Old May 19, 2003, 08:23 AM
hubevolution is offline
Find More Posts by hubevolution
Joined Apr 2003
Ripmax .40 trainer
Is it possible to equip a Ripmax Trainer .40 to fly with an electric motor ?
If yes could you specifiy what would I need to make it work ? What disadvantages would come out ?
hubevolution is offline Find More Posts by hubevolution
Old May 20, 2003, 02:44 AM
Joined Apr 2003
opsss anyone can help ?
Old May 20, 2003, 03:27 AM
Stuey is offline
Find More Posts by Stuey
Aylesbury,UK
Joined Apr 2000
There are literally 10's of different combos you can use for this, i don't think you will need a setup equivalent to a .40 engine as these trainers always seem overpowered to me. It as always depends on how much you want to spend. You could probably use a AXI 2820/12 on 10-14 cells to give enough power, that motor can fly .40 sized models.
Stuey is offline Find More Posts by Stuey
Old May 20, 2003, 08:47 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
You might get more responces to your question if you supply more information that'll make it easier for us to help you pick powerplant configurations?
What is the weight of the bare airframe? What is the wing span and the area of the wing?
GregG is offline Find More Posts by GregG
Old May 21, 2003, 01:54 AM
Joined Apr 2003
Greg you are right here they come the specs directly from the Ripmax site (Ripmax Trainer .40 ):
Lightweight ARTF Trainer
Attractive high visibility colour scheme
Highly prefabricated for ease of assembly
Kit Contents:
Tough pre-covered fuselage
Lightweight pre-covered built up wing and tail surfaces
Moulded fuel tank
Moulded spinner
Preformed undercarriage and wheels
Full set of control hardware
Comprehensive full colour step by step instructions - building your ARTF has got easier!
SPECIFICATION:
Wing Span: 1550mm (61")
Weight: 2200g
Engine: .38~.48
Build Level: ARTF
Skill Level: Beginner
Required to complete (Not included):
4~6 Ch radio equipment
.38~.48 2-Stroke engine
Propeller
I would like to know which electric engine can I use and which ESC and servos and prop ... eheh yep everything
Thanks so much
Old May 26, 2003, 07:45 AM
Joined Apr 2003
still anyone can help ? thanks
Old May 26, 2003, 10:12 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Sorry for the long delay, this one got away from me. I'm assuming that you will be using the stock landing gear and I like to use larger props so we won't go too far off in that direction. I'll plan on an 11" prop diameter. Running a few combinations through Motocalc with that size prop direct drive I came to the conclusion that a Mega 22/30/4 on 12 cell and an 11 X 7 prop should pull ~39 amps. This should have plenty of power to get the plane moving well and also have enough headroom to back considerably off the throttle for those super long training flights at slow speeds. You may want to try some of the 1950FAUP cells as they're very light weight yet can handle that amp draw.
This is just one combo that I believe will work. Perhaps we'll get a couple more recommendations from other modelers. Hope this helps and let us know what you decide on and how it eventually flies.
Old May 26, 2003, 11:01 AM
farnboro flyer is offline
Find More Posts by farnboro flyer
farnboro flyer's Avatar
Farnborough, Hampshire, England.
Joined Jan 2002
I have just dug out a copy of the UK mag.Model Flyer(Jan.2003)
They have done a conversion on the Ripmax Trainer 30!
They fitted a 12x8APC E prop, and 10 3000mAH cells, with a wing area of 465sq.ins, they used a standard 600 7.2 volt mated to 3:1 open type gear box.
This, they say flew it fine................that might help you for the bigger model, but if you can afford brushless, then go with that.
Ian
farnboro flyer is offline Find More Posts by farnboro flyer
Old May 28, 2003, 08:59 AM
Joined Apr 2003
Thanks guys mmm I have to say that Trainer .30 conversion is maybe to prefer to .40 also because will fit better in my car LOL
I have to look at some prices and decide which config would be less expensive.
Anyway thanks so much and I will let you know every detail as soon as I get news LOL
Discussion need advice for my ripmax nova 40 trainer greyx551 Beginner Training Area (Fuel) 1 Jun 18, 2006 08:43 PM
Electrify AirCore 40 Trainer? babblefish Sport Planes 5 Feb 10, 2003 10:05 AM
For Sales: .40 Trainer (New) Engine and Radio installed!!!! Captain Carlton Aircraft - Fuel - Airplanes (FS/W) 0 Aug 06, 2002 10:57 PM
.40 Trainer + Engine for sale / Trade Danythemany Aircraft - Fuel - Airplanes (FS/W) 0 Jun 24, 2002 05:25 PM
.40 Trainer Recommendation Question Ghostbear Fuel Plane Talk 4 Jun 12, 2002 07:03 PM
