Old Jun 23, 2010, 01:47 AM
flying lx is offline
Find More Posts by flying lx
Joined Dec 2009
i am confuse,what does that for?
flying lx is offline Find More Posts by flying lx
Old Jun 23, 2010, 06:54 AM
Cici528 is offline
Find More Posts by Cici528
Joined Jul 2009
the blue one is beautiful.
Cici528 is offline Find More Posts by Cici528
Old Jun 24, 2010, 01:48 PM
Jammo is offline
Find More Posts by Jammo
London
Joined May 2010
Does anybody know where abouts the CG can be located on this bird?
Jammo is offline Find More Posts by Jammo
Old Jun 24, 2010, 04:16 PM
foamcrazee is offline
Find More Posts by foamcrazee
Joined Nov 2009
see post #38
or
"they show the cg being from the back intake holes
on top to the front of those little vert fins, i have a 15 c 2200 3s
and I put it behind the nose wheel and the cg is at the extreme rear line.
they say the lipo is 150 grams, I have a 3s 2650 30c coming which is 240 grams so we shall see"
.according to him, it seems like at the orange line in the photo to me
foamcrazee is offline Find More Posts by foamcrazee
Old Jun 24, 2010, 06:15 PM
toliver66 is offline
Find More Posts by toliver66
Florida
Joined Feb 2009
65mm back from the leading edge of the wing at the fuse. Which is just a little further back than foamcrazee pic shows but not much. The CG location is shown on the instruction sheet. Seems a little nose heavy at this location though
toliver66 is offline Find More Posts by toliver66
Old Jun 26, 2010, 05:57 AM
Joined Nov 2009
mine :-)
Old Jun 28, 2010, 04:36 AM
Jammo is offline
London
Joined May 2010
I have just finished building my F-18 and I also am having a problem with the CG (nose heavy). What can I do to shift the weight towards the rear of the plane? My lipo is already as far back in the battery tray as it can go.
This CG problem is the only thing holding me back from maidening her.
Old Jun 28, 2010, 07:31 AM
Don Shimoda is offline
Find More Posts by Don Shimoda
will work for stick time
Don Shimoda's Avatar
Austin, TX
Joined Apr 2006
Jammo,
What size battery are you using, and where is the cg with it as far back as it will go? I mistakenly maidened mine very nose-heavy, with the cg at about 40mm, and it still flew ok. Make sure you've got a bit of up-elevator trimmed in for launch.
Don Shimoda is offline Find More Posts by Don Shimoda
Old Jun 28, 2010, 08:28 AM
Jammo is offline
London
Joined May 2010
I'm using a 3S 1300mah battery. I think I may have mounted the battery in the wrong place. There are two compartments. One compartment is in the nose of the plane and the larger compartment is behind the nose wheel and servo. I have placed my battery in the nose compartment and my receiver behind the nose wheel. I think I may need to swap the location of the receiver and lipo.
I have placed red lines where my CG is.
Old Jun 28, 2010, 09:14 AM
zach_dad is offline
Find More Posts by zach_dad
TEXAS
Joined Sep 2005
Try moving the speed controler to behind the motor and fan like on HET planes, I'm using the freewing clone version from Hobbyking makes 2LBs of thrust plus its a little heavier than a normal 4000+kv innrunner with a 2.3 shaft. You never want to add weight in a DF in my opinion.
Hobbyking Freewing Clone #2.3gp (0 min 27 sec)
zach_dad is offline Find More Posts by zach_dad
zach_dad is offline
TEXAS
Joined Sep 2005
Sorry, im using a 2200 mah 30c
Old Jun 28, 2010, 09:26 AM
Jammo is offline
London
Joined May 2010
That's a good idea. I had not thought about moving the esc.
Old Jun 28, 2010, 09:28 AM
zach_dad is offline
TEXAS
Joined Sep 2005
Maybe receiver to
Old Jun 28, 2010, 10:38 AM
Austin, TX
Joined Apr 2006
Jammo,
My receiver is in the front compartment (nose cone) and my battery is in the rear one. Switch yours around and you'll be able to achieve the cg you're looking for.
Don
Old Jun 28, 2010, 10:41 AM
Jammo is offline
London
Joined May 2010
I will do that. Thanks
Discussion Nitro Planes New Airfield 70MM F-16 EDF Jet FlyBoyTha1 Foamy EDFs 29 Sep 24, 2010 01:10 AM
