Old Feb 06, 2010, 04:22 PM
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Airbender: 19g, 18 inch Aerobat
Here's my latest plane, the Airbender. Wing span is 18 inches, weight is 19g, and wing loading is 0.95 oz/sq.ft -- slightly less than a Vapor's 1.0 oz/sq.ft.
Equipment is the Leichty 900mhz servo receiver with Martin Newell's fantastic HipHop spread spectrum software code. Servos are three of the Leichty/Zigras 0.70g ultra light servos. Propulsion is a Gasparin G10 Micro 2.4g brushless motor and Micro Invent MBC-1 0.6g controller. Battery is Full River 90mAh. Since covering is clear, the color comes from a dusting of paint on the skeleton. The top side is red and the underside is yellow to aid in keeping track of the plane's orientation when in flight.
The name Airbender comes from a favorite show of my boys, "Avatar, the last Airbender".
The Airbender has not flown yet. First flight will be Feb 21. I'll try and get video and pics and post.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Feb 06, 2010, 04:23 PM
Boston, Mass
Joined May 2001
Here are some close up detail pictures and some of the equipment. Soldering up the servos and RX connections, which are done with litz wire, is not for the soldering faint hearted.
Shown are two of the Leichty/Zigras servos next to the ubiquitous Parkzone linear servo. One of the Leichty/Zigras servos is upside down to show the mechanism. The action on the LZ servos is very smooth.
The motor mount is very minimal. Two slots are cut with the laser when cutting out the fuselage. Then, two 1/64 ply pieces with holes sized for the bearing tube on the BL motor are glued and slid in place. A hand reamer reams out the foam. Finally, the motor has some UhHu Por applied and it's slid into the ply motor mounts.
Boston, Mass
Joined May 2001
Airframe is all laser cut foam. The fuselage is 6mm Depron, for stiffness. The wing and elevator are 3mm Gediplac. For each part, the openings are laser cut out. It is then painted (just a dusting). Then, the part is dusted with 3M77 adhesive and applied to a previously stretched and taped down sheet of film. The fuselage is covered on two sides and requires working fast.
After the part has the plastic film applied, it is put back in the laser (using temporary locating pins to position the part accurately) and the perimeter of the piece is cut out with the laser -- cutting through the foam and the covering in one step.
Covering is WES Technik micro indoor film, which has a weight about 1/5th that of Reynolds plastic wrap.
Old Feb 06, 2010, 04:24 PM
Boston, Mass
Joined May 2001
The wing is undercambered, not a flat plate airfoil. The center section has a two piece rib that is glued on the wing on top and bottom. This is sized to insert into a matching opening in the fuselage. The center rib also holds the aileron servo and the bell crank. Bell crank is 1/64 light ply and a BSD wheel hub and keeper. One aileron is folded back on the top of the wing when inserting the wing through the opening, and it is then folded down into its normal position. The wing also has two undercamber ribs 2/3 of the way out toward the tips. This is where the CF struts attach.
Old Feb 06, 2010, 04:25 PM
Boston, Mass
Joined May 2001
reserved 5
Old Feb 06, 2010, 04:28 PM
Boston, Mass
Joined May 2001
reserved 6
Old Feb 06, 2010, 04:30 PM
Joined Jan 2005
Air bender
Wow!!!! The level flight speed has to be super slow!!!! Thanks for showing how you kept the covering tight and smooth and I see how you keep the camber by the rib where the struts attach. Really neat!!! Ta ke off and landings will really be something else!! What kind of thrust do you expect. Also not having the bottom of the wing covered will help as air brakes.
flybob1 is offline Find More Posts by flybob1
Old Feb 06, 2010, 04:57 PM
slow climbing turn to the left
USA, CT, North Branford
Joined Sep 2009
Airbender
Amazing!
dhdrover is offline Find More Posts by dhdrover
Old Feb 06, 2010, 05:58 PM
Westbrook Maine
Joined Apr 2003
Awsome job Gordon, nice and clean.
Fritz
fmhans is offline Find More Posts by fmhans
Old Feb 07, 2010, 08:36 AM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Beautiful, can't wait until your flight reports.
Azarr
Azarr is offline Find More Posts by Azarr
Old Feb 07, 2010, 09:14 AM
USA, VA, Richmond
Joined Aug 2008
Inspiring advance of the state of the art! Thank you for sharing this.
melkor is offline Find More Posts by melkor
Old Feb 07, 2010, 10:55 AM
ducatirdr's Avatar
Central Massachusetts
Joined Aug 2006
Subscribed
I have seen a Ghost bipe in person and thought it was the coolest thing. This is another level up,. Very cool.
ducatirdr is offline Find More Posts by ducatirdr
Old Feb 07, 2010, 03:06 PM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Tell me about it!! I have a Leichty Cricket Rx and love it. Also, I have been bumble-thumbing actuator wires for years.
Each of my planes has secret epithets gingerly engraved into the foam by my self-wavering soldering iron!!
On another note, what is the torque spec for the LZ servos?
356Jim is offline Find More Posts by 356Jim
Old Feb 08, 2010, 05:52 PM
Boston, Mass
Joined May 2001
Azarr
Azarr,
I'll do better. When KIEF comes around I'll let you fly it.
Gordon
Old Feb 09, 2010, 06:49 AM
Boston, Mass
Joined May 2001
Glad you guys like it. My goal was to get a very low wing loading and thus very slow flying speed. I am really looking forward to flying it.
The Gasparin G10 Micro is listed as putting out about 24g of thrust with a 4x2.7 CF prop. So, while the thrust/weight ratio won't be tremendous, at 1.26 to 1 it should be sufficient for reasonable Aerobatics. It won't be a hovering machine, but that's not what I built it to do. I want it to fly on the wing not fly on the prop.
Nick lists them as putting out up to 10 grams of force on his site
http://microflierradio.com/Actuators.html
Gordon
Build Log EPP Cessna Aerobat Butch777 Parkflyers 10 Feb 20, 2010 07:34 PM
Sold Reactor Bipe Sport Aerobat Airplane Flazo Aircraft - Electric - Airplanes (FS/W) 0 Jan 31, 2010 04:46 PM
New Product RC Guys 150 Aerobat, 96 Inch, in August LBJ Giant Electric Planes 2 Jul 21, 2009 12:44 PM
ANYONE NEED foam wings? 3.18 inch chord by 23.75 inch CLARK Y's steelhead Aircraft - Electric - Airplanes (FS/W) 4 Jan 26, 2005 09:35 PM
