Closed Thread
Old May 18, 2003, 06:30 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
AZ-Shrike Bluecor Fan Fold Pylon Racer - Plans & Construction
**** !!!! NEW VIDEO ! CLICK ON LINK BELOW !!!! ****
As a small token of my appreciation for the incredible amount of information. expertise, and support that I have received from all of you, I humbly offer the following for your building and flying pleasure.
Presenting: The AZ-Shrike!
The AZ-Shrike has been designed for Bluecor or other thin sheet foam construction. A speed 400 or comparable motor should be used and I have found the 5.5x4.5 APC-E prop to be a good match. The AZ-Shrike flies great on 7 or 8 cells (600AE or better). The All-Up-Weight (AUW) is 14.5 oz to 17 oz, depending on your battery. The wingspan is 30". The airfoil is symmetrical and there is no dihedral in the wing. There is no rudder, just ailerons and elevator.
The AZ-Shrike is a thrill to fly. Highly aerobatic and capable of just about anything you can throw at her. But she particularly loves the 400 foot dive bombs and high-speed passes!
AZ-Shrike video by SkyPyro:
http://www.skypyro.rchomepage.com/html/AZ-Shrike.wmv
Standard Speed 400. APC-E 5.5x4.5 prop. 8x950 KAN battery.
AZ_Astro is offline Find More Posts by AZ_Astro
Old May 18, 2003, 06:31 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
Here she is after taping up the fuselage.
Old May 18, 2003, 06:32 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
Proof that she's all Bluecor! [Or can be, anyway]
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
Plans:
A zipped copy of the full .jpg file can be downloaded from page 18 of this thread.
A CAD version of the plans is on page 11 of this thread. I haven't checked it for accuracy or completeness so print out this plan as well, at least for the notes.
Old May 18, 2003, 06:35 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
Here's where we're heading:
Old May 18, 2003, 06:38 PM
ProBro 1634
MGoddard's Avatar
Enterprise, Alabama
Joined Feb 2003
AWESOME !
Thanks AZ - !
MGoddard is offline Find More Posts by MGoddard
Old May 18, 2003, 06:40 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
Building and Flying the AZ-Shrike
Construction:
Constructing the AZ-Shrike is absurdly simple and should only take a few evenings. That it takes so long is due to the fact that the Probond has to dry!
The steps that will be followed are:
1) Preparation
2) Transferring the plans to the Bluecor and cutting the pieces
3) Fuse Construction
4) Wing Construction
5) Tail Construction
6) Motor Mount
7) Putting it all together
8) Finishing touches
9) Flight testing
Old May 18, 2003, 06:43 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
Step 1: Preparation
You will need:
Parts List:
* 1 sheet Bluecor Fan Fold Foam (but you need most of a folded edge for the wing)
* 1 plywood S400 motor mount (1/16" thickness or slightly larger)
* 1 4 mm carbon fiber spar (24" length)
* 1 length of 1/16" music wire
* 1 Dubro Control Horns (These come in packs of two)
* 1 Dubro Kwik-Links for Torque Rod Couplers/Connectors
* 2 Dubro E/Z connectors sets (you need 3 connectors)
* 1 8" length brass or aluminum tubing for 1/16" music wire torque rods
* 2 or 3 rolls of colored packing tape (can substitute Ultracote or other covering material for the wing, but packing tape is recommended for fuse)
* 1 sheet (36") 3/32" balsa for horiz and vertical stabs (you can use Bluecor to substitute if you're a purist!)
* 1 balsa 1" aileron stock
* 1 6V Speed 400 motor (stock)
* 2 S400 Mounting Bolts
* 1 Xenor diode for S400 motor
* 3 Capacitors for S400 motor
* 1 10-20 amp speed controller (Great Planes 10 recommended)
* 1 Receiver (Hitec 555/Berg 5 or comparable recommended)
* 2 servos (HS-55 or stronger recommended)
Tools:
* 1 bottle Elmers Probond Polyurethane Glue
* 1 bottle of tap water (to be mixed with the Probond)
* 5 minute Epoxy
* Thin CA if you're using the balsa tail feathers
* Popsicle Sticks (for stirring and applying the glues)
* 20 or more 2"x2" scrap Bluecor foam pieces, used for mixing the glues and then discarded
* 1 razor/Xacto/Box Cutter Knife
* 1 24 inch ruler
* 1 1 inch flat metal file
* 1 pizza cutter (rolling blade)
* 1 12 inch ruler
* 10-20 hobby clamps and/or rubber bands
* Soldering iron and solder
* Dremel tool
* Circular and flat files/rasps
Old May 18, 2003, 06:48 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
Step 2: Transferring the plans to the Bluecor and cutting the pieces
I pencil in a center line first on the Bluecor, then draw my dimensions from there. I like to use the dots on the Bluecor to line up my ruler for horiz or vert cuts.
Here I've started to draw the lines for Fuse #1.
ProBro 1634
MGoddard's Avatar
Enterprise, Alabama
Joined Feb 2003
Oh, what motor are you planning on using ? How is the performance ?
uhh, posted same time nevermind
read my mind
Old May 18, 2003, 06:50 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
Cutting the Fuse #1 piece.
Remember, the plans are NOT TO SCALE. You need to measure the dimensions onto your Bluecor directly.
Old May 18, 2003, 06:52 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
Cutting Fuse #2:
Old May 18, 2003, 06:53 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
Be sure to use a sharp hobby knife, and keep it sharp while cutting. Otherwise you'll get snags on the bottom of the Bluecor while cutting.
You want to avoid this.
Old May 18, 2003, 06:54 PM
DLG Fan
AZ_Astro's Avatar
Tempe, AZ
Joined Nov 2002
That's it for now. More to follow in a day or so.
Old May 18, 2003, 06:55 PM
Genesisyy's Avatar
Nashville, TN
Joined Oct 2002
Thanks AZ_ Astro!
Genesisyy is offline Find More Posts by Genesisyy
Closed Thread
Bluecor Fan-fold P-47 Ready to Fly! AZ_Astro Foamies (Kits) 54 May 27, 2006 05:19 PM
Bluecor Fan-fold SE-5A Ready to Fly! AZ_Astro Foamies (Kits) 33 Apr 27, 2004 01:42 AM
Bluecor Fan-Fold Foam F-16 Construction Underway AZ_Astro Foamies (Kits) 165 Dec 06, 2003 01:29 AM
Bluecor Fan Fold in Phoenix Arizona? MikeDPP Foamies (Kits) 15 Feb 28, 2003 10:40 PM
Desperate! Is there any BlueCor Fan Fold Foam in Arizona? AeroMojo Foamies (Kits) 3 Aug 02, 2002 12:20 PM
