Fat Shark FS-HD1 Camera
I figured it'd be better to start a new thread so the reference information could be all on the 1st page and I can control the updates:
You can the product specifications and download unedited raw onboard footage here: http://www.gowiththeshark.com/FPV_HD...0piloting.html Key features are: - 37g (including IRC plug/play cable, 24g without) - Dimensions: 30mm X 90mm (DVR board only, not include lens). - 720p, 60fps - MicroSD tested to 16Gb (theoretically can handle 32Gb) - High quality CMOS imager and Media chip (Texas Instuments) - Stable Linux operating system - 4.6mm interchangeable lens - 90 degree FOV (diagonal) HD image, 70 degree FOV analog out - No automatic power shutdown - Low power (300mA @ 5V) - Downloadable upgrades The camera currently records at 6Mbit/s and outputs NTSC analog out. I will be releasing a downloadable upgrade that will allow the data rate to be selectable (up to 12Mbit/s) and NTSC/PAL AV out selectable. The 6Mbit/s data rate was chosen as current default because I personally don't see any image improvement at the higher rates, but the file sizes become unmanageable. The original intention was to have the camera head connected by a longer ribbon cable for use with a pan tilt. Unfortunately I did not anticipate the amount of RF interferrence that this generates and thus could not be released as such. This is too bad because I actually opened up a really neat pan and tilt tooling that had a rubber friction clutch to save the tilt servo on impacts (see photo). I am still working on RF suppression and if can be acheived, will release a pan/tilt version (but no way to say right now if it will be possible). -Fat Shark |
Romania, Dolj, Craiova
Joined Sep 2007
Shield the ribbon and no more issues.
At least, so was solved for Aiptek. |
Latest blog entry: JRSky - birth of a dream radio
As he states above, there's a copy of a raw file (whole flight) on the web page linked above.
It's very large, and not a super fast pipe so it'll take quite a while to download. The raw file looks very good and there's lots of detail. It's just really bumpy due to the wind. That plane seems to waggle side to side quite a bit too. I've been feeding the raw file to Virtualdub, and seeing what DeShaker can do with it, and so forth. On my new 3.0Ghz Core i7 920, it's still pretty slow re-rendering HD files this big. Some may find that any HD resolution files will thrash their box when trying to do video editing. My old Pentium D DualCore box won't touch it. ian |
Latest blog entry: My 2012 FPV year in Review
Joined Sep 2007
60 fps ? The video looks jumpy...
Daemon between 4:25 and 4:30 there are some kind of glitchs, did you see it?
i wonder how good the image would be with MJPEG codec, grass and trees are blurry in fact, i am sure camera catch much more details that what they are shown in the video due to video compression artifacts, i find MJPEG is one of the best video codecs (fact aside is the big files this codec generates) for example... did you ever see a video with such details ? http://gh1.dark-stone.com/kholi/P1020079.MOV what about a firmware wich record in MJPEG ? or some kind of update utility to select the codec and resolution of the recording video? |
| Thread Tools | |
| New Product Fat Shark RCV922: Redesigned for 2010 | fatshark | Video Piloting (FPV/RPV) | 153 | Dec 04, 2010 08:44 AM |
| Discussion The New FS-HD1 HD Camera | The_Mongrel | Video Piloting (FPV/RPV) | 40 | Feb 08, 2010 06:21 AM |
| Discussion New Fat Shark Camera | Sonic1 | Video Piloting (FPV/RPV) | 17 | Nov 24, 2009 08:01 PM |
| Discussion FS: Fat Shark RCV922 - On Ebay | swwesq | UAV - Unmanned Aerial Vehicles | 0 | Nov 07, 2009 05:12 PM |
| Sold Fat shark goggles and camera | beeker_12 | Cars - Accessories (FS/W) | 1 | Mar 02, 2009 11:38 PM |
