Old May 21, 2003, 10:10 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
What is this "High Authority" What does it do or do better??
kushal_22 is offline Find More Posts by kushal_22
Old May 21, 2003, 10:20 PM
WeatherB is offline
Logo Power!
Toronto, Canada
Joined Dec 2002
KsFlyer,
Steve said the pinion that is included with the IPS motor will not work on the piccolo (I guess the tail gear is a different pitch).
Hardeckflier,
The high authority motor is that really long motor...
Old May 21, 2003, 11:00 PM
Manchild is offline
Manchild's Avatar
Seattle, Washington
Joined Sep 2002
The high authority motor will give you more tail authority. Right now I am flying separates with HH gyro and the stock tail motor. Even with the HH gyro, sometimes the heli will spin if you throttle up really fast. With a high authority motor (IPS I think) or the EDF-50 motor, you should be able to punch the throttle with the tail steady. You can purchase the high authority motor and pinion at www.helihobby.com
The high authority pinion is none of the stock IPS pinions. I think the pitch might be different but not sure.
Old Jun 28, 2003, 12:07 PM
50feet is offline
Find More Posts by 50feet
50feet's Avatar
DELAWARE
Joined Mar 2003
I got the pinion from Helihobby but it does not fit. its to long and it does not fit snug. It slides right off. I put CA on it but it come loose .
50feet is offline Find More Posts by 50feet
High Authority tail motor for the Piccolo? Mindchatter Micro Helis 2 Feb 07, 2005 11:43 PM
High Authority Tail Motor For Hummingbird Tommy632 Micro Helis 9 Dec 19, 2004 07:40 PM
High authority tail motor pinion? turbojoe Micro Helis 0 Feb 07, 2004 04:45 PM
High authority tail motor... Steve McBride Micro Helis 1 Sep 05, 2003 10:09 AM
High authority tail motor capacitors Jimbo Micro Helis 1 Jun 26, 2003 08:46 PM
