Old Aug 21, 2012, 06:11 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
quitcherbitchen
Well in the old brushed motors there were ware parts , some equipment
had oiler's , but with the newer brushless motors which can run for
thousand's of hours , the use maintenance free sealed bearnings
which are """"Lubricated for life """ the lub is sealed in the dirt which
can destroy a bearning is sealed out .
but as with everything in life I could be wrong , just ask my wife.
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Aug 21, 2012, 07:00 PM
DeathWarmedUp is offline
Find More Posts by DeathWarmedUp
Plane Fanatic
DeathWarmedUp's Avatar
Australia, QLD, Gympie
Joined Jul 2007
Originally Posted by lebl468 View Post
Was going to maiden today, however, she has a good pull to the left. I have read about the ESC's being out of sync, but one motor seems to be built tighter, I am guessing you cannot feel ESC timing in an unpowered motor. On the stand, I ran it up a few times and it seems like it it getting looser, but it could just be me. Any thoughts?
Did you set the ESC's to TX Throttle Range?
  1. Remove the Props for safety.
  2. Turn on your Transmitter
  3. Put the Throttle Stick to Max
  4. Plug in the LiPo and power up the Plane
  5. The ESC's will do the normal start tones but wait for a sec
  6. Then you will hear another set of tones
  7. Pull the TX Throttle back to Off
  8. ESC's will give another set of tones.
  9. Remove LiPo from the Plane
Both ESC's should now be synced to the TX throttle min/max.
DeathWarmedUp is offline Find More Posts by DeathWarmedUp
Old Aug 21, 2012, 08:08 PM
WVrailfan is offline
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
And, just in case you're not tired of me posting photos, here are my two Dynam C-47s. One an ex Navy R4D turned Army transport the other an ex Army transport turned corporate flying business car.
Jim
WVrailfan is offline Find More Posts by WVrailfan
Old Aug 21, 2012, 08:21 PM
Plane Fanatic
Joined Jul 2007
Mate, I for one, never get sick of looking at Planes
Nice ones!!
Old Aug 21, 2012, 09:37 PM
lebl468 is offline
Find More Posts by lebl468
lebl468's Avatar
Cold Lake, Alberta
Joined May 2010
I think it is a case of a tight motor, but I will throttle range them as it definitely cannot hurt. Thanks for showing me how it is done.
Chris
lebl468 is offline Find More Posts by lebl468
Old Sep 07, 2012, 10:12 AM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Doushiyou12's Avatar
Joined Feb 2010
Creeping my way closer to the maiden. Its been about a month and half since I received this plane. Just haven't had time. defiantly did the steerable tail wheel. Few more things need to be done.
Huge dent that I was really upset with. filled in with light Spackle.
After.
Thinking of filling in the whole compartment and modifying the batt hatch to the bottom as I saw someone on here do. maybe down the line.
3in dubro wheels. working on the wiring still.
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Sep 09, 2012, 12:22 PM
Andre Kochanski is offline
Find More Posts by Andre Kochanski
The Depronizer
Andre Kochanski's Avatar
Germany, NRW, Dortmund
Joined Aug 2012
retracts - remember Nov 10, 2010 ?
Hi guys,
in late 2010 (Nov.10 to be exact) i developed a retract system for the dynam DC-3 using original parts and 3d-printed moving parts.
i now found a possible way for you to get a reliable and extremely strong retract mechanism for your dynam DC-3.
i just added my youtube-video of the testing:
Dynam Skybus DC-3 Fahrwerkstest Retracts Test (3 min 36 sec)
and this is the original post (i changed my rcg-alias cause i now wanted to use my real name):
http://www.rcgroups.com/forums/showp...&postcount=924
So this is the link to a company in the US printing models for everyone at fairly reasonable prices. It is still pricy but maybe someone could make moulds and replicate some parts.
this is the link to the parts:
http://www.shapeways.com/search?q=dynam+skybus
Operation:
The main carrier sits in the original dynam main support baseplate. Glued to a 3mm carbon rod, it can rotate/pivot through torsion of that rod. In the middle of the wing sits the retract servo.
all the other pieces are connected by 3mm carbon cylinders and secured with CA. for the support at the back a 5mm carbon cylinder is used.
this system is light, easy to assemble a extremely durable. i am now running my retracts for two years without a single problem. works like a charm even after this long time.
so then - if anyone is interested just go ahead
Greetings!!!
Andre Kochanski is offline Find More Posts by Andre Kochanski
Old Sep 09, 2012, 03:47 PM
Seahawk One is offline
Find More Posts by Seahawk One
What tree??.......Doh!!
Seahawk One's Avatar
USA, WA, Seattle
Joined Aug 2007
Originally Posted by Andre Kochanski View Post
Hi guys,
http://www.youtube.com/watch?v=0pZApAIsiNc
Operation:
Greetings!!!
Andre- simply Awesome! I remember back in the day when you creating the original. Was sooo envious!
One question. For the first part in the shapeways listing called "connecting piece" ( $4.83) do I need to order 2 per land gear or is the price per pair?
Thank, Neil
Seahawk One is offline Find More Posts by Seahawk One
Old Sep 10, 2012, 08:41 AM
The Depronizer
Joined Aug 2012
Hi Neil,
glad you like it Having access to a printer for free was just a perfect opportunity! The other part was convincing the professor that they are necessary for my work, but i was lucky
For you now the parts cost, but the geometry is really simple so that reproducing them should be easily possible.
And you are right, you will need two of the connecting pieces for one unit. by the way i couldnīt come up with a better name for these things
This is what you need for one plane:
2x main carrier
4x connecting piece
2x aft base
if you print just one piece of every part you only pay about $26. thats a reasonable price in my opinion.
greetings!
Old Sep 10, 2012, 09:02 AM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
I sold one of my planes in my hanger to make room for this bird and it looks like it is sold out almost everywhere.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Sep 10, 2012, 09:20 AM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
http://www.snhobbies.com/index.php?c...4d4e4625476cab
xviper is offline Find More Posts by xviper
Old Sep 11, 2012, 02:12 PM
rcflyinff is offline
Find More Posts by rcflyinff
rcflyinff's Avatar
United States, FL, Titusville
Joined Mar 2012
Sound like as soon as Nitroplanes gets this bird back in stock, that my son wants to buy it with his birthday money. I looks cool, but I was just wondering how it flies? Youtube videos looks like it does well. Does it have counter rotating props? Never had a twin engine, so just wondering what to expect. We have only ordered once from Nitroplanes. Do they get their stock back up pretty quick? Thanks for your help.
rcflyinff is offline Find More Posts by rcflyinff
Old Sep 11, 2012, 05:06 PM
flyinwalenda is offline
Find More Posts by flyinwalenda
EIEIEIO Classic is dway ta go!
flyinwalenda's Avatar
Northeast Pa. .Heyna or No?
Joined Aug 2009
Read this thread from the start and you will get a lot of info. I put counter rotating props on mine along with the full conversion (short of retracts)to an AC-47 gunship. Mine flies very scale just the way I wanted it to...not overpowered at all. Ground handling is tricky if you are not familiar with tail draggers and the plane WILL tip stall just like the full scale one. Otherwise it's a comfortable plane once in the air.
As far as NP's goes I would never buy a plane from them...ever. I bought mine elsewhere.
Good luck !
flyinwalenda is offline Find More Posts by flyinwalenda
Old Sep 11, 2012, 08:10 PM
WVrailfan's Avatar
Joined Jun 2011
Anyone know where to get a motor shaft, or replacement motor for these planes. I hit some tall grass when aborting a take off and bent a shaft.
Jim
Old Sep 11, 2012, 08:20 PM
xviper is offline
Canada
Joined Jul 2009
Jim
I did the same. Got mine from Grayson Hobby.
http://www.graysonhobby.com/catalog/...or-p-1362.html
Discussion DC-3 Plans blackwidow18 Australia 2 Jan 17, 2010 08:27 PM
Sold Celectra 4-Port 1S 3.7V 0.3A DC Li-Po Charger by E-flite DuaneV Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 15, 2010 09:02 AM
For Sale Great Planes DC-3 project sunderll Aircraft - Electric - Airplanes (FS/W) 3 Jan 12, 2010 07:34 PM
Sold Celectra 4-Port, 1-Cell, 3.7, 0.3A DC Li-Po Charger, Plus 3 240MAH Single Cell Packs. jafo216 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Jan 01, 2010 11:55 AM
Sold Dynam 5-Channel Receiver/Dynam 3 in 1 Gyro CGReload Aircraft - General - Radio Equipment (FS/W) 3 Aug 18, 2008 04:40 PM
