Old Nov 05, 2010, 08:39 PM
bobandris is offline
Find More Posts by bobandris
LSF 004 - AMA 5055
bobandris's Avatar
United States, CA, Saratoga
Joined Dec 2000
Originally Posted by pulsery2k1 View Post
Hi rob737
I been very busy, only one month to retirement , I been working
on this slowly , I found some 8x6 scale 3 blade props but need to
test them, then I will list the link as to where to get them .
Hi pulsery2k1,
Did you ever sort out the 8x6 3-blades you mentioned? Best I could find in this thread for L&R 3-blades was the GWS 8x4's cut down to 7x4's by xplaneguy in post #223 and 235.
Bob
bobandris is offline Find More Posts by bobandris
Old Nov 06, 2010, 01:24 AM
pilot40874 is offline
Find More Posts by pilot40874
Los Angeles
Joined Sep 2010
Need help....
I hope I didn't do something to screw up my TX and RX.
I finally got my Dynam Skybus from Nitro Planes today. Attempted to do a "dry run" before assembly to make sure that all of the electronics were working correctly (servos, RX, TX, etc.) However, after I hooked up all the connections to the RX and charged the battery, I powered up the TX (first), but nothing seems to be working.
The transmitter is on, and the RX is blinking quickly, but none of the servos or motors is operational.
I'm hoping I just messed up the binding between the TX and RX somehow. Didn't really understand the Chinese directions on the TX as far as the "protection switch".
Can somebody explain to me how to rebind the 2.4ghz TX and RX so I can test out things before assembly?
Jim
pilot40874 is offline Find More Posts by pilot40874
Old Nov 06, 2010, 01:43 AM
Los Angeles
Joined Sep 2010
I think it might have something to do with the 7 channel receiver that comes with the 2.4ghz of the RTF version.
I found some additional information elsewhere on the net where the problem was resolved by plugging the throttle cable into the Aux 2 position on the receiver and NOT the throttle position. Weird huh...
Something about a 4 channel plane and a seven channel receiver.
I'll give that a try tomorrow, but if anybody has any additional information on this, I'd appreciate hearing what you've know.
Thanks for all the input.
Old Nov 06, 2010, 04:50 AM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
Jim
Sorry, I can't help you since I bought the RX-ready version for my Futaba FASST 7C. I'm sure it's just some crazy protocol problem and someone with the 2.4gHz RTF will chime in for you.
Aeronca
aeronca is offline Find More Posts by aeronca
Old Nov 06, 2010, 07:24 AM
dbc is offline
dbc
Find More Posts by dbc
dbc
United States, FL, Brooksville
Joined Apr 2008
I just received my Dynam Grand Cruiser yesterday which has the same 2.4G Dynam radio system as used in the Skybus. And I had the very same issues with it. Could not get it to power up. The planes motors, servos and ESC's worked fine when I replaced the Dynam radio system with a Spectrum receiver and used my DX6i.
I then retried the Dynam radio and it worked. Second power up required some time and fiddling with the "protection swith" to get it to work. Sometimes it will power up; sometimes it won't.
Since it works only intermittently, I'm going to use the Spectrum system in this new plane. I'll work with the Dynam 2.4 system on the test bench to see if I can get it to perform consistently before risking using it. I'll just toss it out if I can't feel comfortable with it. It's only about a $30 tx/rx.
Anyone else with this 2.4 Dynam radio, please let us know your experiences.
dbc is offline Find More Posts by dbc
Old Nov 06, 2010, 08:54 AM
aeronca is offline
aeronca's Avatar
Joined Oct 2003
That is precisely why I bought the RX-ready version of the Skybus for my Futaba FASST 7C system! Besides, I really didn't need ANOTHER transmitter OR receiver of questionable quality.
Aeronca
Old Nov 06, 2010, 09:08 AM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
bobandris
the scale props worked great, the master airscrew 7X4 3blade
didn't quite have enough power I have the master airscrew
8X6 3 blade on the model , but havn't tryed them yet.
the wind seem's to like 15-20 mph each day so I haven't
flown it with them.
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Nov 06, 2010, 09:21 AM
dbc is offline
dbc
dbc
Joined Apr 2008
No reciever ready version of the cruiser is avaliable now, I probably would have chosen that.
But for only $30 more you get the tx/rx, 2200 3s lipo and a charger with ac adapter. The battery alone is worth almost that much. If I end up discarding the tx/rx it was still a reasonably good deal.
Old Nov 06, 2010, 11:10 AM
aeronca is offline
aeronca's Avatar
Joined Oct 2003
I do agree the RTF is worth the cost differential especially if you don't have a good collection of LiPo's, but I just didn't want their transmitter and receiver. Too bad they did away with the RX-ready option.
Aeronca
Old Nov 06, 2010, 01:04 PM
dbc is offline
dbc
dbc
Joined Apr 2008
Grayson is going to carry a RX ready version of the Grand Cruiser but they don't know when they will be getting it. I bought the RTF version from Nitroplanes and glad I did. They were out of stock on them 4 days after they went on sale! So it may be a while before either source has them available.
Pilot40874:
I've been playing around with the Dynam 2.4G radio this morning and discovered several interesting things (these may or may not apply to all of these systems):
1) The receiver will not link up to the transmitter if you turn on the tx first and wait for the blinking power lights to go solid and then hook up the battery. This is the way we're traditionally told to do it but I cannot get it to link this way.
2) However, if you will first hook up the battery (powering the rx) and then turn on the tx , it will link every time.
3) If you hook up the battery while the tx power lights are still flashing it will also link up.
4) The "protection switch" must always be moved to the position farthest away from you. If you started in this position, you must pull it forward and them push it back to power the motors. This must be done after you've heard the beeps from the ESC's indicating they are powered.
5) The rotary knob adjusting the servo travel (essentially end-point adjustments) works nicely except it has no effect on the rudder servo. That's precisely the one I'd like to be able to adjust to soften the nosewheel steering (on the Grand Cruiser) which is often too touchy to get smooth, scale-like roll outs on landings and takeoffs.
6) The throttle trim is not very linear and behaves erratically. No setting is able to give full stick travel, linear power. About the first 25% of the stick travel is always dead.
I'm still a little skeptical of this radio and may try it first in some "disposable" plane. I haven't yet tried a range check.
If its turned on in the sequence I just outlined, mine will link and power the ESC's, motors and servos just fine.
Old Nov 06, 2010, 05:52 PM
Los Angeles
Joined Sep 2010
Yep, and since the version without the TX,RX only reduces the price by $9.75 at Nitro Planes. I figured for an additional $9.75, it's worth it just for the battery and ac adapter; even if I throw out the RX,TX eventually.
Old Nov 06, 2010, 05:54 PM
Los Angeles
Joined Sep 2010
Thanks for the information dbc...great news. I'm going to give your suggestions a try and hope to have things operational soon.
Old Nov 06, 2010, 07:43 PM
Los Angeles
Joined Sep 2010
That did the trick! Works great. Thanks again dbc.
Old Nov 06, 2010, 08:23 PM
dbc is offline
dbc
dbc
Joined Apr 2008
Glad it worked for you!
I just took my DC3 out for a flight and realized how much I enjoy it. It now has logged 49 flights with absolutely no problems.
Love the resonance of the two motors at part throttle on low, eye level fly-bys!
Old Nov 06, 2010, 10:11 PM
Josephp13 is offline
Find More Posts by Josephp13
Vertical
Josephp13's Avatar
United States, NV, Las Vegas
Joined Sep 2010
Some photos of HBPD stock DC-3. I took them this Friday morning. 11-5-2010. It was a great Southern CA day. Because of HBPD and Bladehead I purchased one, just airframe for 49.99 plus 10% off for a holiday discount.
HBPD glad I did not crash her when you handed me the controls. Thank you so much for the stick time, I look forward to building mine up early 2011.
Josephp13 is offline Find More Posts by Josephp13
Discussion DC-3 Plans blackwidow18 Australia 2 Jan 17, 2010 08:27 PM
Sold Celectra 4-Port 1S 3.7V 0.3A DC Li-Po Charger by E-flite DuaneV Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 15, 2010 09:02 AM
For Sale Great Planes DC-3 project sunderll Aircraft - Electric - Airplanes (FS/W) 3 Jan 12, 2010 07:34 PM
Sold Celectra 4-Port, 1-Cell, 3.7, 0.3A DC Li-Po Charger, Plus 3 240MAH Single Cell Packs. jafo216 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Jan 01, 2010 11:55 AM
Sold Dynam 5-Channel Receiver/Dynam 3 in 1 Gyro CGReload Aircraft - General - Radio Equipment (FS/W) 3 Aug 18, 2008 04:40 PM
