Old Feb 05, 2010, 10:56 PM
topgun2mo is offline
Find More Posts by topgun2mo
Slidell, LA
Joined Dec 2004
Thanks Mark, I'm having a ton of fun putting this together and in case any one wonders, I cant ever put an aircraft together exactly per plans. I just always have to put my own spin on it!
topgun2mo is offline Find More Posts by topgun2mo
Old Feb 05, 2010, 11:12 PM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
Originally Posted by PT Gyro View Post
Words of encouragement?? How about this: I'm impressed... looking real good... can't wait to see it finished... you're making it look easy... AND you are doing it very quickly.
Great job!
Mark
www.flyingbalsa.com
There ya go......from the man himself!
Thanks Mark!
jodini is offline Find More Posts by jodini
Old Feb 06, 2010, 02:30 AM
Jockadopolus is offline
Find More Posts by Jockadopolus
Jockadopolus's Avatar
Scotland
Joined Jan 2010
I have a 61 asp 4stroke in mine and it flys ok with the extra weight
I can see a lot more pt25 being modified after seeing yours, great job I look forward to the finished photos and flight video.Here is a link to my test flight video.
RC Hotel P T 25 Autogyro (4 min 45 sec)
Jockadopolus is offline Find More Posts by Jockadopolus
Old Feb 06, 2010, 02:33 AM
Boneswamped is offline
Find More Posts by Boneswamped
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
I already liked the PT gyro's, but you've made yours very unique. I like the changes you've incorporated, yours has a very nostalgic look. Looking forward to the maiden.
Regards,
-Mike
p.s. I really do like it, I'm not just complimenting you because Joe yelled at us.
Boneswamped is offline Find More Posts by Boneswamped
Old Feb 06, 2010, 08:43 AM
jodini is offline
jodini's Avatar
Joined Sep 2004
HA! Thanks Mike. I just don't like being alone!
I can't believe Jockadopolus has a .61 4-stroke on his! That's nuts! O.K. pluriel....I stand corrected!
Old Feb 06, 2010, 10:06 AM
Slidell, LA
Joined Dec 2004
Thanks for the Vid
Jockadopolus, thanks for the vid. That was sweet. I'll be sure to film mine.
Boneswamped, I was wondering if anyone down here in good ole Louisiana flew any of these contraptions! BTW I just added Slidell to my profile. You didn't miss it.
Jodini, plenty of company now!
Go Saints
Old Feb 06, 2010, 10:10 AM
pluriel is offline
Find More Posts by pluriel
Durham, UK
Joined Sep 2006
A 61- I am amazed! I was thinking more of a 30! It does look like a heavy model though - long take-off run, flies with authority but glides like a brick - a bit hard on the undercarriage i bet.
Regarding the question of weight - my Rainbow is designed for a 1300 lipo, but will take the weight of a 2100 no problem, it just flies a bit quicker.
pluriel is offline Find More Posts by pluriel
Old Feb 06, 2010, 11:09 AM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
My worry with the extra weight with a 61 installed would be the life of the PPP head plate, may be worth changing on a regular basis?
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Feb 06, 2010, 11:15 AM
Slidell, LA
Joined Dec 2004
Inspection
I only painted the top of the head. It would be easy to inspect the bottom of the unpainted head for any developing stress issues.
Old Feb 06, 2010, 01:30 PM
Slidell, LA
Joined Dec 2004
Mast Assy
I installed the head and layed out pushrod holes
I made an oh so small notch in the mast to accept the center stringer. 2nd photo shows all stringers installed. I added a stringer directly to each side of the mast to support sheeting along mast. (not shown in photo)
3rd photo shows the 1/16 balsa sheet fitted and glued to the mast and center stringers
Old Feb 06, 2010, 01:33 PM
Slidell, LA
Joined Dec 2004
Fit to Fuse
If you don't have an ammonia and water solution for balsa bending, good ole Windex will work quite nicely. As you can see it's fitted to the fuse
Old Feb 06, 2010, 05:49 PM
Slidell, LA
Joined Dec 2004
Faired in
The cockpit is kinda faired in now. I'll have a little more sanding filling before covering. As you can see from the profile view the shape of the cockpit looks pretty good. Again all laid out with a compass.
Old Feb 06, 2010, 05:53 PM
Slidell, LA
Joined Dec 2004
Boo Boo
Well I made a boo boo somehow when I drilled the lower portion of the gimbal. The pivot hole is oversize causing some slop.
If you don't have one of those K&S grab bags of brass tube, you are missing one of the greatest things in your shop. I've had mine for 20 years, made balsa drills, bushings etc from it. It's just invaluable.
I found a 3/32 ID piece of brass and cut a bushing and CA'd in the gimbal pivot hole (After it was properly sized) and no more slop.
Old Feb 06, 2010, 05:59 PM
Slidell, LA
Joined Dec 2004
Pilot
The pilot I would like to use is a Williams Bros #17500. I wish they came painted like this
Discussion My PT 25 in the cold!..BRRRRRRR!!!! SafeLandings Auto Gyros 68 Dec 18, 2010 05:34 PM
Discussion Who's PT-25 is this? topgun2mo Auto Gyros 0 Jan 22, 2010 08:35 AM
Video YAPT Yet Another PT 109 Maiden Voyage daemuon Dock Talk 5 Sep 16, 2009 04:34 PM
