Old May 18, 2003, 03:29 AM
ClayH is offline
Find More Posts by ClayH
ClayH's Avatar
92840
Joined Mar 2003
How to get consistent power on the bench?
I am trying to do some speed 400 motor tuning and was wondering what I can use as an alternative to battery packs to run a speed 400 motor at a constant 6-7 volts. The packs don't keep the same voltage for long enough to test different motors with the same voltage input. I have a desktop power supply that powers my chargers. Ideas?
ClayH is offline Find More Posts by ClayH
Old May 18, 2003, 06:46 AM
Gary Retterbush is offline
Find More Posts by Gary Retterbush
I "plant" trees (balsa)
Gary Retterbush's Avatar
Eisenschmitt, Germany
Joined Jan 2002
Running motors for long periods on the bench is a great way to ruin them. Better to do the testing in the air.
To answer the question; certainly one can use a power supply as long as the voltage is correct and the supply can hack the amps.
Gary Retterbush is offline Find More Posts by Gary Retterbush
Old May 18, 2003, 07:58 AM
KatManDEW is offline
Find More Posts by KatManDEW
FASST flyer
KatManDEW's Avatar
USA, OH, Newark
Joined Sep 2001
Power supply... I have a 35 amp adjustable voltage supply. Extremely handy. I don't run motors for a long time, but it's impossible to get accurate reproducable measurements for good test comparisons using battery packs. The power supply can also be used for breaking in brushed motors and powering battery chargers.
KatManDEW is offline Find More Posts by KatManDEW
Old May 18, 2003, 12:07 PM
SoarNeck is offline
Find More Posts by SoarNeck
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Cheap alternative - a large 6V gellcell. That's what I use.
SoarNeck is offline Find More Posts by SoarNeck
Old May 18, 2003, 01:04 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I tested a bunch of S400s (and a couple of S480s) a while back. My method was to set the tacho, ammeter, and whatt meter up with a camcorder pointing at them. Then video a 20-30 second run with each motor on an 8x2400 pack (I used two packs and alternated them, same prop each time ... moved from motor to motor).
Then play back the tape, pick a voltage that occurs say 15 secs into each run, freeze frame at that point, and you can write down the amps and rpm at exactly the same voltage for each motor
Bill Glover is offline Find More Posts by Bill Glover
Old May 18, 2003, 08:51 PM
ClayH is offline
ClayH's Avatar
92840
Joined Mar 2003
Thanks to all...
for the responses. I think the video is a great idea as I'm always hurridly writing information trying to beat the voltage drop. A 6 volt gel cell should work as well.
How to get a 1060 prop on a 350c gearbox ? rcmarty Parkflyers 13 Jul 11, 2004 03:49 PM
How to get XP to log on automatically? Andy W Life, The Universe, and Politics 8 Apr 02, 2004 09:07 PM
How to get the best finish on a foam model bluespier Foamies (Kits) 12 Jul 14, 2003 03:11 PM
How to get more power from Aveox1415/4? Janusz Jawien Power Systems 7 Jan 29, 2003 07:14 AM
