Old Jan 29, 2010, 12:16 PM
Fossy313 is offline
Find More Posts by Fossy313
Joined Dec 2009
Question
esc all one, can i change to different tx/rx?
basikally guys im wondering if i can use my new eurgle tx/rx in my old plane cessna tw 747, however i am led to believe that the rx and esc in this plane is all one, does this hinder me doing this? can i get round it??
craig
Fossy313 is offline Find More Posts by Fossy313
Old Jan 29, 2010, 12:34 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
you would have to replace the all in 1 board with a ESC and RX (compatable with your TX) to fly her.
ATIS is offline Find More Posts by ATIS
Old Jan 29, 2010, 06:28 PM
Fossy313 is offline
Joined Dec 2009
any idea what ESC i would need for a 37A motor???
Old Jan 29, 2010, 06:51 PM
Ira NZ is offline
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
One with at least a 37 amp capacity.
But, I seriously doubt that little brushed motor is drawing 37 amps.
Ira NZ is offline Find More Posts by Ira NZ
Old Jan 30, 2010, 05:07 AM
Fossy313 is offline
Joined Dec 2009
yer i think the esc is 30 amps, but even then it seems alot, however i take it the esc just connects stright to the motor? i found out this information about my plane and was wondering if this ESC i have found would be adiquate to go with my new 2.4g eurgle system
someone kindly posted this on another one of my threads for me..
Wingspan 980mm (40')
370 brushed motor with gearbox
8x6 prop
8 cell 650mAh NiMH
4ch 35MHz with rx/esc in one unit
The last item on the list is the little beast you're looking for. Mixing the receiver and the ESC in one unit is pretty cheap......cheap in a bad way.
this is the ESC i was looking at.... http://cgi.ebay.co.uk/ws/eBayISAPI.d...id=p2759.l1259
Help! looking for all in one motor,esc,batttery mount HELP ginger turbo Pusher Prop Jet Models 0 Nov 09, 2009 06:16 PM
Help! What all different RX's can I use w/spektrum DX6I mechengineer03 Radios 12 May 13, 2008 03:36 PM
Discussion Can I Change The Tx And Rx On My Blade Cx2 the grounds 2 hi Coaxial Helicopters 0 Jun 25, 2007 04:19 PM
GWS tx and Aerohawk all in one rx conversion 72Mhz to 35Mhz peterbennett26 DIY Electronics 5 Jun 11, 2004 08:39 AM
FS- Wattage Tubby Cubby Kit, GWS Rx, esc, 6 gr servos and Neon Tx- All NIB Etonic Aircraft - Electric - Airplanes (FS/W) 0 Feb 09, 2004 02:33 PM
