Old Feb 05, 2010, 12:11 AM
nick3 is offline
Find More Posts by nick3
USA, CA, Parlier
Joined Jan 2010
US Aircore Trainer build questions
I just got my first plane- a US Aircore Trainer kit . From what I've read it is going to weigh a lot, Does anyone have any suggestions for ways to keep the weight down? epoxy or CA vs contact cement
also
http://homepages.sover.net/~badmojo/pages/aircore.html
this guy seems to think that the wing should be built without washout. The directions say some washout is beneficial. What do you guys think?
Thanks a lot!
Nick
nick3 is offline Find More Posts by nick3
Old Feb 05, 2010, 11:57 AM
dked41 is offline
Find More Posts by dked41
windy Wisconsin
Joined Feb 2009
Some washout is beneficial, the Aircore I built, was put together as instructed and has held up well. It is now on it's second owner and still is in good shape. The contact cement adds weight, but not enough to to make much difference on a plane this size. The corroplast is heavy to start with. Just a thought, but if Jeff had some washout maybe he would have less crashes. The only thing I recommend is make sure the engine is at least a ball bearing .45 or equivalent. I tried an OS .40 LA and it was very poor performance wise, a Magnum .46 worked very well.
dked41
dked41 is offline Find More Posts by dked41
Old Feb 05, 2010, 05:55 PM
nick3 is offline
USA, CA, Parlier
Joined Jan 2010
Ok thanks! I have a magnum .52 4 stroke that I am planning to use in it. Does anyone have any suggestions on making the plane any lighter? Is removing material from the fuselage doublers a bad idea?
Sold US Aircore 40 Trainer Dan777 Aircraft - Fuel - Airplanes (FS/W) 1 Jul 24, 2007 12:50 PM
Question US AirCore 40 Trainer-good 1st plane? mofish62 Beginner Training Area (Fuel) 1 Jul 14, 2006 08:52 PM
FS: US Aircore Trainer .40-Size N925WB Aircraft - Fuel - Airplanes (FS/W) 0 Jan 14, 2005 01:36 PM
RTF US Aircore Trainer AIRon Keefer Aircraft - Fuel - Airplanes (FS/W) 8 May 19, 2003 04:22 PM
