Old Mar 22, 2010, 10:29 PM
outtacontrol is offline
Find More Posts by outtacontrol
VNE Mach 2
outtacontrol's Avatar
United States, FL, Delray Beach
Joined May 2009
Originally Posted by brati4 View Post
Looks similar to the RCL unit.. Is the rotor plastic or a composite? Have you watt-metered that thing?
It's plastic. The whole setup should be pulling about 33amps and making a little under 500 watts according to the Hobby Lobby website. I haven't put it on a watt meter myself though. It's a good combo
for this jet. It's easy on the packs but still makes good power. When flown correctly, this bird looks just like a real F-18, so I'm loving this jet and power setup so far.
outtacontrol is offline Find More Posts by outtacontrol
Old Mar 22, 2010, 10:49 PM
brati4 is offline
Find More Posts by brati4
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Sounds pretty good for a plastic rotor. Are the rotor blades stiff, the blades I had on my Delta 480 fan are way to flimsy and would cavitate under a load.
I'm really curious to see wattmeter numbers on that, it really performs from your vid.
brati4 is offline Find More Posts by brati4
Old Mar 22, 2010, 10:52 PM
sharam is offline
Find More Posts by sharam
Northern CA
Joined Apr 2003
hi brati4,
The battery is a Hyperion 4S 2600 mah, 35C and it weights just under 10 ounces.
This happens to just counter the greater weight of the RC Lander fan - CG comes out to where it should per the manual.
I will will run the system on a Wattmeter this coming weekend and post my results.
Good luck.
sharam is offline Find More Posts by sharam
Old Mar 22, 2010, 10:57 PM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Originally Posted by sharam View Post
hi brati4,
Good luck.
Thanks, that's amazing that this plane can take a 2600, you must get great flight times. Please post your numbers as I'm curious what a 35c batt will do for this.
Old Mar 25, 2010, 08:39 PM
VNE Mach 2
Joined May 2009
Anyone know when these might be back in stock? I know a few friends that want one, and I'd like to have a backup on standbye just in case....
Old Mar 25, 2010, 08:47 PM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Me too.
Old Mar 29, 2010, 12:43 PM
sharam is offline
Northern CA
Joined Apr 2003
So, the combo runs about 700 watts and 45 amps according to the wattmeter.
I usually land in about 2.5 minutes so I can't say how long the flight lasts. After a few flights with various batt packs, I now think the 2600 batt makes the plane a bit nose heavy. It flies and lands better with the 2200 batt. I will see if I can move the 2600 batt further back.
Old Mar 29, 2010, 12:53 PM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
You should be able to get at least 4-4:30 minutes out of the 2200, depending how much WOT you use. This is what I am easily getting from my 2350s.
Old Mar 29, 2010, 01:14 PM
Ibanezjimjim666 is offline
Find More Posts by Ibanezjimjim666
Shut up and FLY!!!!!
Ibanezjimjim666's Avatar
Philadelphia, PA__ Old people hate guitar solos.....I WIN!
Joined Jan 2005
Me too.
I just bought the 30th anniversary RTF and there are still more available, I will probably repaint mine, but I also have a MaxJet F18E SuperHornet airframe of the same size on the way too
http://www.nitroplanes.com/f18c-64mm-white-rc-jet.html
Ibanezjimjim666 is offline Find More Posts by Ibanezjimjim666
Old Mar 29, 2010, 09:40 PM
VNE Mach 2
Joined May 2009
If you have a wattmeter, I would love to know how many amps the stock setup is pulling, and how many watts it's making. Mine is feeling kinda slow on 4s with my setup.
Old Apr 03, 2010, 11:46 AM
Joined Jan 2005
My F/A-18 arrived yesterday evening. I take it back, I will NOT be repainting this plane, looks even better in person. Probably wont get to flying this weekend being it's Easter so patient preparations must prevail, since this is my first EDF RTF. Gotta look for my wattmeter now. Where did i put that?..........
Old Apr 03, 2010, 02:11 PM
j3tman is offline
Find More Posts by j3tman
Were..is..my..Super..Suit ..
j3tman's Avatar
United States, NE, Papillion
Joined Sep 2009
sweet have any pics?
j3tman is offline Find More Posts by j3tman
Old Apr 03, 2010, 05:43 PM
Joined Jan 2005
Oh yeah I got pics, uploading from camera now, they'll be up in about a 1/2 hour
Old Apr 03, 2010, 06:31 PM
Joined Jan 2005
OK so it took 45 minutes
Completed model ready for balancing, trimming, measuring, wattmetering, etc...
A view from her 6:30 Note her MaxJet F18E parcel buddy.
The canopy hatch was loose so I glued a piece of foam for a snug fit.
Parcel Buddy wants to fly, too.
The P-38 is getting prepped for flight, too
Old Apr 03, 2010, 09:30 PM
j3tman is offline
j3tman's Avatar
Joined Sep 2009
sweet lookin plane cant wait to hear your flight report on it
Discussion Nitro Planes New Airfield 70MM F-16 EDF Jet FlyBoyTha1 Foamy EDFs 29 Sep 24, 2010 01:10 AM
