Old Sep 23, 2001, 02:21 AM
procrastination inc is offline
Find More Posts by procrastination inc
Adelaide,Australia
Joined Apr 2001
DIY 200A speed controller kit
Wadaya reckon?
200A R/C MODEL SPEED CONTROLLER KIT: This kit is designed to work direct from a standard 1-2ms pulse from a radio control receiver to control an electric motor in one direction only. Features include a brake. Kit includes PCB and all on-board components including 5 high power mosfets and a small (26 x 64 x 38mm) case.
PUBLISHED: Silicon Chip Magazine
KIT PRICE: (K152) $35 (AUD)
Pic here:
http://www.oatleyelectronics.com/kits/k152.html
procrastination inc is offline Find More Posts by procrastination inc
Old Sep 23, 2001, 03:16 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
For 200A read somewhere around 25-30A if you're lucky. I suspect the rating is based on the maximum MOSFET rating (like many car controllers). These in turn are based on the MOSFET being on a large force-cooled heatsink and kept to a temp of 25C. These have no heatsinks .
I guess you could put 200A through it for about 1/100th of a second before the smoke comes out. The real giveaway is the size of the wires in the picture. Can you imagine 200A through those weedy wires ?
Steve
steve lewin is offline Find More Posts by steve lewin
Old Sep 24, 2001, 07:03 AM
Adelaide,Australia
Joined Apr 2001
Thanks.
so 25-30A is OK for an s600.
Is $18(US) too much for a big heavy 25A DIY speed control with no BEC?
Old Sep 24, 2001, 01:00 PM
N. Staffs, UK
Joined Jan 1997
The price is not bad, the MOSFETs could easily cost close to that at retail prices. If you like electronic kits (plenty of fairly fiddly soldering) and want to to give a try it why not just go for it ?
You could test it to see how much current it will actually stand or you could tell us exactly what type the MOSFETs turn out to be and someone could probably give you a good idea of what it will do. I'd guess it would easily handle the average S600.
Have you read the article it references ? That probably contains some more realistic details.
Steve
Old Sep 25, 2001, 02:49 AM
Adelaide,Australia
Joined Apr 2001
>>Have you read the article it references ? That probably contains some more realistic details. <<
I looked for it on the web, no show. I'll have to see if the library has that back issue.
Old Sep 25, 2001, 11:17 AM
MrBungle is offline
Find More Posts by MrBungle
rebmeM roineS
MrBungle's Avatar
Rockingham, Perth - Western Australia
Joined Apr 2001
This kit is marketed by Oatley Electronics as a 200A controller, but Silicon Chip ran the article as a 50A continuous controller(tested):
Silicon Chip - May 2000 - "50A Model Motor Speed Controller - With Brakes", Page 78
50A continuous rating, 1 x MPT2955 (Brake) + 5 x IRFZ44 (Power)
Voltage drop at 50A = 0.28v (worked using IRFZ44 datasheet, SC magazine claims 0.24v)
At 50A this controller has to dissipate approx. 14 Watts of heat, quite a lot without heatsinks.
MrBungle is offline Find More Posts by MrBungle
Old Sep 26, 2001, 01:50 AM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
Sounds pretty good, that ought to be plenty even for hot buggy motors right?
Could always add a small heatsink or some bent up aluminium. Stick the metal ends of the transistors out into the airflow.
Trizza is offline Find More Posts by Trizza
Old Sep 26, 2001, 04:25 AM
N. Staffs, UK
Joined Jan 1997
That sounds pretty reasonable. I'm not sure about 50A continuous unless the FETs are in a really good airflow. I usually think of IRFZ44s as safe at about 8A with no heatsink but I've never really tested them to destruction
However it should certainly take anything you could comfortably use with a 540/550/600 size motor. Why not try it and let us know how you get on ?
Steve
Old Sep 26, 2001, 11:40 AM
MrBungle is offline
rebmeM roineS
MrBungle's Avatar
Joined Apr 2001
procrastination inc,
If you would like to read up some more on this controller before purchasing the kit, send me an email with your address and I will send you a photocopy of the construction article from SC mag.
I would scan it and send via email, but I dont have a scanner
For Sale NIB T - Rex 450 ccpm kit + motor + speed controller greg367 Aircraft - Electric - Helis (FS/W) 0 Oct 03, 2005 09:10 AM
Great Planes C-10 speed controller hkowalczyk Beginner Training Area (Aircraft-Electric) 5 Jul 29, 2001 02:50 AM
GWS 2amp speed controller - no. of servos? Matthew Allen Parkflyers 7 Jul 13, 2001 10:21 AM
FMA Mini 5 Speed Controller. quintav02 Parkflyers 3 Jun 22, 2001 01:49 PM
Speed controller for terry 2fish Electric Plane Talk 6 Jun 21, 2001 09:51 AM
