Old Nov 15, 2010, 03:04 PM
rperego is offline
Find More Posts by rperego
Joined Jul 2007
Interesting comment about locking tail wheel
The August 2010 FLYING magazine has an article about the DC-3 turning 75 years old. The article is entitled "DC-3, A Real Man's Airplane" by Martha Lunken. When talking about flying one (a real one), she says "I taxi without locking the tailwheel because Kevin would laugh at me if I didn't..."
Especially because I employed differntial throttle, I guess I'm a wimp for adding a steerable tail wheel.
BTW, the article is interesting if you can find a copy of the mag.
rperego is offline Find More Posts by rperego
Old Nov 15, 2010, 04:18 PM
BladeHead is offline
Find More Posts by BladeHead
Flick lives
BladeHead's Avatar
beautiful, picturesque Southern New Jersey, USA
Joined Dec 2008
Originally Posted by bobandris View Post
Tamilflyer,
I've been following this thread since it began; and I don't have a page 55. Probably because I have my default set to 100 posts per page. Could you give us the actual post number of yours that you are refering to?
Bob
Bob, Tamilflyer's post on p.55 was #811.
Burt
BladeHead is offline Find More Posts by BladeHead
Old Nov 15, 2010, 04:44 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
the main problem with esc's is the ESC's the set that came with mine
one arms at low throttle setting the other did not , so I used to good
esc's no problem
the esc's work well they are in other projects and flying
but one still arms at low throttle the other need's to move the stik to full
then back to low befor it will arm????????
esc's are cheap was worth the few buck's to feel safe
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Nov 15, 2010, 05:41 PM
bobandris is offline
Find More Posts by bobandris
LSF 004 - AMA 5055
bobandris's Avatar
United States, CA, Saratoga
Joined Dec 2000
Thanks Burt,
I knew it was in there, and I had seen it. But didn't remember what to do. Just checked #811 and and it all came back . . . don't do anything!
Bob
Burt
bobandris is offline Find More Posts by bobandris
Old Nov 16, 2010, 01:51 PM
HBPD is offline
Find More Posts by HBPD
HBPD's Avatar
Orange County, Ca.
Joined Jan 2009
Well after a small "Midair" its time to make the C-47 out of her. It will be a generic version but never the less a C-47. Will post more photos as I progress.
HBPD is offline Find More Posts by HBPD
Old Nov 16, 2010, 03:14 PM
Flick lives
BladeHead's Avatar
Joined Dec 2008
Ya know...This plane does seem to wear the olive-drab well.
Old Nov 18, 2010, 03:54 AM
Flying M is offline
Find More Posts by Flying M
Flying M's Avatar
United States, WA, Vancouver
Joined Oct 2010
Hi Skybus fans! I purchased a Skybus about 6 months ago and it's only my third RC plane. I finally got around to painting it and I'm now ready to start assembling. I did a quick test of the electronics when it first arrived and everything seemed normal. Now, after checking it again, I find that when I plug in the aileron servos to the receiver, the ESCs get very hot in just a few seconds. I also get a short burst from the motors. Can someone tell me what's wrong? Do I have a bad aileron servo? Are they just hooked up to the Y harness wrong? I'm baffled. Everything is fine with the other servos connected. Help!
Flying M is offline Find More Posts by Flying M
Old Nov 18, 2010, 10:43 AM
rperego is offline
Joined Jul 2007
Have you tried connecting just one servo at a time, without the Y-connector? For the ESC (BEC) to get hot that quickly one would think something is shorted.
Old Nov 18, 2010, 08:40 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
ok, I'm lazy to look through the thread.My buddy got the DC3 from Nitroplanes. Wants to make it a warbird. What are you guys using to paint them?
He wants to replicate this one:
http://en.wikipedia.org/wiki/File:Do...w_2010_arp.jpg
Melnic is offline Find More Posts by Melnic
Old Nov 19, 2010, 06:41 PM
Flick lives
BladeHead's Avatar
Joined Dec 2008
Originally Posted by Melnic View Post
ok, I'm lazy to look through the thread. . My buddy got the DC3 from Nitroplanes. Wants to make it a warbird. What are you guys using to paint them?
WWII C-47 suggested paint:
1 large can Krylon indoor/outdoor flat gray primer
1 3oz can Testors 1226 flat dark aircraft gray
3 3oz cans Testors 1265 flat olive drab
Avoid masking on top of painted foam with tape, (even the blue easy-release type).
Old Nov 20, 2010, 04:12 AM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
Invasion Stripes
Used black and white electrical tape for your invasion stripes. There is a foam ridge on the wing to get you started straight.Then just line them up carefully. I believe Bladehead pioneered this. I did not know that when I did it. Thought it was my own idea. Also check out my retracted look wheels. Mine will be a belly slider. Also painted props to look like anti ice boots, electrical tape leading edge anti ice boots,and silver windows. Motors are from Headsuprc.com. Running two Donsrc 30amp esc's and a seperate BEC. Lots of soldering which I enjoy as an Aircraft Electronics Specialist in the AF. Props are 9x5x3 counter rotating GWS trimmed to fit. Didnt think 9's would hit the fuse but they do. Pulls hard and will likely have lots of vertical but will be flown in a scale manner. Maiden later today weather permitting.
Description: Name: C47-2.jpg
Description:
Description:
Cubcrazy is online now Find More Posts by Cubcrazy
Old Nov 20, 2010, 04:21 AM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Maiden will likely be with a 2200 30c pack, but I have a couple 3000 20c on the way that will be just for this plane. Was hoping they would be here already. 13 planes and counting my addiction is terminal. Amp draw all up is 30 amps. each motor separately registers about 18 amps wide open. I guess the parallel circuit has something to do with the current distribution. I still have more detail to add but she is ready for flight.
Latest blog entry: Warning!! Graphic images of...
Old Nov 20, 2010, 11:56 AM
Flick lives
BladeHead's Avatar
Joined Dec 2008
Good luck with the maiden. I bet with your custom power and props, she'll fly as sweet as she looks. Would be great to see some vid of fly-bys with the landing gear tucked in.
Burt
Old Nov 20, 2010, 04:36 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Unfortunately my lazy self over slept during my afternoon pre-flight nap. Maiden will have to wait till tomorrow. In the meantime, time to add a spot on my plane rack for Juliet Kilo. ( My C-47 tail Flash Letters)
Old Nov 20, 2010, 06:12 PM
Flick lives
BladeHead's Avatar
Joined Dec 2008
Now that I'm again checking out Cubcrazy's pics of his nice C-47 with the gear up, I have an interesting factoid to share with my fellow Skybus drivers from my vast file of useless mental trivia. Did you know that the guys who engineered Donald Douglas' little masterpiece designed the retractable mains so as to minimize damage in the event of a belly-landing? Even if the plane touched down with wheels in the wells, they still protruded just enough to support the plane and roll! There was a real chance that the only damage would be to the props. No kiddding, you could look it up.
Discussion DC-3 Plans blackwidow18 Australia 2 Jan 17, 2010 08:27 PM
Sold Celectra 4-Port 1S 3.7V 0.3A DC Li-Po Charger by E-flite DuaneV Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 15, 2010 09:02 AM
For Sale Great Planes DC-3 project sunderll Aircraft - Electric - Airplanes (FS/W) 3 Jan 12, 2010 07:34 PM
Sold Celectra 4-Port, 1-Cell, 3.7, 0.3A DC Li-Po Charger, Plus 3 240MAH Single Cell Packs. jafo216 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Jan 01, 2010 11:55 AM
Sold Dynam 5-Channel Receiver/Dynam 3 in 1 Gyro CGReload Aircraft - General - Radio Equipment (FS/W) 3 Aug 18, 2008 04:40 PM
