Old Oct 18, 2010, 03:51 PM
Darwood is offline
Find More Posts by Darwood
Joined Sep 2010
Originally Posted by xplaneguy View Post
I have three and they all run fine. Grayson Hobby has always treated me right!
Best,
Tony
Well, I only have one, which is my last one.
When a manufacturer (Dynam) ignores problems with their products and the distributor (Nitroplanes/Hobbypartz) doesn't seem to know anything about what they sell and can't replace parts with the correct part, they have lost me as a customer.
It's like playing Russian Roulette. I think you're very lucky to have bought three and not to have any problems.
Darwood is offline Find More Posts by Darwood
Old Oct 18, 2010, 04:02 PM
rperego is offline
Find More Posts by rperego
Joined Jul 2007
Originally Posted by 12345 View Post
rpergo, Thanks for the suggestions.
We at the club have come to the conclusion (after several crash post inspections) it most likely is not a brown out.
LED is ALWAYS solid and everything seems to be in good working order as far as servos, motors and ESC's.
However, could you expand a bit on this?
"Are you by chance using a switching UBEC located close to the RX?"
YES, I have a castle external BEC wired in semi-close proximity to RX.......
All 6 crashes have been within a 50 yard radius.......
Thanks Much, Bill
This is new to me, from reading about switching UBECs before I buy one. Apparently the noise from these BECs can potentially interfere with 2.4gig systems. The recommendation is to locate it away from the RX and/or use a choke which some come supplied with.
Sounds like something you might be able to bench test.
rperego is offline Find More Posts by rperego
Old Oct 18, 2010, 07:37 PM
12345 is offline
Find More Posts by 12345
I am Bill
12345's Avatar
United States, AZ, Mesa
Joined Feb 2010
Very interesting. That's exactly where I will start, once I am done with my epoxy work
Until then a bit of research....
Thanks,Bill
12345 is offline Find More Posts by 12345
Old Oct 19, 2010, 06:07 PM
Darwood is offline
Joined Sep 2010
First and second flights today. I like it. It's not perfect, but I like it.
It is very pitch sensitive to throttle, which may be why Dynam put in so much down thrust. I'm going to experiment with the down thrust and see what, if any, effect changing it has on how the plane handles. I also think I'll see what effect some out thrust has.
The second landing was on the mains for about 10 feet....looked good.
I guess I'll make it into a WWII C47 over the winter.
Old Oct 19, 2010, 06:56 PM
BladeHead is offline
Find More Posts by BladeHead
Flick lives
BladeHead's Avatar
beautiful, picturesque Southern New Jersey, USA
Joined Dec 2008
Congrats on the Maiden, Darwood. Plz post video for those of us who may be temporarily flight-challenged? Doing the C-47 Skytrain, eh? It will be good to have another one in the squadron.
"I have not failed. I've just found 10,000 ways that won't work."
-Thomas A. Edison
BladeHead is offline Find More Posts by BladeHead
Old Oct 19, 2010, 07:22 PM
pulsery2k1 is online now
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Finally a day with less than 20+ mph wind I had 8X6 3 blade props
and decided to try master 7X4 3 blade props -not good- very underpowered
and becouse our state is broke the park with our paved flying field is
closed and this does not like grass - first attempt to right second
you have to hold full up to keep it from nosing over - well it jumped
in to the air before it had the proper flying speed. but once up it flew well.
Piedmont Dc-3 from grass.wmv (2 min 42 sec)
pulsery2k1 is online now Find More Posts by pulsery2k1
Old Oct 20, 2010, 05:07 AM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
GREAT news, Darwood! After so much trouble and aggravation, to what do you attribute your new-found successful flights? Was it the re-programming of the ESC's? I'm really happy things are working out for you!
Aeronca
aeronca is offline Find More Posts by aeronca
Old Oct 20, 2010, 08:24 AM
Darwood is offline
Joined Sep 2010
Aeronca
No, I wish it was as simple as re-programming the ESCs.
Nitroplanes finally replaced the ESCs and harness. But, they sent me ESCs/harness from some other airplane, so it didn't fit the Skybus. I had to re-do the harness to make it usable.
I guess the bottom line was, one of the original ESCs was bad.
Old Oct 20, 2010, 10:11 AM
aeronca is offline
aeronca's Avatar
Joined Oct 2003
Gotcha. I remember them sending you new ESC's that were a problem (didn't fit, or something like that) and just didn't realize you worked on them to make them function for you.
Good luck!
Aeronca
Old Oct 20, 2010, 07:04 PM
Flick lives
BladeHead's Avatar
Joined Dec 2008
Maiden
Video of today's latest maiden attempt. She taxis beautifully.
C-47 Maiden FAIL (3 min 19 sec)
Old Oct 20, 2010, 09:53 PM
Tamilflyer150 is offline
Find More Posts by Tamilflyer150
Hemet,CA
Joined Jul 2010
http://www.youtube.com/watch?v=d5nmWvWCjf4
Well it appears your right prop is on backwards, you can see it at 3:03. The round or concave shape of the prop is facing back while your left prop is forward.
Tamilflyer150 is offline Find More Posts by Tamilflyer150
Old Oct 20, 2010, 10:01 PM
Heavy Chevy is offline
Find More Posts by Heavy Chevy
Vanadu
Heavy Chevy's Avatar
Canada, YT, Whitehorse
Joined Dec 2008
I was wondering the same thing....something didn't look right about the way the props are spinning but I could never get a good look through the video. Are the props spinning the right way?
Heavy Chevy is offline Find More Posts by Heavy Chevy
Old Oct 21, 2010, 11:15 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Bigger wheels will help on grass.
Melnic is offline Find More Posts by Melnic
Old Oct 21, 2010, 01:10 PM
xplaneguy is offline
Find More Posts by xplaneguy
EB-66C Team Member
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
Darwood-Glad to see you stuck with it and are having successful flights.
Best,
Tony
xplaneguy is offline Find More Posts by xplaneguy
Old Oct 21, 2010, 03:32 PM
Darwood is offline
Joined Sep 2010
Best,
Tony
Thanks Tony. I now have 4 flights on it.
I don't think I've ever flown a plane where I had to "feather" the throttle as much on takeoff and landing like I have to on the Skybus. I like a good amount of rolling on the mains for both takeoff and landing and that's the only way I've found that gives me that. Anything close to full throttle and it just wants to go straight up, which is not a pretty takeoff. And no throttle on landing just gives me a bouncing three-point.
Oh well, I guess it's just going to take time to get used to it.
Discussion DC-3 Plans blackwidow18 Australia 2 Jan 17, 2010 08:27 PM
Sold Celectra 4-Port 1S 3.7V 0.3A DC Li-Po Charger by E-flite DuaneV Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 15, 2010 09:02 AM
For Sale Great Planes DC-3 project sunderll Aircraft - Electric - Airplanes (FS/W) 3 Jan 12, 2010 07:34 PM
Sold Celectra 4-Port, 1-Cell, 3.7, 0.3A DC Li-Po Charger, Plus 3 240MAH Single Cell Packs. jafo216 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Jan 01, 2010 11:55 AM
Sold Dynam 5-Channel Receiver/Dynam 3 in 1 Gyro CGReload Aircraft - General - Radio Equipment (FS/W) 3 Aug 18, 2008 04:40 PM
