Old Feb 03, 2010, 08:26 PM
kyle7119 is offline
Find More Posts by kyle7119
United States, IA, Cedar Rapids
Joined Aug 2009
FPV landings
So, I would like to get some helpful facts on how to land while flying FPV. Here is my situation:
I have an Easy Star with the EZ Glider wings, and I feel like I need a football field or two to land it. So far, I have only flown in fields where I have this kind of room. However, I would like to be able to go to an open area surrounded by trees. The trick that I would like to learn is how to make my approach above the trees and then drop down really quickly and put it on the ground.
Also, how fast are you guys going when you land. Do you stall it out, or do you fly it onto the ground?
Videos would be wonderful.
kyle7119 is offline Find More Posts by kyle7119
Old Feb 03, 2010, 08:31 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
Practice.
Kmart is offline Find More Posts by Kmart
Old Feb 03, 2010, 08:34 PM
kyle7119 is offline
Joined Aug 2009
So, from an altitude of 50 ft (height of tree?), how much space does it take you to land?
Old Feb 03, 2010, 08:35 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
maybe 60 feet? I usually come in slow right over the tree tops, then dive down to almost ground level. Then, I just glide along until it sits down.
Old Feb 03, 2010, 08:37 PM
kyle7119 is offline
Joined Aug 2009
My plane has really sloppy controls at slow speeds. Too high of a stall speed.
Old Feb 03, 2010, 08:38 PM
merkzu is offline
Find More Posts by merkzu
Minnesota
Joined Sep 2009
I fly out of a small grass area outside my house sometimes and descend in a tight circle pattern until I'm on the ground. It might be pretty hard to do with easyglider wings unless you have the ailerons hooked up.
merkzu is offline Find More Posts by merkzu
Old Feb 03, 2010, 08:39 PM
Dirt Brakes is offline
Find More Posts by Dirt Brakes
Nice, but watch this... oops.
Northern Ohio
Joined Jan 2010
can you dial in flaperons on your radio?
bill
Dirt Brakes is offline Find More Posts by Dirt Brakes
Old Feb 03, 2010, 08:41 PM
kyle7119 is offline
Joined Aug 2009
I have ailerons. I don't know about flaperons. I'll have to check. Can the Futaba 7C do flaperons?
Old Feb 03, 2010, 08:49 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
As long as you have two channels for the ailerons you can do flaperons or spoilerons. Both down or both up while still giving you aileron control. Some planes or pilots work better one way some the other.
Also, it sometimes helps to mix in elevator trim along with either flaperon or spoileron.
I've never used either but I've contemplated it on occasion so I thought I'd throw in my two cents to confuse the issue.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Feb 03, 2010, 09:08 PM
kyle7119 is offline
Joined Aug 2009
Two channels for ailerons!?
Old Feb 03, 2010, 09:35 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Why not just land it hot and level? I can plant almost any airplane right where I want it in FPV mode. I actually require less runway. I just aim the nose for a spot about 100 feet away from where I want to touchdown and fly right for that, then level off.
Here's what you do: Bring your plane in fast with the nose down at minimal throttle to maintain maneuverability. You want to come in at an angle between 10 and 25 degrees, so it can be a fairly steep drop. More angle means less throttle. Aim your nose about 100 feet infront of your intended touchdown point. When you get close to the ground shut down your throttle and begin to level off. Do not flare as this will result in a tip stall, but just let the plane land fast but level. An EZ Star will certainly do fine this way.
My best landings are always coming in fast with power on right before the plane touches down.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 03, 2010, 09:42 PM
kyle7119 is offline
Joined Aug 2009
-Alex
Interesting, I was doing the exact opposite of that: shallow approach angle, really slow approach speed, and a flare right at the end. I will definitely try this new method.
Old Feb 03, 2010, 09:47 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Just my opinion....
While there are "standard" accepted practices of landing aircraft, I think FPV pilots need to find the method that works best for each individual and the plane they are flying.
Now I don't claim to have mastered FPV landings....
But here are a couple of vids with landings at the end, of 2 completely different aircraft.
The landings are "similar" yet the method to achieve each landing was different.
....and certainly weather/wind conditions play a part.
As someone above said.... Practice... get to know your aircraft and what it is capable of in different conditions.
If possible, practice touch and goes where you have lots of room, and try to shorten the landing each time, before trying to set down in a tight area.
This first vid I had lots of room to line up...
The second vid was landing in a fairly tight location, I did have an approach along the road, but not obvious is the fence I had to stay above.
Oh, and it was WITH the wind....
Slow Stick FPV Over 1000 ft. altitude, April 19 09 (4 min 2 sec)
Radical RC Wright Stick FPV flight #2 (5 min 20 sec)
galaxiex is offline Find More Posts by galaxiex
Old Feb 03, 2010, 09:53 PM
Crist Rigotti is online now
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Kyle,
Check your pm.
Crist Rigotti is online now Find More Posts by Crist Rigotti
Old Feb 03, 2010, 09:55 PM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
When landing on a "spot" in a tight space, I fly relatively fast and into the ground (a bush is better...lol.).
Here's what I did when I was learning a couple of years ago...
Originally Posted by scrtsqrl View Post
[B]
LANDINGS
I like to fly from small fields. To do that safely, I have to land precisely and accurately.
I have to control two parameters: Glideslope and Line-up. Flying the SAME glideslope and the SAME line up will put the plane on the SAME spot in the LZ.
Here's my wag at trying to make that happen:
I use my carry box as a landing aid. I stand the cover up around 3 paces from the box itself laying flat. If I am on glide slope and line-up, I should see a "T" as I fly in.
I also found that the carry box is highly visible in the terrain, and marks the landing aimpoint very well, especially when I'm flying into the sun, when the ground is totally washed out...
The proceedure goes:
1. Mark on top of an Initial Approach Point. I use a church, because it is easily distinguishable from the air.
2. Find the dot & go to it. This gives me a rough heading.
3. Make out the "T". This gives me more precise glideslope and line-up.
4. Maintain the "T" until the LZ is made.
5. Wave off and bring it arround if I get too far out of parameters.
It seems to work. Using this, I've been able to put my plane into the purple bush around 7 out of 10 times. I'm sure that number will get better. The true test will be when I try it out in some other location.
Check this out:
http://www.youtube.com/watch?v=8UwYjzHgvPY
Night Landings
Same procedures I use in daylight. The difference are four lights...Red flasher on the back "nav aid"...White Flasher on the forward "nav aid" for glideslope and line up...an orage light (plastic pumpkin left over from halloween) to mark the forward edge of the bush...and a flashlight shined by my son at the airplane so that I know not to hit him (and me, 'cause I'm standing next to him).
So long as I am on line-up, the flashing light just becomes visible once I am on glideslope. I keep it barely visible on top of the middle light...I stay on glideslope. Very easy and reliable.
scrtsqrl is offline Find More Posts by scrtsqrl
Video Unusual takeoffs and landings Axbri Electric Plane Talk 0 Dec 15, 2009 01:24 PM
Discussion F5D landings: spoilerons or flaperons? plainguy High Performance 5 Dec 07, 2009 12:41 AM
Help! OS LA 15 Helping me get good at deadstick landings Aber Engines 15 Sep 28, 2009 01:42 PM
Discussion FPV VIDEO's HERE! Misc..Landings Crashes Etc.. QUIKSILVER FPV Talk 32 Aug 02, 2008 05:04 AM
