Old Feb 04, 2010, 12:22 AM
mahmoodmusaddi is offline
Find More Posts by mahmoodmusaddi
Radio gives you wings ;)!!
mahmoodmusaddi's Avatar
Joined Jun 2008
how can i set up delta/elevons in my flying wing type aircraft... from JR XF 622
heloo guys
brother is in desperate need of help here lol.
i just lost my radio for flying wing aircraft and very upset atm.
how ever i have a TX and RX set of radio 'JR XF 622' computer radio . i have used it in patternship and 3D 46 size nitro planes. not any electric how ever. i need to use it in my electric flying wing and set up its delta/elevons. so that same control surface works as ailerons aswell. hope u understand what i am looking for.
so plzzz can any 1 tel me how to change the setting of the radio to do this...??
mahmoodmusaddi is offline Find More Posts by mahmoodmusaddi
Old Feb 04, 2010, 03:23 AM
scousethief is online now
Find More Posts by scousethief
scousethief's Avatar
United Kingdom, England, Redcar
Joined Jan 2006
I cant really help but if mixing is not available on your radio just buy a V-Tail mixer , i use them on my wing and my stryker.
http://www.jrradios.com/ProdInfo/Fil...219-manual.pdf
page 20
scousethief is online now Find More Posts by scousethief
Old Feb 06, 2010, 12:28 AM
Joined Jun 2008
page 20
hey thnx bro. i already came accross this manual link. how ever its for xf 631 , not for xf 622 but i tried it. it has done it but the only problem i am having is that since i use mode 2 in my JR radio. after doing this every thing is right except for the ailerons. when i move rudder stick ailerons move. when i move ailerons stick , ailerons dont work. rest throttle and elevator are fine.
hope u can help me or sum 1 can .
Old Feb 06, 2010, 06:04 AM
Joined Jan 2006
I dont have that radio but i will try and find an answer for you , can you not just swap the servo location at the receiver ? eg switch the leads around ?
Old Feb 07, 2010, 11:56 AM
Joined Jun 2008
yes i tried tht. reversing the lead of elevator and rudder. but it didnt work. hmm
Old Feb 07, 2010, 11:59 AM
Joined Jun 2008
hmm nice . yes i will get a v-tail mixer.. any idea about the cost tho?
Old Feb 07, 2010, 12:19 PM
Joined Jan 2006
V tail mixer are around 3 delivered from ebay
http://cgi.ebay.co.uk/Hobbywing-VTAI...item1c0c1d74ef
very cheap , the same one i use
when i move rudder stick ailerons move. when i move ailerons stick , ailerons dont work : plug the aileron servo into the rudder socket ?
http://www.horizonhobby.com/ProdInfo...622-manual.pdf
Old Feb 07, 2010, 11:18 PM
Joined Jun 2008
thnx for teh info scoutchief... so if i use v-tail mixer. i have to insert it in the aileron slot in teh reciever and it will work for both elevators and ailerons? is that it .. and then i put the throttle in teh third channel..
Old Feb 08, 2010, 06:25 AM
Joined Jan 2006
Throttle in throttle channel.
The mixer comes with 2 leads 1 for aileron and one for elevator .
The other end of the mixer has pins 1 set of 3 for each servo.
If movement is reversed just swap the servo pins. Really easy
Old Feb 09, 2010, 02:19 AM
Joined Jun 2008
thnx bro. i just ordered two of the mixers. and will use it.
btw my plane is a GOFLYKITE. u mite already have an idea. v cool and light kitle like thing . with carbon rods and carbon paper sheets.
Discussion how to set my shocks up in stampede xl5 kzpl14 Off-road Cars 3 Oct 27, 2009 05:55 PM
Discussion How can I embed the transmitter into my flying wing? tekrunner FPV Talk 2 Sep 03, 2009 05:00 PM
Discussion question on radio set up for delta wing elevons QinMD Electric Plane Talk 4 Jul 12, 2008 10:20 PM
Discussion Can you help me set up my HL LYNX XF EDF? SwissBoy Foamy EDFs 14 Feb 19, 2008 05:03 PM
zagi set up with a JR 622 pval3 Flying Wings 7 Jun 19, 2005 11:20 PM
