Old Feb 02, 2010, 04:33 AM
vleisie is offline
Find More Posts by vleisie
boerie roll
vleisie's Avatar
Johannesburg, South Africa
Joined Apr 2007
Help!
SA Depron frustration
Hi guys,
I do a lot of building with 6mm Depron, but it is very difficult to get a reliable supplier in SA. Anybody have any alternatives (supliers or materials).
Marcel
vleisie is offline Find More Posts by vleisie
Old Apr 01, 2010, 05:28 AM
Christie is offline
Find More Posts by Christie
Fly 4 Fun
Christie's Avatar
Potchefstroom, South Africa
Joined May 2002
Hi Marcel,
I was under the impression that MadModels always have lots of 6mm Depron? Have you found a supplier?
Christie
www.flyfun.co.za
Christie is offline Find More Posts by Christie
Old Apr 01, 2010, 05:35 AM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Hi Christie,
I've started using isoboard hot wire cut into 6mm sheets as an alternative.
Marcel
Old Apr 08, 2010, 02:47 PM
Terry Pieters is offline
Find More Posts by Terry Pieters
Cape Town, South Africa
Joined May 2008
Hi, because of the high price of Depron and it not being generally available, I have tried using ceiling tiles (bought from Builder Warehouse) 500x500mm about3.5mm thick,8 sheets (2sqm about R120) What I did was lamin either 2 thicknesses or 3 depending on use, have built a Divinity (see Foam Scratchbuilds) and a profile. Both yet to be maidened.
Terry Pieters is offline Find More Posts by Terry Pieters
Old Apr 08, 2010, 11:39 PM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Thanks Terry.
Old Feb 17, 2011, 03:53 AM
SA/RCFlyer is offline
Find More Posts by SA/RCFlyer
SA/RCFlyer's Avatar
Joined Jan 2009
Hi Vleisie
I have heard that Wi Fly will be stocking the stuff soon.
SA/RCFlyer is offline Find More Posts by SA/RCFlyer
Old May 10, 2011, 12:42 PM
HennieT is offline
Find More Posts by HennieT
HennieT's Avatar
South Africa, LP, Mookgopong
Joined May 2011
Hi
I buy my Depron from RC Pilot 0119793504.
In some cases I also use Iso board.
Cheers
Hennie
A fellow Depron plane lover!
HennieT is offline Find More Posts by HennieT
Old Jul 06, 2011, 04:11 PM
rchobbysa is offline
Find More Posts by rchobbysa
Joined Jul 2011
As an alternative building material you could also try a product called corroplast which is available from Maizey plastics. I am seriously considering building a plane from this stuff as it is available in sheet thicknesses from 2mm up to 12mm.
rchobbysa is offline Find More Posts by rchobbysa
Old Jul 18, 2011, 04:24 AM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
Correx/Coroplast is extremely heavy. It is really only good for combat sloapies in my opinion. I'm not absolutely sure but I think 3mm correx in SA can weigh from 500g to 750g per square meter. 3mm Depron weighs about 100g per square meter. I bought some 2mm Correx from Maizey's a few years ago and it weighed more than the 3mm that people bought overseas, also it was extremely flimsy.
Depron is becoming easier to get now. A friend bought me some Depron Aero from Micton's in Somerset West (they get it from Mad Models in JHB) and the price is the same as if I had to buy R1000 worth of it from the USA...
MegaTesla is offline Find More Posts by MegaTesla
Old Apr 14, 2012, 01:04 PM
Wickets is offline
Find More Posts by Wickets
Joined Apr 2012
Wespack in Alberton now stocks Isoboard without grooves at R46 for a 25mm board and R89 for a 50mm board. (900mm x 600mm).
Wickets is offline Find More Posts by Wickets
Old Apr 15, 2012, 12:59 PM
Jab69 is offline
Find More Posts by Jab69
Jab69's Avatar
South Africa, GP, Alberton
Joined Sep 2009
Isoboard
You can get the isoboard cheaper from Isoboard in Verwoerdburg.I think there price is roond about R80 for size 600mmx1800mmx40mm.
Jab69 is offline Find More Posts by Jab69
Old Apr 20, 2012, 12:49 AM
Wickets is offline
Joined Apr 2012
Where in Verwoerdburg? Just completed demongti's Edge 540 with isoboard, and now I want to do your Thrush. I assume you don't mind?
Old Apr 20, 2012, 12:51 AM
Wickets is offline
Joined Apr 2012
Sorry, I meant Vleisie's Thrush.
Old Apr 21, 2012, 01:39 PM
georgy is offline
Find More Posts by georgy
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
Been using foam-board for my 2 profile jets... 3mm not too hard to get but 6mm...
Last 6mm sheet was R144.00 & 3mm R80.00 (think sheets are 1050x720... or something)
Any-one know where to get this at a better price?
George
georgy is offline Find More Posts by georgy
Old Apr 22, 2012, 01:07 AM
Wickets is offline
Joined Apr 2012
Hi Georgy, why dont you cut your sheets yourself? I use 10mm Aluminium angles on a piece of chipboard, so I can cut 10mm sheets. If I now want 6mm, I just use a piece of 4mm glass under the foam as a spacer. If you consider "foam board" to be expanded polystyrene, you can try Automa in Isando, they have two seperate warehouses full of the stuff, as well as some EPP, but the prices you quoted makes me think its Depron. In place of Depron, use Isoboard.
Discussion frustration locating good engines to fly with? dutchman1950 Control Line 50 Jan 23, 2010 06:39 PM
Discussion Novus frustration and new helicopter advice... steveko23 Micro Helis 4 Jan 20, 2010 04:39 PM
Help! JR 9303 + AR6100e + G110 gyro = programming frustration Mike_Then Electric Heli Talk 13 Dec 28, 2009 08:37 AM
Help! Frustration! Twister773 Batteries and Chargers 41 Sep 24, 2009 09:08 AM
Discussion Sukhoi NICE TRY--NOT HAPPY--FRUSTRATION!!!! flybob1 Scratchbuilt Indoor and Micro Models 20 Sep 06, 2009 09:49 AM
