Old Aug 28, 2010, 05:49 AM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
in one of the funnel casings put a gutted servo, in the space between them, a big drum attatched to the servo.
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Aug 28, 2010, 11:29 AM
HeavyCruser9 is offline
Find More Posts by HeavyCruser9
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
Thx Ghost, There will be a winch but lower down,( hope I explain this right) there is going to be a winch house aft of funnel and below level of base of funnels with a couple of small cranes. Some thing like on these deck plans(But jiggled with a tad!)
Cheers Bruce
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Sep 01, 2010, 10:05 AM
Adelaide,Australia
Joined Dec 2009
Did a bit more work on Tug and Superstructure, Primered Hull 2 check for high points and it is surprisingly good! I will lightly rub it back 2mora and see how it comes up. Sat the Bridge on it tonight for fun and got some pic's
Cheers Bruce
Old Sep 01, 2010, 11:19 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Look s good.
Im longing to paint mine, think its not so far away in the future, just needs to put on the fiberglass and then fill and sand ect. ect....
Sharky1dk is offline Find More Posts by Sharky1dk
Old Sep 01, 2010, 11:27 AM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Just a Question?? on the inside i primed the hull with some Filler (Hempel 599 for grown up boats) Its a kind of Epoxy (its in 2 cans to be mixed) its for soaking into the wood filling, sealing and strenghting it. Shall i put it on on the outside too before the fiberglass or is the fiberglass enough?? In the "manual for the sealer it states "not to be used on gelcoat" so i cant use it on the fiberglass.
Old Sep 01, 2010, 04:37 PM
Ghost 2501's Avatar
stoke on trent
bloody hell bruce i like it !!!
Old Sep 01, 2010, 09:32 PM
Adelaide,Australia
Joined Dec 2009
Thx Ghost!! She's a fat looking beast
Sharky I would go with just F/g on outside, then use auto body filler, sand it, another coat of resin 2 seal the filler, sand it again until happy. My Tug was resin coated inside hull first (several times!cause I could LOL) then resin outside, sanded, then used the fine glass mat they use for surfboards resin'd that on , then filler until happy with it then more resin!!!
Cheers Bruce
Old Sep 01, 2010, 09:53 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Looks like it has been put above the long beach project.
The primer really shows the shape. Great Job Bruce.
Aimee
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Sep 02, 2010, 12:38 AM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
I would bet that the warning about not using it on gelcoat is to make sure it doesn't ruin the gelcoat, more than it will not stick to fiberglass (or the glass wont stick to it). An easy test would be a small piece of plywood (maybe a foot square) put the resin on it then try glassing over it.
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Sep 02, 2010, 03:54 AM
Adelaide,Australia
Joined Dec 2009
Thx Aimee!!
Ya the USS Long Beach makes a great bench, gives a good impression of how big the Tug is compared 2 the Heavy Cruiser!
When my Tax return check turns up I will be sendin ya an order for Bow bumper rubber and Some of your LED flood lights!! They R perfect for some lighting job's I have in mind!
Cheers Bruce
P.s I rubbed primer back today and it is looking very nice indeed!!
Old Sep 02, 2010, 05:13 AM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Thanks for the advice
Now i can proceed with ease of mind..
Old Sep 02, 2010, 11:04 AM
cos918 is offline
Find More Posts by cos918
cos918's Avatar
abingdon england
Joined Feb 2008
Bruce
that tug looks top. You done a great job on her considering you are not following a real tug.
John
cos918 is offline Find More Posts by cos918
Old Sep 02, 2010, 11:16 AM
Ghost 2501's Avatar
stoke on trent
i am considering stripping the bridge down on Nord Adiemus now and changing it
Old Sep 02, 2010, 03:58 PM
Ticonderoga is offline
Find More Posts by Ticonderoga
Ticonderoga's Avatar
Australia, QLD, Mudgeeraba
Joined Feb 2010
Hi Bruce,
your not playing fair.......too many lovely boats
Now I will have to seriously consider Pacific Responder........
Ticonderoga is offline Find More Posts by Ticonderoga
Old Sep 02, 2010, 09:27 PM
Adelaide,Australia
Joined Dec 2009
Cos918 (John) Tug is loosely based on SEMCO's 75m AHST "Salvanguard" except I have redesigned the bridge so it is unique.
Ghostie go forth and modify!! Its Refit time!!
Tico I started this tug back in Summer!! I had'nt touched it for about 3 months ( as evidenced by all the dust!! when I cleaned it) Pacific Responder would make a sweet tug!! Consider it for your next project after Varyag's hull is done.
Cheers Bruce
Build Log A Modern Harbor Tug toesup Dock Talk 514 Sep 06, 2011 01:46 PM
Build Log Project Gatika, Modern Voith Tug yacht boy Scale Boats 198 Feb 19, 2009 04:05 PM
Help! Building a Modern Tug Mast captain at the Scale Boats 15 Dec 23, 2007 07:58 PM
Build Log Ocean/Harbor Tug Based on Fiberglass Hull off eBay not_in_houston Scale Boats 53 Nov 12, 2007 10:27 AM
