This thread is privately moderated by nick_75au, who may elect to delete unwanted replies.
Old Feb 06, 2010, 04:29 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Idea
Kitchen rudders
I read Glynn Guest's article on simple control for steam engines posted in the forum, and seeing as I had already built the clamshell part I thought about trying it on them, so I grabbed some PCB material and fitted the servos to it and soldered the outer tube to the PCB copper surface. Made up some copper wire servo linkages(will bend if there's a problem), turns out this was a good idea as getting the buckets to sit correctly was a bit of trial and error.
Moving the servos to the centre improved the operating of the system, both servos in line with the centre may be even better.
the system requires a V-tail mixer to work correctly
here is a mechanical mixer that will work with a simple 2 channel radio
http://www.interq.or.jp/sun/miki-k/vol_2/cont_2.htm
The second picture is how my rudder is assembled, It needs a third tube to act as the bearing for the assembly.
Another thought
I think that with flexible cables the two servos can be remote mounted anywhere. . The angle of the actuator arms does not seem to matter so could be mounted in a very narrow stern.
Link to the original Glynn Guest article, post by steamboatmodel
http://www.rcgroups.com/forums/showp...&postcount=725
nick_75au is offline Find More Posts by nick_75au
Old Apr 17, 2013, 10:40 AM
Laonastes is offline
Find More Posts by Laonastes
Joined Apr 2013
I’m wondering if you perfected the system of using a servo mixer?
I’m completely new to RC and attempting to build a live steam boat with a kitchen rudder. What I’m trying to work out is what I need in terms of radio, receivers and mixers and possibly servos to work the kitchen rudder. Any advice?
Thanks, Rob
Laonastes is offline Find More Posts by Laonastes
Idea Midwest fantail launch + Kitchen rudder peconic steam Scale Boats 91 Oct 28, 2010 10:59 PM
Discussion neoteric hovercraft- thrust vectoring rudders spacephrawg RC Hovercraft 5 Jan 13, 2010 10:39 PM
Sold Rudders, props, shafts, motors fredspak Boats (FS/W) 1 Jan 06, 2010 05:08 PM
Careful! Kitchen Sink Effect btgreen Micro Helis 15 Dec 31, 2009 12:08 PM
Question Offset rudders or not offset rudders... speedchaser Dock Talk 10 Dec 29, 2004 05:12 AM
