Old Feb 04, 2010, 07:49 AM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Idea
E-Z Airplane Stand
While killing some time yesterday at Home Depot (which usually gets me in trouble) I came across this Rigid Flip-top stand and figured it would make an ideal field stand.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I used some 3/4 pvc and fittings to make up a craddle to go on it for my Sabre. Other planes can have their own craddle to suit with the same mounting method. I drilled a pair of 1-1/4" dia holes in the stand to accept the bottom of a 'tee'. I may extend them or run a pin through the bottom for added security, but at the moment it's a nice snug fit.
The cross brace that the fuse is sitting on is raised up off the deck to allow for cycling of the gear and doors, as well as installing and removing battery packs.
The stand looks like it could tip over, but it's very sturdy and the height is adjustable. If you lower it a little you could even push the center into the ground.
Not bad for around $40 and an hour of time.
strictlyscale is offline Find More Posts by strictlyscale
Old Feb 04, 2010, 12:59 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
nice. might have to go and check those out. hope they are available here in the great white north. LOL.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Feb 04, 2010, 11:00 PM
old p47 is offline
Find More Posts by old p47
Joined Nov 2002
that is a great tip I was thinking of getting another midwest but that looks perfect
old p47 is offline Find More Posts by old p47
Airplane Starting stand/table plans ??? artmonster Fuel Plane Talk 6 Mar 03, 2008 07:43 AM
Discussion Picoo Z charger as stand alone LiPo charger? AleG DIY Electronics 6 Nov 07, 2007 09:11 AM
Du-Bro EZ Connector Alternative E-Z E/Z 121 Microbatman 3D Flying 7 Jan 02, 2006 11:00 AM
Rant e-z bee vs. e-z bee II bcd11 Fuel Plane Talk 0 Apr 11, 2005 05:00 PM
S.P.A.D.(Simple Plywood Airplane Dock) Stand for SPADS Bolter SPAD - Simple Plastic Airplane Designs 4 Feb 08, 2005 11:50 AM
