Old Nov 12, 2011, 08:02 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
midnite- okay thanks. so you don't feel it is a good aileron trainer?
xviper- this was your first aileron plane? so you would recommend this?
electricrc68 is offline Find More Posts by electricrc68
Old Nov 12, 2011, 08:26 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
I would recommend it but I don't know what your skill level is at this time. I flew a Radian for a full season and then a "V" tail plane for a bit before I flew the DC3. I also came from an RC helicopter background, so working all the sticks was not new to me.
I now have, as aileron planes, a U2 ducted fan jet, a Fox Glider powered sailplane, B-25 twin engine bomber and the DC3. The DC3 is by far, the easiest of them all to fly. If you want easier, go with a Cub but this DC-3 is the cheapest. You'll probably crash either one. I'd rather crash the cheap one.
xviper is online now Find More Posts by xviper
Old Nov 12, 2011, 08:28 PM
Joined May 2011
okay thanks. yeah im probably going to go for a cub instead. thanks.
Old Nov 12, 2011, 10:34 PM
garryk is offline
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
Actually a cub has bad slow speed characteristics. I mean fatal ones. Generally speaking of course. Depends on the builder or manufacturer. Like the Park Zone one is easy to fly.
Garry K.
garryk is offline Find More Posts by garryk
Old Nov 13, 2011, 08:11 AM
Joined May 2011
oh okay thanks.
Old Nov 13, 2011, 10:07 PM
Midnite Tweeke is offline
Find More Posts by Midnite Tweeke
Joined Sep 2009
I have quite a few Dynam planes (7 or so) and overall I've been quite satisfied with them. I think the value is quite good, but you need to accept the fact that there will be certain things you need to inspect to insure they're in flyable condition before take-off. In particular, factory-glued fittings are somewhat notorious for either being loose or coming loose. So check 'em & re-glue 'em if necessary. I don't mind addressing minor details---in fact, I enjoy it---and considering the price, if it flies well when I'm done, I'm happy.
One plane I don't have is this one: http://www.nitroplanes.com/60a-dy893...2-new-arf.html but based on the reviews it might be a good aileron trainer for you. $90 is hard to beat. I've never had a problem with Dynam electronics and at least half of my fleet have been RTF's.
Whether it would be a good choice for you depends on if you can address the issues the reviewers raised.
MT
Midnite Tweeke is offline Find More Posts by Midnite Tweeke
Old Nov 21, 2011, 10:34 AM
rgwilson is offline
Find More Posts by rgwilson
rgwilson's Avatar
USA, TX, Arlington
Joined Aug 2010
Dynam C-47 Skybus
Just received my Skybus last Thursday. It came with 30 amp esc's instead of the stated 40 amp. The motors were a little tight so I removed them and had to adjust the endplay by removing some material from the brass spacer at the back of the motor shaft. They both seem to turn freely and in unison now.
I also added the steerable tailwheel mod to it but the stock servo did not seem up to the task of the additional load. I replaced both the elevator and rudder servos with Hitec HS-81's which were a perfect fit in the fuse servo cutouts. During taxi tests I also noticed the left motor esc cutting off and re-initializing so I replaced both of the factory Y-harnesses and the issue seems to have gone away, certainly don't want to see that happen during flight.
I hope to get in the maiden flight soon, weather permitting.
rgwilson is offline Find More Posts by rgwilson
Old Nov 21, 2011, 10:38 AM
mt_flyer is offline
Find More Posts by mt_flyer
Montana Transplant
mt_flyer's Avatar
United States, TX, Sealy
Joined Aug 2005
seems like you addressed the "dangerous" issues. 30A ESC won't be a problem as the motors are 18A
mt_flyer is offline Find More Posts by mt_flyer
Old Nov 21, 2011, 02:07 PM
rgwilson is offline
rgwilson's Avatar
USA, TX, Arlington
Joined Aug 2010
Stock Power?
Anybody ever check the power of the stock motor setup?
I checked mine and it comes in at:
330 watts @ 10.8v on a 3s 3200 mAh 20C turning the stock Dynam 8x6 3 blade props.
Just wondering if this sounds about right. About 30.8 amps total or 15.4 amps per motor, if my calculations are correct.
All up weight is 2 lbs. 6 oz. so about 139 watts per lb.
Old Nov 21, 2011, 02:45 PM
race58 is offline
Find More Posts by race58
race58's Avatar
USA, IL, Huntley
Joined Feb 2006
What are the issues with the "Y" connectors?
race58 is offline Find More Posts by race58
Old Nov 21, 2011, 02:50 PM
WVrailfan is offline
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
repaint ideas?
I picked up a Dynam Skybus which I would like to repaint as the first corporate plane of the C&O Railway. the plane will be white above the window line and bare metal below, including the wings, with a dark blue band along the window line.
Since I know several of you have repainted your DC3, I was wondering how you would suggest the bare metal look. I guess I could just paint it silver, but I am also thinking of covering the lower half of the fuse and the wings with silver Monokote.
Any thoughts?
Jim
WVrailfan is offline Find More Posts by WVrailfan
Old Nov 21, 2011, 03:26 PM
rgwilson is offline
rgwilson's Avatar
USA, TX, Arlington
Joined Aug 2010
"Y" connectors
After reading several posts in this thread, there have been several crashes caused by these factory "Y" harness failures. Do yourself a favor and simply replace them and not risk an engine out or aileron failure in the air. A couple of $4 Y-connectors are cheaper than repairing/replacing the airframe IMO.
Old Nov 21, 2011, 04:00 PM
race58 is offline
race58's Avatar
USA, IL, Huntley
Joined Feb 2006
I have read what your saying and that folks are replacing them but I'm trying to find out what has been wrong with them specifically.
In other words how do you distinguish quality "Y"'s from the bad ones when you see them.
Old Nov 21, 2011, 04:34 PM
Seahawk One is online now
Find More Posts by Seahawk One
What tree??.......Doh!!
Seahawk One's Avatar
USA, WA, Seattle
Joined Aug 2007
Any thoughts?
Jim
Oracal 651. Many of the 737 guys have used it on their planes.
It is more of a stretchy vinyl than film you need a hot iron to use with a la monokote. It also adheres better to foam than monokote. They also have chrome, to various shades of gray/silver or metallic whatever to suit your needs. It is also what Callie uses when she makes the graphics for many of the planes.
Cheers~ Neil
Seahawk One is online now Find More Posts by Seahawk One
Old Nov 21, 2011, 04:51 PM
WVrailfan's Avatar
Joined Jun 2011
Thanks for the tip, I'll look into this. You wouldn't happen to know of a vendor for it?
Jim
Cheers~ Neil
Discussion DC-3 Plans blackwidow18 Australia 2 Jan 17, 2010 08:27 PM
Sold Celectra 4-Port 1S 3.7V 0.3A DC Li-Po Charger by E-flite DuaneV Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 15, 2010 09:02 AM
For Sale Great Planes DC-3 project sunderll Aircraft - Electric - Airplanes (FS/W) 3 Jan 12, 2010 07:34 PM
Sold Celectra 4-Port, 1-Cell, 3.7, 0.3A DC Li-Po Charger, Plus 3 240MAH Single Cell Packs. jafo216 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Jan 01, 2010 11:55 AM
Sold Dynam 5-Channel Receiver/Dynam 3 in 1 Gyro CGReload Aircraft - General - Radio Equipment (FS/W) 3 Aug 18, 2008 04:40 PM
