Old May 19, 2003, 01:46 AM
Fall_Ryan is offline
Find More Posts by Fall_Ryan
No cash=time for ideas!
Fall_Ryan's Avatar
Boeing Field, Seattle
Joined Mar 2003
Anyone Converted the Sureflight 1/2A Cub?
I'm curious as to if anyone has converted it to Electric. Also, Do you think that it would make a good EPS-300C powered plane? I'm looking at it as my next plane sooo... (Click text for Website)
Fall_Ryan is offline Find More Posts by Fall_Ryan
Old May 19, 2003, 01:36 PM
Scratchbuilder is offline
Find More Posts by Scratchbuilder
Wayne's World - Illinois
Joined May 2002
...some folks have done it to some of those SF planes....
http://www.rcgroups.com/forums/showt...threadid=18473
Scratchbuilder is offline Find More Posts by Scratchbuilder
Old May 19, 2003, 01:50 PM
ChuckHHill is offline
Find More Posts by ChuckHHill
Concord, CA, USA
Joined Dec 2000
I have seen two converted. Both a long time ago. The first had a can O-5 in it and flew pretty well. This was very early in my electric experience and it inspired me to try one myself. I tried a gearbox, and believing the label, I foolishly tried to use a 7.2volt speed 400 and 6x600mah AA nicad. It was way underpowered, but did actually fly without the landing gear attached. If I had used a 6volt S400 and 7 or 8 cells, I think it would have worked well.
Chuck Hill
ChuckHHill is offline Find More Posts by ChuckHHill
Old May 19, 2003, 02:55 PM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
The original kit is or was designed for a Cox 049 motor. The hardware is heavy.
I built one bone stock with a speed 400 using 7 and 8 500AR packs and a 6x4 prop in direct drive.
I built a 2nd one that received lighter tail feathers, lighter opush rods and lighter wheels and gear. On this one I also tried a geared 400. It does not really need the gearing however.
This leads me to think that it will indeed fly with a geared 300
Since the suplied hardware is bogus, try to order a spare wing and fuse. This is the el cheapo way to go.
Good luck
poobs is offline Find More Posts by poobs
Old May 19, 2003, 06:27 PM
Fall_Ryan's Avatar
Joined Mar 2003
Thanks poobs... I might just do that, If I do, I'll be sure to post it!
Old May 19, 2003, 07:08 PM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Here's a pic of one of mine before its inevitable demise
Old May 19, 2003, 07:09 PM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
And the spares...
Old May 19, 2003, 08:51 PM
Fall_Ryan's Avatar
Joined Mar 2003
Ahhh, I remember that one.. Didn't know it was your's... Or that it was the .049 version. Cool! Although I'm thinking now that I could just carve a cub out of Pink Foam.
Old May 19, 2003, 09:30 PM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
The one in the pic had a speed 400 direct.
You probably can make one out of foam.
I made a fuse out of pink foam for a Cub 1/2 a wing. It looked like a Cessna Cub.
The spare fuse and wing came to $25.00 when I bought them a couple of years ago. Hard to go wrong.
Herr 1/2a cub motor combo? sloppytypist Power Systems 0 Nov 21, 2003 02:01 AM
Herr 1/2a Cub! Gotta love laser cut! Martin Hunter Parkflyers 63 Jun 27, 2002 01:35 AM
Herr 1/2A Piper J-3 Cub (My love for the Cub) genovia Parkflyers 30 Jun 10, 2002 10:18 AM
Herr 1/2A Piper Cub in need of assistance genovia Electric Plane Talk 21 Jun 08, 2002 04:34 AM
Converting a Sureflite 1/2a Cub to electric ARCHER7153 Foamies (Kits) 2 May 21, 2001 01:05 AM
