Old Feb 04, 2010, 04:08 PM
topgun2mo is offline
Find More Posts by topgun2mo
Slidell, LA
Joined Dec 2004
hatch joint
OOps here are the pics
topgun2mo is offline Find More Posts by topgun2mo
Old Feb 04, 2010, 10:26 PM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
Come on guys...am I the only one watching this one! Give topgun2mo some words of encouragement!
What's the color scheme you going with...or is it a surprise? And cowl or no cowl?
What motor?
jodini is offline Find More Posts by jodini
Old Feb 04, 2010, 11:57 PM
Slidell, LA
Joined Dec 2004
I am going to go with the Power 32 as recommended with a TB 54 ESC as I have these ready to go. As far as scheme, I have been kicking that around between a pt-19ish scheme or something more inventive. I am going to put balsa around the firewall to give that rounded look that is typically behind radial engines. I'll probably fly it like that to see how it does before modeling a non functional radial engine to hide the power 32.
I usually torment myself over the color schemes. hahahaha
Old Feb 05, 2010, 12:11 AM
rotorheid is offline
Find More Posts by rotorheid
Closed Account
Joined May 2006
Hi topgun2mo,
You are doing a great job there mate, keep it up, choosing a colour scheme is personal and unique, it's what you want, I'm sure it will be very cool, good luck with the remainder of the build and of course your Maiden flight.
Cheers,
regards Al,
rotorheid is offline Find More Posts by rotorheid
Old Feb 05, 2010, 07:48 AM
Slidell, LA
Joined Dec 2004
Thanks Al
Old Feb 05, 2010, 08:17 AM
pluriel is offline
Find More Posts by pluriel
Durham, UK
Joined Sep 2006
Very pretty, it will be worth the effort. It would be even nicer with a small 4-stroke on the front...
pluriel is offline Find More Posts by pluriel
Old Feb 05, 2010, 08:39 AM
jodini is offline
jodini's Avatar
Joined Sep 2004
Thanks guys for jumping in! Now you have all the professionals to help ya.....4-stoke..LOL! NICE!
Here's one opition you could have. The plastic is super thin but it looks nice. imsofaman mad it worked on one of his electric autogyros...about the same size.
Old Feb 05, 2010, 09:19 AM
Slidell, LA
Joined Dec 2004
Radial Engine
I like that. Where is that from?
Found it. It's a Eflite PT17 cowl and dummy radial. Out of stock everywhere!
Old Feb 05, 2010, 10:16 AM
pluriel is offline
Durham, UK
Joined Sep 2006
Your build look so nice in fact that I have started looking sideways at my unstarted Flying Doozy kit - it does look a bit plain with flat sides....
Old Feb 05, 2010, 12:52 PM
Slidell, LA
Joined Dec 2004
Thanks Pluriel.
As you can see I added some 1/16 balsa from the top of the fuse down to the sides. The pattern you see removed on the bottom was to allow the balsa take on somewhat of a compound curve (wetted with ammonia and water) I still have to add cockpit sheeting (Probably 1/64 or 1/32 ply) but I'll add that when I get a pilot in the seat.
I wonder how these things fly a little heavier than usual? Anybody with that kind of experience?
Old Feb 05, 2010, 07:41 PM
Slidell, LA
Joined Dec 2004
Hatch Screws
Here I am using a paper tube to provide access to hatch screws. I decided against magnets as in my first post.
Old Feb 05, 2010, 07:45 PM
Slidell, LA
Joined Dec 2004
Ocd
I am so OCD that I made a jig out of ply to glue the blade shims in place to ensure that they are all placed exactly alike. Copied the head drawing, glued it on ply, drilled the matching blade hole and Voila it's done. In the last pic you can see where I masked the top of the bearing.
Old Feb 05, 2010, 07:48 PM
Slidell, LA
Joined Dec 2004
Paint!
Put a nice coat of primer and Panzer Grey on all of the head parts.
Old Feb 05, 2010, 07:49 PM
Slidell, LA
Joined Dec 2004
Covering Scheme
I am going to do a play off of this fuselage color scheme and do something different on the tail feathers
Old Feb 05, 2010, 09:22 PM
PT Gyro is offline
Find More Posts by PT Gyro
Joined Nov 2004
What motor?
Words of encouragement?? How about this: I'm impressed... looking real good... can't wait to see it finished... you're making it look easy... AND you are doing it very quickly.
Great job!
Mark
www.flyingbalsa.com
PT Gyro is offline Find More Posts by PT Gyro
Discussion My PT 25 in the cold!..BRRRRRRR!!!! SafeLandings Auto Gyros 68 Dec 18, 2010 04:34 PM
Discussion Who's PT-25 is this? topgun2mo Auto Gyros 0 Jan 22, 2010 07:35 AM
Video YAPT Yet Another PT 109 Maiden Voyage daemuon Dock Talk 5 Sep 16, 2009 03:34 PM
