Old Mar 19, 2011, 06:58 PM
Tamilflyer150 is offline
Find More Posts by Tamilflyer150
Hemet,CA
Joined Jul 2010
Well heres just a little update on my Skybus, i basically just painted my GWS 8x4 orange props a more realistic color, it came out pretty good.
Description:
Tamilflyer150 is offline Find More Posts by Tamilflyer150
Old Mar 19, 2011, 09:31 PM
jeffkix is offline
Find More Posts by jeffkix
jeffkix's Avatar
Joined Dec 2008
Attachment 3879162
Looks good! Your last couple of Skybus videos were great to watch.
jeffkix is offline Find More Posts by jeffkix
Old Mar 19, 2011, 09:48 PM
jeffkix is offline
jeffkix's Avatar
Joined Dec 2008
Originally Posted by Big Johnny View Post
Been working on my Skybus. Replaced the motors with some 480's and Esc's from Jeff at Heads Up. Replaced the wheels with some 3 inchers I had lying around. I fly from a rough grass field and the stock set-up wasn't cutting it. It would not accellerate to flying speed. I am going to use a 4s1p 4000 lipo and 8 x 6 3 bladed counter-rotating props. I'm also adding flaps. The stock wheels got stuck on every clump of grass.
Hey Big Johnny - What Escs go with those 480s?
Heads Up has awesome shipping to go with their great selection and prices.
BTW - their 3mm x 47mm replacement prop shaft fits the Dynam Motors - just add a collet prop adapter and you're back in business. But buy some spare shafts, they're pretty soft...
Old Mar 22, 2011, 09:50 PM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
In flight pics with retracts,
Didn't get any pictures with the gear down, but rest assured my Eflite retract units work flawlessly. I do not have any problems with nose-over either as some have indicated. And as this was my first weekend out testing the MAS 8x6 three blade props, I can say..wow, smooth running, plenty of power, and scale cruising at about 60% throttle. With the GWS 9x5's I had before, I was not getting nearly as good of performance and I had to run at higher throttle most of the time. It also helps that I started running 2650 40c 3s instead of the 3000 20c 3s. The 40C batts pack more punch for sure. Now I need to do the surgery to make the tail wheel steerable. I had originally glued it in place as a belly slider, and now it is free castering, but binds badly.
Cub
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: GWS Funny Park
Old Mar 22, 2011, 11:59 PM
DaveBC is offline
Find More Posts by DaveBC
Obessive Compulsive
Visalia, California
Joined Mar 2010
Cub
Nice over all. Love the ageing paint job....
DaveBC is offline Find More Posts by DaveBC
Old Mar 23, 2011, 12:09 AM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Yeah that effect was achieved by allowing over spray from the underside, to get on the top side a little. It kinda looks like overspray to me, but also looks kinda cool, so I just left it. Gonna touch up the underside where I did the retract install. Then it will be time to readdress the tail wheel.
Cub
Old Mar 24, 2011, 02:48 PM
flyinwalenda is offline
Find More Posts by flyinwalenda
EIEIEIO Classic is dway ta go!
flyinwalenda's Avatar
Northeast Pa. .Heyna or No?
Joined Aug 2009
DC-3 Skybus to AC047 Spooky
Here's some quick pics and a little video of my work so-far. Paint work and clear is done, detailing is done, lighting is done, and decals are almost finished. Still need to find some scale prop adapters for the GWS props. Otherwise it's stock running gear.
Brian
Skybus DC-3 to AC-47 Spooky (3 min 32 sec)
flyinwalenda is offline Find More Posts by flyinwalenda
Old Mar 24, 2011, 03:48 PM
DaveBC is offline
Obessive Compulsive
Visalia, California
Joined Mar 2010
Brian
http://www.youtube.com/watch?v=N9KEySKL8ag
Wow Nicely Done
Old Mar 24, 2011, 04:44 PM
A Rdnek is offline
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
Originally Posted by DaveBC View Post
Wow Nicely Done
++1
Yes, VERY nicely done.
Ron
A Rdnek is offline Find More Posts by A Rdnek
Old Mar 24, 2011, 06:57 PM
Hemet,CA
Joined Jul 2010
well heres just another quick update on my GWS 8x4 props on my skybus, i had to take the old paint off because it was very heavy and made the props very unbalanced and the paint acrylic paint i used was kinda old so i re-painted them again with some newer paint but instead of blue and white tips i choose to paint the tips yellow instead because it shows up better.
Description: Name: IMAG0001.jpg
Description:
Old Mar 25, 2011, 06:11 PM
DoctorBill is offline
Find More Posts by DoctorBill
Joined Dec 2008
Thr DC-3 is great - I also have Dynams Cessna 310R (Grand Cruiser) that flys even better (I think). The steerable nose wheel makes ground handling much better but I have added steerable tail wheel to my DC-3. I'm going to try to add pic.s of the mod. but don't see any "add attachment" button here.
At any rate I cut a small square section out of the bottom of fusalage including the tail wheel, attached a control arm to the tail wheel button inside, ran a push/pull shaft from that arm to the rudder servo and glued it back in place. Not as good ground control as the tricycle gear on the Cessna (the DC-3 tail is pretty light) but it's pretty good as long as you don't have too much cross wind.
If I'm able to post a picture you'll notice I painted the plane silver like the original DC-3s - looks cool on the groung and in the air.
DoctorBill is offline Find More Posts by DoctorBill
Old Mar 26, 2011, 02:48 PM
pilot40874 is offline
Find More Posts by pilot40874
Los Angeles
Joined Sep 2010
Brian
Great job on the camo paint scheme. That's not an easy task. Very nice job!
pilot40874 is offline Find More Posts by pilot40874
Old Mar 29, 2011, 12:09 AM
Hemet,CA
Joined Jul 2010
Heres my latest flight video of my skybus.
My Dynam Skybus Flight Video with a Surprise! (3 min 31 sec)
Old Mar 29, 2011, 04:36 PM
schroeder4 is offline
Find More Posts by schroeder4
Why Yes I Fly!
schroeder4's Avatar
United States, IA
Joined Oct 2009
My Dc-3
I just went for the normal decal schme but you have to admit this picture is awesome
schroeder4 is offline Find More Posts by schroeder4
Old Mar 29, 2011, 05:24 PM
dhunter19 is offline
Find More Posts by dhunter19
Orlando, FL
Joined Mar 2010
Very nice recovery from that tip stall. I thought it was a goner for sure.
Great job!
dhunter19 is offline Find More Posts by dhunter19
Discussion DC-3 Plans blackwidow18 Australia 2 Jan 17, 2010 08:27 PM
Sold Celectra 4-Port 1S 3.7V 0.3A DC Li-Po Charger by E-flite DuaneV Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 15, 2010 09:02 AM
For Sale Great Planes DC-3 project sunderll Aircraft - Electric - Airplanes (FS/W) 3 Jan 12, 2010 07:34 PM
Sold Celectra 4-Port, 1-Cell, 3.7, 0.3A DC Li-Po Charger, Plus 3 240MAH Single Cell Packs. jafo216 Aircraft - Electric - Batteries & Chargers (FS/W) 9 Jan 01, 2010 11:55 AM
Sold Dynam 5-Channel Receiver/Dynam 3 in 1 Gyro CGReload Aircraft - General - Radio Equipment (FS/W) 3 Aug 18, 2008 04:40 PM
