Old Feb 06, 2010, 10:55 PM
mcauburn is offline
Find More Posts by mcauburn
Joined Dec 2007
Hypersonic Fly Setup...
Try the following setup and you will be amazed. I call it my Hypersonici Fly
Power Plant: 2409-12T Outrunner from Headsuprc (anchor very well)
ESC: 30 amp with burst to 40 amp
Battery: 1800/25C 3S Lipo
Servos: T-Pro MG90 9G Metal Gear Digital Servo from HobbyPartz.com (must have for additional torque at high speed)
Add stiffners to control linkages or add a control rod guide.
Elevon differential at 35%
Make sure CG is 9-9.25" from nose tip
Prop: GWS HD8060 from max thrust or APC 7x7 for speed.
Hang on to your hats kids, this will be a fantastic ride. I plan to conduct a couple of high speed runs through our timing gate once the weather clears. I'm expect 100+ on high speed dives. BTW the climb out rate is unreal with the 8x6 setup.
mcauburn is offline Find More Posts by mcauburn
Old Feb 07, 2010, 01:14 AM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
I fly my stock gear hyperflea on 3s and its crazy. Your setup should be off the wall nuts.
Hance is offline Find More Posts by Hance
Old Feb 07, 2010, 03:43 PM
mcauburn is offline
Joined Dec 2007
Hance, I did the same for a couple of months, but had the need for more speed.
Old Feb 08, 2010, 05:27 PM
mcauburn is offline
Joined Dec 2007
Speed Resutls In...
Will, not exactly what I was hoping for.
10 Passes between 100ft gate (flat run):
1.12 60.88
1.32 51.65
1.28 53.27
1.19 57.30
1.26 54.11
1.30 52.45
1.13 60.34
1.21 56.35
1.22 55.89
1.26 54.11
avg speed: 55.63
Tomorrow I'll try the APC 7x7 prop. Should gain a little more speed.
Old Feb 08, 2010, 09:37 PM
Jimmi is offline
Find More Posts by Jimmi
Jimmi's Avatar
Los Angeles Area
Joined Dec 2005
I was thinking 100 mph that wing would do some serious fluttering and probably start bending and falling apart
I bet at 55 mph it feels like its doing 100 mph I also own a hyperflea and I'm going with 2 cell lipos and its fast enough for me. It will fly straight up and rolls great. Mine does about 35 mph or 40 and believe me I was thinking of putting a bigger battery but to much weight for what I have on hand. Now if I had a lighter 3 cell laying around then I would go for it. But the lightest I have is a 1300 mah thunder power 3 cell and its too heavy.
Jimmi is offline Find More Posts by Jimmi
Old Feb 08, 2010, 11:01 PM
Hance is offline
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
I run a 3s 1300 on mine it handles it remarkably well. It doesn't throw the cg nearly as much as you think it would.
Old Feb 12, 2010, 01:08 AM
mcauburn is offline
Joined Dec 2007
Add a string/CA stiffner to the wing. Does wonders for making the wing ridged at high speeds.
Old Apr 28, 2010, 02:55 PM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
do you have a pic of this mod??
thanks
and what are AUW of these fleas and how heavy are the 1300 3 s packs you are using... what brand? thanks
also..any video of you bird screaming??
grfcon is offline Find More Posts by grfcon
For Sale T-rex 450 xl, great condition, add rx,tx to fly. Well setup , $175 only final price missil3 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2010 03:57 PM
For Sale T-rex 450 xl, great condition, add rx,tx to fly. Well setup , final price missil3 Aircraft - Electric - Helis (FS/W) 4 Jan 20, 2010 03:40 PM
Discussion V-Max Hypersonic awundrin Mini Helis 0 Jan 11, 2010 02:26 PM
For Sale Next-D Rave 450 4S setup Bind and Fly creighton1 Aircraft - Electric - Helis (FS/W) 1 Nov 02, 2009 01:09 PM
Sold Smart Fly EQ6 complete setup(reduced09/06/09) John.G Aircraft - General - Radio Equipment (FS/W) 2 Sep 06, 2009 08:52 AM
