Old Jan 28, 2010, 05:27 PM
surfmount is offline
Find More Posts by surfmount
surfmount
Denver
Joined Nov 2006
Fly-dream RX\Fly-sky TX
I want to post a thread on the version 2.0 Fly-Dream 2.4 GHZ TX module (JR in
my case) with the 8 channel RX married to the Fly-Sky FS-TH9X transmitter
for the purpose of getting posts on this equipment and it's success or not.
I have been flying XPS and Spectrum DX6I for the last 3 years with no problems
on either. But, I decided to try some chinese flavor, so I looked at all the options
and decided if FLy-Dream had failsafe it was an obvious choice due to
the $20.00 per RX, and $41.00 for Module and 1 RX.
After getting the wrong RX's (V 1.2) with V2.0 module and getting 3 more sent
with the right version, I got them bound and working. Here is what I found:
1. very small 8 channel RX weighing 6.5 Grams with very good construction.
2. Dual antennas with length options of 4.5", 6" , and 10" (approximate).
3. Range check with no antenna and TX pointed at plane (10" above ground)
the range was 256 '. Looks to be more than enough. (they say 1200 meters)
4. The module fits the Fly-Sky TX very nicely, with the antenna on top of
the module which gives good protection being behind the handle.
5. A nice surprise was the current drain on the RX. Only 20.8 mils (no servo)
XPS 8 RX draws 69 mils (TX on), the spectrum draws 96 mils. (TX on).
6. With bench supply and DVM I measured drop out at 2.4 V. and when
bring the voltage back to 2.5 V. reboot was very quick, about 1 sec.
7. I really like the co-ax antennas. Tape one fore and aft to the side and
one vertical and no worry about servo cables getting too close to the
antenna.
8. Operation of all 7 servos is very smooth, no hesitation anywhere, and I
can see no delay in elevators using ch. 2 and 6. Both elevators appear
to come up together without a lag. Not true on my Spectrum (older
version).
9. The support from Fly-Dream has been very good, although we have
trouble communicating, I get emails back the next day on questions.
10. And very importanty, a good failsafe system. After bind, with led lit
and receiving, press the button on the RX, hold, light goes out, set
controls where you want them, press button once and that's it. It
works from then on going exactly where you set it on loss of signal.
It so easy to set up a cave man can do it.
11. Touching the TX ant. to the RX ant. I got swamping at 1 CM.
Here is how the system works according to Roma at FLY-Dream:
The TX picks 3 clean channels (frequencies in 2.4 spectrum). It transmits
each packet of data on all 3 channels constantly. The RX is told which 3
(at boot up), and receives on the 1st one until interference is detected.
(probably by CRC check or data comparison or both that isn't clear). Upon
interference or noise it goes to the next one and the 3rd one and back to
the 1st one.
Having 3 RX that are useless (the V 1.2), I decided to tear off the cover
which BTW is very heavy and hard shrink of some kind, and see what was
inside. Both the Module and The RX use the TI CC2500 Rf chip with RF pre
amp T212, and 32 pin Atmel processors. 1 in the RX, 2 in the module.
All in all I think it is a winner. I would add a button to decrease pwr for
range check. otherwise, I see no other negatives. Hope to hear from someone
on this system. BYW I got mine from www.hobbiesbp.com
surfmount is offline Find More Posts by surfmount
Old Jan 29, 2010, 05:27 PM
fernandez is offline
Find More Posts by fernandez
Joined May 2009
Yes I can agree the system is in my eyes the best system available, in range of 20 dollar receivers. (price is very important to me, as my Airtonics works well but receivers are too expensive especially for foamies etc)
I have been flying the 4 channel recently. Range is really good, far much better than 450m. When walking away testing the range I was getting so far and it was still working that I decided to walk back. I do nut understand why 450m is stated and 1200m for the 8 channel, the chipset and rf stage are identical.
4 channel is really light and compact, but 8channel is also really light too!
Binding is flawless, switching on off the tx and rx is online within one second. I did not have found any problem of jitter, or spikes. Also I did not see any problem with transmitter at close range.
When flying my plane with the small receiver it reacts good and never find a spike. or problem.
To set the failsave simply push the button during startup, than when led goes off loosen the button, set stick min position you like and push the button on receiver failsave for all channels are set and stored until you repeat the procedure.
Technically the system seem using some chinese 2.4ghz modules as you'll also find them in Corona, Wow rc, Frisky, etc. On top they are using atmel cpu, 2 in tx 1 in rx. Likely each RC manufacturar implements it's own coding schemes and use of the modules.
Only 3 comments I have:
1) The diversity of the both antenna's on the 8 channel receiver are not monitored and not switched by RSSI or by bit error rate from the cc2500, they are just coupled with a simple capacitor in parallel, wich means some losses due to fase erros and impedance mismatch.
On the the other side I checked inside my airtronics receiver and I see the antennas are also put in parallel, but in this case with impedance adaptation network.
So I am not sure if putting antenna's in parallel is a bad or good thing.
All I can say no range or lock out problems sofar.
(In theorie it should be simply possible to equip the 4 channel receiver with dual antenna's, so it should also make 1200m)
2) They provide a buffer capacitor to prevent for spikes noises from servo's etc. this capacitor has to be put on a free channel. I don't like it as the capacitor is big but also it does not buffer very well, as it also powers the servo's wich will pull the voltage down. The Capacitors in the receiver ar very small, I think when you use clean servo's and speed control you can just live with it. But I think a few ms voltage drop, below 3v might lock out the receiver.
My fix:
When opening the receiver you'll find the +5V first pass a diode, for polarity protection, than there is a 3V3 regulator and small smd capacitor.
I soldered a panasonic "goldcap" storage capacitor. They are normally used in back-up circuits etc. 0.1F 5.5V.
http://shop.conrad.nl/componenten/co...ps/422084.html
With this capacitor, when disconecting the battery the receiver will stay on for almost a second. It makes it totally proof to any noises on voltage.
3) The regulator used in the TX module gets warm, it is not of any problem or risk, but means waste of battery life. 12v is regulated down to 5volts, there after a 3v3 regulator feeds the TX module. Best would be to use an efficient 3v3 switching regulator.
In my case I build the module into my rds8000, and feed with 3v3 from the regulator in my RDS8000
Anyway the system works flawless sofar and I am happy and can recommand the system!
fernandez is offline Find More Posts by fernandez
Old Jan 30, 2010, 09:28 PM
surfmount
Denver
Joined Nov 2006
Yes, Fernandez, I like your .1 f. cap for a 5 Volt system. Surely will help stop
drop out. I think I mentioned in my thread that I tested the RX down to 2.4 V.
before dropout, but even then the cap would help. I use only 6 volt systems
so you have another 1.2 V. nominal "head room". Also, this season (if it ever
gets here) I am going to Life04 cells. Two cells saves two ounces and they
hold their l4 milliohm ESR clear through the charge, unlike both Nickel types.
I think that will help dropouts tremendously. I tried a 1 farad (big & fat) and
I didn't get a 1 sec hold on turnoff. Maybe not as good as your Golden cap.
I haven't flown my Fly-Dream yet, but I am glad to hear that you have success-
fully. Have two installed in gas airplanes.
Surf
Old Jan 31, 2010, 07:42 PM
flydreamrc is offline
Find More Posts by flydreamrc
Joined Oct 2009
Very Good!!!
flydreamrc is offline Find More Posts by flydreamrc
Old Mar 23, 2010, 11:38 PM
Chomamma is offline
Find More Posts by Chomamma
Joined Apr 2008
I have the HK Turnagy brand and are using it with the new V3. All work flawlessly. Now theres a dealer in US. I'll need more receivers.
Chomamma is offline Find More Posts by Chomamma
Old Mar 24, 2010, 09:28 PM
Joined Oct 2009
Aha ,we have USA local supplier there ,and you can buy from www.rc-models.com
this will Convenient.Thanks!
Old Mar 24, 2010, 10:59 PM
Chomamma is offline
Joined Apr 2008
Actually I think it is rc-modules.com ;0)
Old Mar 25, 2010, 08:28 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Just to confirm, the supplier is:
http://rc-modules.com/
Daedalus66 is offline Find More Posts by Daedalus66
Old Mar 25, 2010, 09:31 AM
Joined Oct 2009
Originally Posted by Daedalus66 View Post
Just to confirm, the supplier seems to be:
It certainly isn't the one mentioned by flydreamrc.
sorry i type a mistake
Old Mar 26, 2010, 11:20 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I've ordered modules and receivers from http://rc-modules.com/ so will have a chance to see how the new v3 works. From what I read, it's very promising and the price is certainly right.
Old Apr 01, 2010, 09:06 PM
Zaper is offline
Find More Posts by Zaper
Monterrey, MX
Joined Mar 2010
I have a pair of questions:
I want to convert a Futaba FM Tx to 2.4GHz.
- Is the FlyDream DIY 2.4GHz Tx compatible with FlySky 2.4 or HobbyKing receivers?
I Have a FlySky FS-TH9X Tx
- Are the FlyDream receivers compatible with the FlySky 9X Tx?
Zaper is offline Find More Posts by Zaper
Old Apr 01, 2010, 10:44 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Different radios on 2.4 are NOT mutually compatible. The only exception is when they share technology (JR/Spektrum) or are really the same radio with a different label (Turnigy, iMax, etc.).
FlyDream is a distinct manufacturer and their modules work only with their own receivers.
Note, however, that the FlyDream modules come with one receiver for $39 and extra receivers are only about $21. So maybe it doesn't matter.
Old Apr 01, 2010, 11:06 PM
Chomamma is offline
Joined Apr 2008
Zaper,
I'd go with the FD DIY module and replace the HK one. I think HK only uses 3 frequencies anyway. And the receivers are nevr in stock. They you would have receivers that would work with both transmitters. Just a thought.
Old Apr 02, 2010, 02:48 AM
Zaper is offline
Monterrey, MX
Joined Mar 2010
Thanks Daedalus66 and Chomamma for your comments.
The FlyDream and the FlySky JR modules looks identical and I thought were the same factory.
The FlyDream V3 has very interesting specs. and better price.
Old Apr 02, 2010, 07:35 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
That's what I concluded. I've ordered a couple of modules with receivers from:
What convinced me was seeing that FD V3 is a true frequency hopping system. For proof, see:
http://www.rcgroups.com/forums/showthread.php?t=1217849
For Sale T-rex 450 xl, great condition, add rx,tx to fly. Well setup , $175 only final price missil3 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2010 03:57 PM
For Sale T-rex 450 xl, great condition, add rx,tx to fly. Well setup , final price missil3 Aircraft - Electric - Helis (FS/W) 4 Jan 20, 2010 03:40 PM
For Sale T-rex 450 xl , rx+tx to fly , Price lowered to $185 missil3 Aircraft - Electric - Helis (FS/W) 1 Jan 16, 2010 06:14 PM
Sold Fly Sky Tx/Rx (FS-CT6A) "Damaged in shipping" but WORKING eizarg Aircraft - General - Radio Equipment (FS/W) 1 Jun 30, 2009 11:12 AM
Sold Fly Sky Tx/Rx (FS-CT6A) eizarg Aircraft - General - Radio Equipment (FS/W) 2 Jun 29, 2009 12:10 PM
