This thread is privately moderated by microflitedude, who may elect to delete unwanted replies.
Old Jan 29, 2010, 12:35 PM
microflitedude is offline
Find More Posts by microflitedude
RCG -Minus Member
microflitedude's Avatar
United States, SC, West Columbia
Joined Oct 2009
Build Log
guillow's glider conversion
I recently destroyed my Microfighter F-22, and decided to rebuild it.
I picked up one of those Jetfire gliders, and planned to mount the electronics onto it. I sharpied it with a Gee Bee trim scheme. I mounted the electronics onto it, and covered the wing surfaces and vert/horizontal stabs with packing tape to strengthen it. I went out to fly, (there were 5 MPH winds) it was hectic. It got tossed around and chucked back to earth, pulling two of the motor wires from the RX board.
I soldered them back, and tried again. same thing. I changed the motors from an angle, to no angle. the same thing happened 2 more times, but then I came out at sunset, and it flew like a dream - must have been the wind. Climbed steadily, no more throttle problems, and it can turn rather sharply, so it can preform minor aerobatics. Looks great in the air, and glides really well, too. I came in to sharply on a turn and cracked the fuse in half and the wires.
Hot-glued it back together, soldered the wires back, and continued flying until it was too full of glue to do fly anymore. It was a lot of fun, I'll do it again when my other Microfighter loses it's airframe.
microflitedude is offline Find More Posts by microflitedude
Old Jan 29, 2010, 03:22 PM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
That is awesome!
JohnsPop is offline Find More Posts by JohnsPop
Old Jan 29, 2010, 06:32 PM
RCG -Minus Member
Joined Oct 2009
Thanks i like it too.
Matt
Old Feb 02, 2010, 04:27 PM
clefspear is offline
Find More Posts by clefspear
Lynchburg VA
Joined Apr 2009
very unique build.
clefspear is offline Find More Posts by clefspear
Old Feb 02, 2010, 06:41 PM
RCG -Minus Member
Joined Oct 2009
Thanks guys. appreciate it.
Old Mar 01, 2010, 07:23 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
looks great! great job
starscream4002 is offline Find More Posts by starscream4002
Old Mar 01, 2010, 06:13 PM
RCG -Minus Member
Joined Oct 2009
Thanks SS. i maidened it a few days ago, with the improved mods. flies similar to the original F-22. climbs and VERY well. but one of those dang wires snapped again :P
Old Mar 02, 2010, 04:01 AM
Tabriz, Iran
Joined Sep 2008
maybe it can use a soft foam nose
Old Mar 03, 2010, 02:07 PM
RCG -Minus Member
Joined Oct 2009
Maybe, but actually it gradually weakened, and while i was handling it, it fel off. maybe i'll cover the wires in epoxy?
Old Mar 04, 2010, 12:30 AM
Tabriz, Iran
Joined Sep 2008
then how are you going to get the guts out for other builds?
Old Mar 04, 2010, 07:27 AM
RCG -Minus Member
Joined Oct 2009
the gear will probably die before the plane does. :P not the whole RX, but just the wires to strengthen them. flies nice, but gets tossed of to the side in wind. still got that nasty little wire. seems like after i solder it myself and put some elmer's on it, it doesn't break again.
Old Mar 04, 2010, 09:34 AM
Tabriz, Iran
Joined Sep 2008
which wire is it?
Old Mar 04, 2010, 11:20 AM
RCG -Minus Member
Joined Oct 2009
one of the motor wires. snapped from the solder point.
Old Jul 30, 2010, 01:37 PM
Stingray8854 is offline
Find More Posts by Stingray8854
Stingray8854's Avatar
USA, LA, New Iberia
Joined Jan 2009
Video! I used to LOVE those little balsa rubber band planes when I was a child. The gliders too for inside the house.
Stingray8854 is offline Find More Posts by Stingray8854
Old Jul 31, 2010, 08:35 PM
RCG -Minus Member
Joined Oct 2009
Plane got crushed crushed awhile ago. All the solder points got broken, and the terminals fell out of the battery. Not worth it. Just got the batt and motors and tossed the RX. Got another one later on, and that original airframe is still in one piece. :P When that one dies i'll mount the gear on another glider then post it on youtube. I've got enough projects for now though.
Matt
Build Log Guillow's 24inch Cessna 170 conversion to RC snarf007 Scratchbuilt Indoor and Micro Models 9 Mar 12, 2010 08:00 AM
Wanted Guillow's SE5 Biplane Glider Pierre_de’ Loop Aircraft - General - Miscellaneous (FS/W) 1 Oct 08, 2009 08:07 PM
Wanted Guillow's SE5 Biplane Glider Pierre_de’ Loop Non R/C Items (FS/W) 0 Oct 07, 2009 06:13 PM
Discussion Guillow's Foam Glider Conversion andrewwells13 Foamies (Scratchbuilt) 36 Mar 30, 2007 09:27 PM
