Old May 18, 2003, 08:35 PM
citabria is offline
Find More Posts by citabria
Under tension
citabria's Avatar
Johnstown, Colorado
Joined May 2002
mixing epoxy with water
I need to make a repair on a foam model tonight to patch a crack that's pretty tough to get to. I don't have any Probond but I do remember hearing that you can mix epoxy with water to lessen its thickness. I searched the group for info on this trick but couldn't find anything. Does anyone do this? What will it do to my hardening time and will it have any effect on the strength of the bond?
Scott
citabria is offline Find More Posts by citabria
Old May 18, 2003, 08:46 PM
dru is offline
dru
Find More Posts by dru
dru
San Diego Calif.
Joined Jul 2002
Don't know about water but denatured alcohol works very well. You can also try to heat it up with a heat gun before you put it on the crack.
Dru.
dru is offline Find More Posts by dru
Old May 18, 2003, 09:51 PM
fwilly is offline
Find More Posts by fwilly
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
Mine got pretty hot in my truck today and was pretty thin.
fwilly is offline Find More Posts by fwilly
Old May 18, 2003, 10:33 PM
raythomas is offline
Find More Posts by raythomas
KZ RIDER
raythomas's Avatar
United States, MS, Tupelo
Joined Nov 2001
When I get to the end of my epoxy I will stick each bottle in the microwave for about 8 to 10 seconds. Don't leave it unattended while doing this because the epoxy will get VERY HOT VERY QUICKLY!!! The good thing about this is that it makes it very thin, not like water but close and you can get every last drop of epoxy out of the bottle. The bad thing about doing this is that it causes the epoxy to harden very quickly. The heat speeds up the catalyst process. I would suggest using 20 or 30 minute epoxy for this. 5 min might not be long enough when heated. Ray
P.S. Don't let your wife catch you using the microwave for this! Don't ask me how I know!!
raythomas is offline Find More Posts by raythomas
Old May 18, 2003, 10:36 PM
mescal1 is offline
Find More Posts by mescal1
mescal1's Avatar
Maui, HI
Joined Sep 2001
epoxy cure's by a chemical reaction not evaporation like elmers
or ambroid. i wouldn't try mixing it with water but i have to admit
that i've never tried it either. so, now that i'm curious i'll have to
check it out someday. i also have to admit that i'm surprised
that alcohol works, i'll have to try that out as well. either way,
i'd try it out on scraps before your airplane. the heat gun sounds
like the best way to go for now (i know that works!)
mike
mescal1 is offline Find More Posts by mescal1
Old May 18, 2003, 10:39 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
I wouldn't put epoxy in an oven that you intend to use for food. Put the epoxy in warm water for a few minutes to achieve the same thing or warm it with your heat gun after mixing.
In this case, I would use odorless CA because you can be sure it will penetrate the crack. Otherwise, put the normal epoxy on the crack and then hit it with the heat gun. Ordinarily, you can easily make it flow into the crack but you also have to worry about not melting the foam.
If you have some laminating epoxy, its much thinner to begin with.
Rick.
rpage53 is offline Find More Posts by rpage53
Old May 19, 2003, 06:27 AM
Flint is offline
Find More Posts by Flint
Flint's Avatar
Australia, ACT, Canberra
Joined May 2001
I use Metholated Spirits (Metho) to thin Epoxy, works great and is very cheap and easy to obtain.
Cheers
Flint is offline Find More Posts by Flint
Old May 19, 2003, 09:46 AM
DR. JOY is offline
Find More Posts by DR. JOY
Stay thirsty my friends.
DR. JOY's Avatar
United States, SC, Greenville
Joined Feb 2003
A good source of methanol is gas line antifreeze. It is what I use to thin epoxy. I would not use Isoprpopyl alcohol as most is cut with water. I have had poor results with it. Heating also works. I myself would probably use foam safe thin CA.
DR. JOY is offline Find More Posts by DR. JOY
Old May 19, 2003, 01:16 PM
raptor22 is offline
Find More Posts by raptor22
Striving to Rip the Bring
raptor22's Avatar
San Diego, socal, USA, North America, Earth, Solar System, the Orion arm, Milky way, Universe
Joined Apr 2003
yeah, i just use zap-o oderless CA. its better than epoxy, anyway. its lighter, too.
--Alex
raptor22 is offline Find More Posts by raptor22
Old May 20, 2003, 10:07 PM
Mr B.... is offline
Find More Posts by Mr B....
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
You can make epoxy thinner by preheating at 150 degrees for ten min. before you ad the hardener. After mixing your working time will be less and will get hotter. DO NOT ADD WATER!
Mr. Brady
AMA 276833
LSF 7247
www.mmglidertech.com
Mr B.... is offline Find More Posts by Mr B....
Glassing with water-based products Herb The Builders Workshop 24 Jun 15, 2006 07:47 PM
The Perfect Free Material For Mixing Epoxy On !!! *Hurricane039* The Builders Workshop 23 Feb 14, 2005 04:12 PM
Does a Hacker mix with water? SkyPyro Electric Plane Talk 6 Jul 09, 2003 09:48 AM
Mixing the alerons with the elevator! Using a Flash5x Help!!! onfireindoorfly Fuel Plane Talk 2 Aug 15, 2002 03:01 PM
Mixing Epoxy aginzu Beginner Training Area (Aircraft-Electric) 11 Sep 18, 2001 11:56 PM
