Old Jan 28, 2010, 12:14 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Alert
GoPro HD live video out!
The other thread was getting too long. Found this on another forum and tracked it back to the original (I think):
http://www.video-flieger.de/?p=438
Maybe GoPro will make a better way to do this, but until that time here you go. What I'd like to know is if you can power the camera from the 5 volt USB connection so that you could use a BEC and your flight pack to extend your recording times. Looks like they used the standard definition connection in the pictures, but that just makes it cheaper for the TX half since you don't need to buy a wide band HD TX to see it.
I have not tried this yet, just thought some of you might be interested in the info. Your mileage may vary, please report back if you have success.
village_idiot is offline Find More Posts by village_idiot
Old Jan 28, 2010, 09:03 PM
Inciting Riots
Joined Dec 2006
Would have thought this would have sparked more interest.
Old Jan 29, 2010, 12:59 AM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
Wow, that's good news indeed. How did they fix the live out during video recording, thru some firmware update?
And what's a "Live-View-Archos-Monitor".
hmm..
Do we finally have a HD FPV camera?
All video out /live view have a small delay. How is the delay like? Small enough to fly FPV with it?
The author mentioned being cut-off. Not good.
etman is offline Find More Posts by etman
Old Jan 29, 2010, 07:24 AM
Inciting Riots
Joined Dec 2006
Nope, this is a user found hack, so it works on existing cameras.
That monitor is just some little LCD that Archos sells, could just as easily be connected to a video TX. Note that it is connected to the standard definition output so the HD output may or may not work.
Old Feb 09, 2010, 04:45 PM
SSM is offline
SSM
Find More Posts by SSM
SSM
Voluntary Assumption of Risk
SSM's Avatar
Australia, VIC, Canterbury
Joined Nov 2003
Guys, you know that Wobby has done a tutorial on how to get live A/V out while recording. Dead easy!
Simon
SSM is offline Find More Posts by SSM
Old Feb 09, 2010, 07:46 PM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
thanks village+ssm+WOBBY !
village : i agree, it should have show up more on FPV threads ?
if i understand right :
1-you turn on power on gopro
2-you put the camera on player mode
3-you play a video clip... to its end
4-you power up the USB in with external 5 volt
and then the camera is showing video out, and
you can also record while video out ?
ggtronic is offline Find More Posts by ggtronic
Old Feb 09, 2010, 07:58 PM
Talontsi96 is offline
Find More Posts by Talontsi96
Talontsi96's Avatar
Edmonton, Alberta, Canada
Joined Jun 2004
COOL.... I think I'll be pulling the trigger on the GoPro HD....
Talontsi96 is offline Find More Posts by Talontsi96
Old Feb 10, 2010, 10:26 PM
frogman1206 is offline
Find More Posts by frogman1206
Frogman
Stoughton, WI
Joined Jun 2009
Ok, I am thinking about giving this a go. I have a question.
The guy who posted the video on how to do it had a little switch rigged up to turn on the USB power to the camera when the time was right. Instead of putting a switch on there with the added weight could you not just take a servo plug wire and hook the positive and negative to the appropriate USB plugs? Then you take the servo connector and put it on your gear channel. When it is time to power up you just flip the gear switch. Won't that send power to the USB plug and the camera?
Just wondering. I may give this a shot in the next few days.
frogman1206 is offline Find More Posts by frogman1206
Old Feb 11, 2010, 06:47 AM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
I'm pretty sure the + and - are constant so the gear switch would not work. If you had an "RC switch", then it would work.
man2000me is offline Find More Posts by man2000me
Old Feb 11, 2010, 10:02 AM
Frogman
Stoughton, WI
Joined Jun 2009
Oh well....it was a good idea. I still am kinda new to some of the crazy technical stuff....but learning.
Old Feb 14, 2010, 12:11 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
I just tested this with my gopro and it works like a charm - I also notice that it just takes a few seconds of power to put it into live mode then you can turn off the power and remove the usb plug if so needed. This means I dont have to carry an extra battery or weight of the plug to get live video - Just kick the camera into live mode and fly fpv - Nice!!!
cdi3d is offline Find More Posts by cdi3d
Old Feb 14, 2010, 02:12 PM
kestasxxx is offline
Find More Posts by kestasxxx
kestasxxx's Avatar
Baltic States
Joined Jun 2008
my goPro with turnigy 5V BEC
kestasxxx is offline Find More Posts by kestasxxx
Old Feb 14, 2010, 10:53 PM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
So you are power your cam from the BEC? How much weight did the cam lose when you yanked the battery?
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Feb 16, 2010, 04:29 AM
sunrider is offline
Find More Posts by sunrider
sunrider's Avatar
Joined Mar 2008
Hallo
There is a short usefull update
http://www.video-flieger.de/index.ph...o-hd-live-out/
LG Sunny
sunrider is offline Find More Posts by sunrider
Old Feb 16, 2010, 10:12 AM
Inciting Riots
Joined Dec 2006
Hopefully it will only be another week or so for the new firmware and hopefully all these games can be stopped. Rumor is that they will have video out during record in this new firmware. Best estimate is end of February but I'll believe it when it's available.
Yippee! When (xmas) Trees Attack - Trees 0 : Stryker 2 (HD GoPro Vid) snoopy Aerial Photography 5 Feb 17, 2010 07:20 PM
Gallery GoPro HD video "rear view" power Aerial Photography 10 Jan 18, 2010 03:54 PM
Gallery GoPro HD 720p video test power Aerial Photography 1 Jan 17, 2010 01:31 PM
Discussion Point and Shoot camera that outputs video out while recording HD video Xnaron FPV Talk 4 Jan 17, 2010 01:14 PM
Cool GoPro HD Hero Wide - 6.3 oz HD video camera nemo_uk Aerial Photography 5 Sep 27, 2009 10:40 AM
