Old May 18, 2003, 03:47 PM
Krona is offline
Find More Posts by Krona
E-Heli
Krona's Avatar
Palm Bay FL
Joined Mar 2003
Cheap Logo 10 Parts ,Blade, Tail
I just wanted to let everyone know that I have tried these parts on my Logo 10 and they works just as good, if not better than original.
The Blades are 515mm Heli-Max ($17.99)
And the Tail parts are from Kyosho Concept 30 and Nexus 30 ($8.99)
With the 515mm blades my Logo flies just like the original 500mm blades but I get about 30sec longer hover and still have the same power.
The Tail parts are a little heavier than original, but much stronger. The tail fin will not flex like the original fin does. The helicopter flies the same with the new tail parts but I will probably not be able to break it again, they are very strong.
Anyway, I just wanted to let everyone know where to find some cheap replacement parts for the Logo. If I brake my Landing Bows I will try the Kyosho, they should work.
Heli-Max Blades
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXM045
Kyosho Tail
White (no picture)
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXW043
Blue (picture)
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXRB47
I also use Kyosho Tail Rotor Blades Nexus/Concept and they work just like the original tail rotor blades, but they are ($4.99)
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXW050
Krona is offline Find More Posts by Krona
Old May 18, 2003, 06:25 PM
Hovertime is offline
Find More Posts by Hovertime
Always right
Hovertime's Avatar
Chicago
Joined Feb 2003
Thanks for the info, Krona!
Hovertime is offline Find More Posts by Hovertime
Old May 18, 2003, 06:55 PM
Krona is offline
E-Heli
Krona's Avatar
Palm Bay FL
Joined Mar 2003
Here's a picture of the tail mounted.
This tail fits better than original, I think. Because it's harder so you can tighten it better and it's about 1/4 inch longer. So the tail blades won't hit the ground as easy.
Old May 18, 2003, 09:47 PM
GKurt is offline
Find More Posts by GKurt
Chicago
Joined May 2002
Valuable info!
Finding aftermarket Logo parts is tough.
Greg
GKurt is offline Find More Posts by GKurt
Old Jun 09, 2003, 04:09 PM
squelchF18 is offline
Find More Posts by squelchF18
www.dynamoelectrics.com
squelchF18's Avatar
United States, TN, Collierville
Joined Sep 2001
How about tail rotor blades? Have you found any cheap replacements?
Chuck
squelchF18 is offline Find More Posts by squelchF18
Old Jun 09, 2003, 05:21 PM
Krona is offline
E-Heli
Krona's Avatar
Palm Bay FL
Joined Mar 2003
Yes Here
Old Jun 09, 2003, 07:21 PM
squelchF18's Avatar
Joined Sep 2001
How about Pinion gears? I am looking for a 12 or 11T pinion to try with my Mega Motor. Are these 48 pitch gears? Do you know of a cheap supplier to fit a 5mm shaft?
Chuck
Old Jun 10, 2003, 02:23 PM
Krona is offline
E-Heli
Krona's Avatar
Palm Bay FL
Joined Mar 2003
I don't know of any other pinion that will work.
I think the original Pich is 0.5 (Metric) or 64 (English).
Can anyone confirm this?
So any pinion with that pich should work.
FS- Logo 10 parts and Hitec 225's Terkan Aircraft - Electric - Airplanes (FS/W) 11 Apr 14, 2003 05:29 PM
Logo 10 Parts...Where Hivoltage Electric Heli Talk 7 Sep 23, 2002 11:59 PM
Where can I buy Logo 10 parts rcman Electric Heli Talk 3 Jul 25, 2002 04:09 PM
Logo 10 - Main Blade Options Phoenix-IT Electric Heli Talk 1 Mar 27, 2002 06:49 PM
Logo 10 Servo & Tail Fin Question... Phoenix-IT Electric Heli Talk 7 Mar 08, 2002 03:20 PM
