Hampshire, UK
Joined Jun 2002
http://www.rcgroups.com/forums/searc...by=&sortorder= -- Dave |
Thanks that info Sal.
I popped over to the foamies section and found quite a few threads. Guess I was looking in the wrong place. I wanted a regular fuse too with the added durability of epp. The Cobra was the answer for me. I did see the the Tantrum video and that is one nice plane too. -Victor |
Rochester, NY, USA
Joined Aug 2000
![]() Quote:
I have made one mod. since my review to both the Eagle and the Cobra. I added some tiny carbon rods across the stabilizers in the tail. You could also use some carbon fishing line (called Fireline) to do this modification. This helps the tail maintain stability in harder maneuvers and higher winds. The plane just flies better! If you break the stock gearbox, try the metal pinion gear replacement or go to the enclosed MP Jet gearbox using the same stock motor. Mine is still working great with the MP Jet gearbox. Good luck! |
| Thread Tools | |
| How do you like your GWS aiplanes | eflyer1234 | Foamies (Kits) | 18 | Jun 11, 2004 05:38 AM |
| Thunder power POWER , how do you like your batteries ? | misskimo | Batteries and Chargers | 11 | Jun 29, 2003 05:37 AM |
| How do you like your zagi? | Ronbo | Foamies (Kits) | 35 | Jul 20, 2001 04:34 PM |
| How do you like your Lite Stick? is it worth getting? | mrebman | Parkflyers | 23 | Jun 21, 2001 04:55 PM |
