Old Jan 30, 2010, 09:55 AM
lord chris is offline
Find More Posts by lord chris
RAFMAA
United Kingdom, Marham Airfield
Joined Jun 2005
Ripmax Magic Vee
Hi there. I was in the model shop today buying repair stuff for my bf109 that piled in today! I spotted high on the top shelf this little racing vee!
http://www.ripmax.com/item.asp?itemi...ry=050-010-010
when i got back i found the only video online of it and thought id like 1. turns out i had the wrong size prop for the plane so another trip later......... i brought 1
looks nippy on its 180 but was thinking lipo/brushless bullit!
any1 have any idea on ideal motor/esc and prop? im new to the boat thing!
lord chris is offline Find More Posts by lord chris
Old Jan 30, 2010, 10:40 AM
pompebled is online now
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Chris,
Be aware of the fact, that small hulls are easily overpowered; on the video the hull already starts to porpoise with the stock motor, with more power this will get worse up to undrivable, unless you alter the entire set-up to match the power installed.
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Old Jan 30, 2010, 11:26 AM
RAFMAA
Joined Jun 2005
right ok, points noted. wont be going crazy with this then. maybe a a nice lipo setup to increase the speed a little and the run times. this thing comes with a cheapo plastic transmitter so thats def going!
the stock battery is 7.2v 260mah
Old Jan 30, 2010, 02:23 PM
RAFMAA
Joined Jun 2005
are there any better 180 brushed motors out there?
Old Jan 30, 2010, 02:32 PM
nick30head is offline
Find More Posts by nick30head
nick 30
nick30head's Avatar
Joined May 2009
not really, although you could try graupner, its a german company, as your english, try cornwallmodelboats.co.uk they have some, how about trying the equivilent size lipo to the nimh batt you have now
nick30head is offline Find More Posts by nick30head
Old Jan 30, 2010, 02:38 PM
RAFMAA
Joined Jun 2005
surely something like this
http://www.fast-lad.co.uk/store/prod...oducts_id=2261
Can a 180 heli motor be much different?
and yeah i was going to look for a little lipo similar to this.
7.4V 500mah ? (.2v bigger cant hurt can it?) the stock esc is 5A
Old Jan 30, 2010, 03:49 PM
Sneek, Netherlands.
Joined May 2004
Hi Chris,
The heli motor has replaceable brushes, that's a good thing as far as lifespan is concerned.
But, most likely it will rev way too high for a boat in direct drive, as most heli's work with gears on both the main and rear blades.
Sadly that info isn't available in the link.
If it has between 25.000 and 33.000 rpm under load, it would be an option, much more will just result in foam, not speed...
Regards, Jan.
Old Jan 30, 2010, 05:41 PM
RAFMAA
Joined Jun 2005
iv looked all over the place for the rpm of this motor no luck.
any ideas where i can find props this small too? smallest iv seen are like 35mm
Old Jan 30, 2010, 09:46 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Small beryllium props:
27mm - http://www.offshoreelectrics.com/pro...?prod=oct-x427
27mm - http://www.funrcboats.com/ProductInf...oductid=OCX427
30mm - http://www.funrcboats.com/ProductInf...oductid=OCX430
scorpion1 is offline Find More Posts by scorpion1
Old Jan 31, 2010, 03:39 AM
Sneek, Netherlands.
Joined May 2004
Hi Chris,
This is the smallest Graupner two blade:
http://shop.graupner.de/webuerp/servlet/AI?ARTN=2318.29
And this the smallest three blade from Graupner:
http://shop.graupner.de/webuerp/servlet/AI?ARTN=2299.30
But, you don't want to go the high revs, small/tiny prop way, the efficiency of the small props is on the edge, along with the (lack of) efficiency of those small motors.
As an example:
http://shop.graupner.de/webuerp/servlet/AI?ARTN=6394
This motor converts only 55% of the electric energy you put in, into motion, the rest is lost in heat and friction...
If it physically fits, one of the brushless motors, suggested by Scorpion would seem a better upgrade to me.
Keep in mind you'll need to watercool the motor 'properly', as the stock solution is rediculously inefficient for a brushless motor.
If the motor you select, doesn't come with a watercooling fitted, like this one (which, if it fits, will be major overkill):
http://www.hobbycity.com/hobbycity/s...WaterCooled%29
you'll need something like this:
http://www.swanghobby.com/hobbywing-...1-pr-1723.html
Regards, Jan.
Old Jan 31, 2010, 07:37 AM
RAFMAA
Joined Jun 2005
i got hold of a cheap xtreme se 180 motor. going to see what that does first.
this little boat does have water cooling but it looks like a poor attempt.
after the motor upgrade il see how it does, then il get a 7.4v lipo
am i right in thinking mah will give me better run times? so say a 500mah pack will last longer than my 260mah pack. it wont add speed as thats only voltage.
Old Jan 31, 2010, 07:56 AM
Sneek, Netherlands.
Joined May 2004
Hi Chris,
Yes, you are correct.
Keep us posted on your 'speeding up attempts'.
Regards, Jan.
Old Jan 31, 2010, 10:00 AM
RAFMAA
Joined Jun 2005
Cheers. yeah i will do
I took it to a small bit of stream near me today.
Here is what i think:
1. Mine is not 20kph.
2. My motor shaft isnt the straightest thing around.
3. The layout with the Nicad makes the boat sit lopsided!
4. because of the above it turns sharper to the left.
5. After 2mins i had quite a bit of water onboard.
6. My servo rod has a bit of backlash in 1 direction.
What i hope will happen.
1. find a straight shaft.
2 the lipo will be lighter and thinner so i can balance the boat.
3. lay a thin layer of silicone at suspect leaks.
4. bend the control rod better to eliminate backlash.
5. find a better prop.
6. fit the xtreme se180 motor.
The stream was pretty tight and after 3 seconds i had to rescue the boat.
Is there any rules on balancing a boat? should i place more upfront it it porpoises?
would a long motor shaft out the back help in any way apart from larger prop diameter.
another thing. those little fins at the back.......
what are the for and why and when would you adjust them??
Think it would make a nice Monster Energy/DC boat!
Cheers Chris
Old Jan 31, 2010, 11:45 AM
nick 30
nick30head's Avatar
Joined May 2009
for self righting you want the battery as close to the prop shaft as you can, keep the battery about in the middle of the boat, the fins are there to aid stability when turning, a long prop shaft will make the boat prop walk, i would try to make the shaft shorter at the motor to bring the prop closer to the transom or find a strut small enough for the shaft
Sold Estes SWEET VEE Lbuff1 Aircraft - Sailplanes (FS/W) 2 Mar 06, 2010 06:14 AM
Sold Magic fun fly Fizzy Aircraft - Fuel - Airplanes (FS/W) 4 Feb 03, 2010 02:58 PM
Build Log Dumas Deep Vee 40" Mo.Hawk Racing Boats - Electric 5 Jan 28, 2010 02:45 PM
Discussion Polihedral Vee-Tail? doddlepots Thermal 47 Nov 06, 2009 07:12 AM
Sold Estes Sweet-Vee rocket glider (a)NIB $60 KMKAZE Aircraft - Sailplanes (FS/W) 0 Aug 29, 2009 02:38 PM
