Old May 19, 2003, 03:00 AM
Freeze
Freeze
Guest
n/a Posts
Is it possible to use a single conv RX with a dual conv TX?
As long as they are using the same Frequency/Channel? I'm putting together
an order for a cheap electric park flyer and came across an inexpensive
single conversion Hitec receiver that I'd like to use but I have a dual
conversion Tx
Thanks!!!.
Tor Aanonsen
Tor Aanonsen
Guest
n/a Posts
Re: Is it possible to use a single conv RX with a dual conv TX?
"Freeze" <goingbald_2000(at)yahoo(dot)com> wrote in message
news:cZ2dnTpn8N40EVqjXTWcrg@comcast.com...
> conversion Tx
There is no such thing as a dual conversion TX.
Freeze
Freeze
Guest
n/a Posts
"Tor Aanonsen" <airbaticNO@SPAM.online.no> wrote in message
news:1053265886.320485@gurney...
together
> > conversion Tx
You're right!!! I wrongly assumed that a dual conversion receiver would
require a dual conversion transmitter. When I checked this post it made me
look up my transmitter and that is when I realized my error. Having said
that, are there any major downsides to using a single conversion receiver?
Any personal experiences? Where I live there is no one flying R/C within
about 40 miles of my home so interference should not be an issue from other
R/C'ers.
Thanks.
JR
JR
Guest
n/a Posts
One of our guys tried the single conversion Hitec Rx and found it's range
extremely limited. He lost two planes before calling Hitec and then
switching to one of their Electron Rx's. A lot depends on your definition of
a park flyer. If you are going to fly the very small ones, in close, the
single conversion will probably do fine. If you are going to fly one with a
little more power, a little further away, go for the dual conversion. A call
to Hitec may be in order.
Take a look at the prices at Servo City as well, if price is a concern.
Great service and prices. www.servocity.com .
JR
news:cpydnQnS9NufAlqjXTWcrg@comcast.com...
> together
inexpensive
dual
> > > conversion Tx
would
me
other
> R/C'ers.
> Thanks.
Ed Cregger
Ed Cregger
Guest
n/a Posts
There is no such thing as a dual conversion transmitter.
Ed Cregger
together
> conversion Tx
> Thanks!!!.
aeropal
aeropal
Guest
n/a Posts
pdf receiver article:
http://www.bergent.net/SC-DC.pdf
Abel Pranger
Abel Pranger
Guest
n/a Posts
"Freeze" <goingbald_2000(at)yahoo(dot)com> wrote in message news:<cpydnQnS9NufAlqjXTWcrg@comcast.com>...
<snip>
> R/C'ers.
You can have fine performance from a single conversion Rx, if you get
the right one. The Hitec Feather isn't it. The GWS is a lot better
Rx and only costs $28 with crystal from Radical R/C or Balsa Products.
Abel
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
The problem with flying single conversion receivers in the US is the
adjacent channel, and inter-channel interference. Pagers and all sorts of
other nasties "live" between the channels. Any of these can swamp a SC
receiver. In the UK, it isn't quite so bad.
> together
inexpensive
dual
> > > conversion Tx
would
me
other
> R/C'ers.
> Thanks.
Douglas Kaip
Douglas Kaip
Guest
n/a Posts
I have flown single conversion almost exclusively for several years on my
helicopters and have not had any problems.
Now let me clarify that statement.
I have been using JR 9 and 10 channel PCM single conversion receivers and a
6 channel ( I think ) FM receiver ( on a plane ). JR 10SXII and 8103s as
TXs.
On the FM receiver I know that I have been hit, once for sure and possibly
another time. The first time I found out that my muffler had come loose and
was causing an intermittent metal to metal connection. The other time I
never did find a cause, but, there were no other flyers around.
With my PCM receivers I do not think I have been hit at all, even though it
is harder to tell. I have never noticed my servos hold or my throttle go to
IDLE ( failsafe ) so I assume that I have not been hit.
I have flown adjacent channel many times with no problems. The other pilots
were using JR and Futaba equipment. I should add that their equipment was
mid line or top of the line equipment and probably less than 5 years old.
I also have a JR 9 channel ( I think ) dual conversion receiver and, of
course, it works fine.
So what am I saying? I guess that I believe that single conversion can work
just fine, however, I would also strongly suggest that you learn from
others on this NG that have more experience, especially with the receivers
that you mentioned.
Douglas Kaip
Six_O'Clock_High
Six_O'Clock_High
Guest
n/a Posts
The real issue is not just how close another R/C flyer is, but how much
other radiated energy there is in your area. If you live close to a
television transmitter, you will be operating in what a single conversion RX
will see as a 'hostile environment'. However, if there are not much in the
way of heavy electronics users around you (no factories, not microwave links
and the like) , you may get away with it out of doors. The general rule of
thumb for single conversion RX's that *I* follow is only for indoor stuff.
YMMV
Jim Branaum
AMA 1428
Six_O'clock_High
Target_Lock@Guns.com
> together
inexpensive
dual
> > > conversion Tx
would
me
other
> R/C'ers.
> Thanks.
James D Jones
James D Jones
Guest
n/a Posts
>>> putting
> together
>>> inexpensive single conversion Hitec receiver that I'd like to use
>>> but I have a dual conversion Tx
> would require a dual conversion transmitter. When I checked this
> post it made me look up my transmitter and that is when I realized my
> error. Having said that, are there any major downsides to using a
> single conversion receiver? Any personal experiences? Where I live
> there is no one flying R/C within about 40 miles of my home so
> interference should not be an issue from other R/C'ers.
Hitec makes great receivers. they also make the one that you are
considering. Unfortunately, it isn't a very good choice. Range is
extremely limited. If you can stand the extra weight, get either the
555 or the new Electron. If not, the GWS single-conversion micro
receivers that I have been using have fine range for use in a park
flyer. They don't reject interference from other transmitters very
well, but that shouldn't be an issue in your case.
Jim - AMA 501383
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
With RC, the interference you need t worry about are high power paging
systems and industrial RC (cranes, etc).
"Six_O'Clock_High" <Target_Lock@Guns.com> wrote in message
news:RBSxa.4465$Io.374447@newsread2.prod.itd.earth link.net...
RX
the
links
of
> YMMV
> Jim Branaum
> AMA 1428
> Six_O'clock_High
> > together
> inexpensive
> dual
> > > > conversion Tx
> would
> me
receiver?
within
> other
> > R/C'ers.
> > Thanks.
Freeze
Freeze
Guest
n/a Posts
Thanks all. Something to think about for sure. The pager frequency issue I
did not consider. I live about 300 yards from a pager/cellular tower. I'll
definitely have to reconsider my choice of receiver.
Old May 19, 2003, 03:01 AM
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
Cell towers shouldn't cause any trouble. Cell systems operate around
800mHz. Pager interference is usually seen as intermittent, violent hits.
news:OTWdnQJ3w8NcslWjXTWcqQ@comcast.com...
I
I'll
Old May 20, 2003, 03:00 AM
astroflyer
astroflyer
Guest
n/a Posts
On Sun, 18 May 2003 21:12:15 -0400, "Freeze"
Well, I fly regularly at our field with the GWS receivers in my park
flyers. There are TWO cell towers within sight on the hill over
yonder...no more than a mile away. NO interference of any kind,
except when we have five or six planes in the air when I see some hits
presumably from the other transmitters. and this doesn't happen all
the time, only with certain other club members in the air, and only
when it's crowded. Only downside of the towers is that my better half
can reach out and touch me when ever she feels like it <VBG>
Ditto for the other club sites where I've flown...problems in a
crowded environment, but never when only one or two are flying.
cheers
Papa Sharptooth
Bouncing about the living room, my three year old grandson declares
he's "a kangaroo".
"If you're a Kangaroo, what is Grampie", I ask.
His reply: "you a dinosaur"
Question Hitec 5 channel single conversion RX-Hitec optic 6 TX redtail Radios 6 Aug 29, 2006 01:43 PM
Is it possible to use a heading hold gyro with a tail motor heli? Foamaholic Micro Helis 14 Oct 05, 2005 08:43 AM
Way to use a 2 channel Rx with Electric??? DPN Power Systems 11 Jul 29, 2004 01:31 PM
FS: Futaba r127df rx WITH Skysport 4 tx stockguru Aircraft - Electric - Airplanes (FS/W) 1 Oct 28, 2003 10:12 AM
Can I use the 7th channel on my RX with a 6 channel Tx Doc Watson Power Systems 2 Feb 22, 2002 11:34 PM
