Old May 22, 2011, 06:15 AM
skrez is offline
Find More Posts by skrez
Joined Dec 2004
Originally Posted by tdab View Post
No issues at on like this on the F18. Today on my second flight, I actually chucked it at over a 45 degree angle (not on purpose) and it just climbed at that same angle with no issues at all. My other launches were straight out with no pitch up or down...
Thanks for the reply. I would be putting the same set-up in mine, 4000+ in 64mm endo fan and 2200 4s .
Frank
skrez is offline Find More Posts by skrez
Old May 26, 2011, 03:45 PM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
Originally Posted by skymaster62 View Post
Had to cut a hatch just behind the canopy to have access to rx and servo wires.
If this plane is anything like the Banana/BlitzRC/Starmax F-18, there's a thin plastic fairing on the underside that's perforated, so a little cover lifts up for Rx and servo wire compartment access. Doesn't this jet have access here as well?
hydro_pyro is offline Find More Posts by hydro_pyro
Old May 26, 2011, 05:56 PM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
I think he meant to say that he cut a hatch to access the receiver, not to route the servo and ESC power wires.
You can see the wiring port in the Blue Angels F-18 shown below:
fredmdbud is offline Find More Posts by fredmdbud
Old May 26, 2011, 09:13 PM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
Oh yeah, that's totally different...
Old Jul 26, 2011, 10:48 PM
the_walrus is offline
Find More Posts by the_walrus
United States, UT, Saratoga Springs
Joined Mar 2010
Will the stock motor handle 4s?
Like can I use a 60amp ESC, a 4s 2200, and be ok with the stock motor & fan?
Justin
the_walrus is offline Find More Posts by the_walrus
Old Jul 26, 2011, 10:52 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
I don't know about the motor, but the duct and fan can handle it.
I believe the stock motor is 4300kV, so I think it should be OK, though it might be better with 3800kV.
Old Jul 26, 2011, 10:55 PM
Joined Mar 2010
Pretty sure the stock motor is 4100kv.
Old Jul 26, 2011, 11:27 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Still, same answer.
Old Jul 26, 2011, 11:42 PM
brati4 is offline
Find More Posts by brati4
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Does a 4s fit in this plane or does it require surgery?
brati4 is offline Find More Posts by brati4
Old Jul 26, 2011, 11:53 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Folks have been able to fit a 4S in this plane. Depending on the battery's dimensions, cutting might not be necessary, though it could get crowded in there (RX, wires). A battery longer than 90mm or wider than 30mm will probably require cutting to get it to sit where the battery compartment is molded; this seems to be the case in recent versions. Other versions didn't have a molded compartment, making larger batteries easier to fit.
Old Jul 27, 2011, 09:35 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I have not tried but my 4S 1800mAh Gens Ace from Hobbypartz is about the same size. I use it on a funjet. I'd have to swap ESC I think if I were to use it.
Melnic is offline Find More Posts by Melnic
Old Jul 27, 2011, 09:42 AM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Can anyone post a pic of the battery area?
Old Jul 27, 2011, 01:43 PM
tdab is offline
Find More Posts by tdab
tracey=Col Frank Fitts
tdab's Avatar
Carolina's
Joined May 2004
bratia, I will take a few when I get home and post them here. Just for reference, I use a 30C 4s2450 and it fits and balances perfect.
I also took off the gear and removed all the plastic that the gear was attached to in order to save weight. I did it very carefully and then cut out 3mm depron to fill the gaps underneath. Then I taped the bottom for a nice skid on the grass. I set up just a tad nose heavy and if flies like a dream.
My setup:
Dons Wicked Plus 4000kv in the stock 64mm EDO1 Fan
Turnigy Trust 55A esc
Turnigy 30C 4s2450
Optima Lite 6ch Rx
27.5 oz auw
Just over 700 watts
Flies great. About 80mph top speed, estimated....
tdab is offline Find More Posts by tdab
Old Jul 28, 2011, 12:19 PM
Joined Mar 2010
tdab that's what I'm going for. Will be using a 60amp ESC and 4s 2200 batts. I'll see how long the stock motor can handle it. lol Should be ok as long as I take it easy. This plane flys so stable, just needs to be faster.
Would like to see the pics of your battery location, etc when you get them posted.
Justin
Old Aug 02, 2011, 09:52 PM
tdab is offline
tdab's Avatar
Carolina's
Joined May 2004
Pics below.....You can see where the front LG bulkhead of foam was removed so the top 1/3 of the 4s2450 will fit in perfectly. I molded another foam part inside the airframe that holds the other side of lipo tight and still allows air-flow around it
Discussion Nitro Planes New Airfield 70MM F-16 EDF Jet FlyBoyTha1 Foamy EDFs 29 Sep 24, 2010 01:10 AM
