Old May 19, 2003, 08:25 AM
RadioControl is offline
Find More Posts by RadioControl
Singapore
Joined Mar 2003
Hangar 9 Aresti 40 ARF electric conversion?
Hi Guys,
Wondering, how can I convert the Aresti 40 ARF into an electric plane? What battery, motor, etc do you guys recommend? Also, how much would I have to spend to convert it into an electric? Thanks a lot!
RadioControl is offline Find More Posts by RadioControl
Old May 19, 2003, 09:41 AM
rcman is offline
Find More Posts by rcman
rcman's Avatar
Logan, Utah, United States
Joined May 2002
I know someone as done this conv.
I would do a search on Aresti and see what comes up
This is what I would use, I think you would be very happy
Hacker B50 13S 5.2:1 $259.95 , Master 70-3P Opto $139.00, 14x3000 $7.95 per cell ($111.00 per pack), 14x10 $7.95
Cooling fins $15.00 Prop adapter $30.00
So I think you would run around $500.00 to $600.00 for all the stuff you would need, but remember Hacker is on the expensive side of brushless system but work very well there is other systems that don't cost as much maybe someone else will chim in and give you some other ideas
If I remember right the whole plane after the conv. is about 94-100oz done
I hope that helps
Good luck
David
rcman is offline Find More Posts by rcman
Old May 19, 2003, 05:26 PM
Dave Wenzlick / Slickraft is offline
Find More Posts by Dave Wenzlick / Slickraft
(Batteries not included.)
Dave Wenzlick / Slickraft's Avatar
Mesa AZ
Joined Jun 2001
Aresti conversion link
This page top right corner is Frank Wallace's plane. I have flown it many times. Excellent plane. There's a video online too.
Dave W.
Dave Wenzlick / Slickraft is offline Find More Posts by Dave Wenzlick / Slickraft
Old May 20, 2003, 03:12 AM
Singapore
Joined Mar 2003
Thanx, what other cheaper motor and battery can I use?
Old May 20, 2003, 08:51 AM
byoung is online now
Find More Posts by byoung
byoung's Avatar
O'Fallon, MO USA
Joined Dec 1999
I have not done this conversion myself, but I think that a Jeti 45/3 ($159 or around $110 used), Jeti JES 40-3P Opto Controller ($ 98.90) on 16 cells ($4.50x16=$72) would also fly it quite well. Not as much raw thrust as the Hacker, but still very respectable. The 45/3 will turn an APC 10x7E prop around 10,000 RPM.
Brad
byoung is online now Find More Posts by byoung
Old May 20, 2003, 06:29 PM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Here's a mega 22/30/3 option, about $400
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old May 20, 2003, 06:31 PM
Ed Lyerly's Avatar
Joined Apr 2001
Here's an AXI 4120/18 outrunner option......about $350.
Ed
Old May 20, 2003, 06:36 PM
Ed Lyerly's Avatar
Joined Apr 2001
I see from your profile you are 14 years old. It is not my intention to discourage you ....but.... I hope you have R/C flying experience with similar models as this is definitely not a beginners model.
Ed
Old May 20, 2003, 11:41 PM
kmashima is offline
Find More Posts by kmashima
kmashima's Avatar
San Jose, California, United States
Joined Feb 2002
Jeti 45-3 -- I flew this exact configuration with 16 cells on my Aresti. It was OK sport flying but not "real" pattern performance. It just doesn't have enough thrust to pull through strong vertical moves. Compared to a Hacker 13S; 6.7, it's kinda sad.
-- Kyle
kmashima is offline Find More Posts by kmashima
Old May 21, 2003, 02:42 AM
Singapore
Joined Mar 2003
Yep, I fly gas planes, aerobatic and I am thinking of coverting to electric because it is more covenient. BTW, is the AXI 4120/18 outrunner the one that doesn't need a gearbox?
Old May 21, 2003, 07:31 AM
Ed Lyerly's Avatar
Joined Apr 2001
Good, then you should have few problems
Yes
Ed
Old May 21, 2003, 07:34 AM
Singapore
Joined Mar 2003
hi Ed, any idea which website sells that motor?
Old May 21, 2003, 07:56 AM
Ed Lyerly's Avatar
Joined Apr 2001
Try Nipon Dave,
His website shows the smaller AXI motors, maybe he carries these too.
http://www.aircraft-world.com/products.asp?id=16]
Ed
Old May 21, 2003, 08:00 AM
Singapore
Joined Mar 2003
dropped him a mail, other than the motor, what else do i need?
Old May 21, 2003, 08:12 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
You'll need speed controller capable of handling the amps and the number of cells you plan on running. You'll also need a battery pack (at least one but several helps) and battery charger.
GregG is offline Find More Posts by GregG
Hangar 9 Aresti 40 glowfuel Fuel Plane Talk 2 Dec 11, 2004 05:27 AM
Horizon Hangar 9 Twist 40 ARF AMCross Product Announcements 0 Apr 30, 2004 08:09 PM
Hangar 9 Aresti 40 The_Widowmaker Fuel Plane Talk 5 Feb 06, 2004 01:02 PM
F.S. Hangar 9 Funtana S40 3D. electric conversion with extras Gerald Aircraft - Electric - Airplanes (FS/W) 4 Aug 12, 2003 09:52 PM
Sig Rascal-40 ARF Electric Conversion Donald Duck Sport Planes 63 Mar 26, 2003 02:03 PM
