Espritmodel.com Heli Air
Old Aug 13, 2010, 04:13 AM
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
I'm still learning myself mate! But its not that difficult once you've done it a couple of times! I'm gonna do a much better job on USS California!! Each boat must be better made than the next!! Always learning from my previous builds.
It had been awhile since the tug had any work done on her and I'd like 2 have her running by end of September for a test run of drive setup atleast. I have started drawing out the superstructure bits on some styrene and still need 2 make up decks and deck supports.
Plenty still 2 do on her yet. Still got to settle on a good name for her!
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Aug 13, 2010, 04:15 AM
Adelaide,Australia
Joined Dec 2009
P.s It takes 13.5kgs(29.8 lbs) of ballast to get her 2 the waterline!!
Old Aug 13, 2010, 06:36 AM
Regional Victoria, Australia
Joined Aug 2010
G'Day Bruce,
Nice tug but a question for you....
How may boats are you building. Each time I look at a new build, it has your name on it....
P.S. Have you spoken to Michael B re club motors???
Martin du
Martin du is offline Find More Posts by Martin du
Old Aug 13, 2010, 08:53 AM
Guard-Officer's Avatar
Canada, ON, Quinte West
Joined Feb 2009
Looking really good there Bruce,
That things going to be a monster tow-er! Do you have an idea of the Bridge structure yet? or is this just going to be a make it up as you go? I'm lookig forward to seeing more on this puppy!
G-O
Guard-Officer is offline Find More Posts by Guard-Officer
Old Aug 13, 2010, 10:48 AM
Adelaide,Australia
Joined Dec 2009
Thx G-O I have some plans drawn up for her Superstructure based loosely on A SEMCO AHST tug 'Salvanguard' based in Singapore. I just need 2 cut em out of Styrene sheet!!
G'day Martin!! I have 5 large models in various states of construction! If I get stuck I just work on different build!! Power for the Tug will probably be a pair of 550/600 sized Graupners driving 3.3:1 planetary gearboxes (for nice fat torque output) with 60mm 4 bladed props in Kort nozzles.
Cheers Bruce
Old Aug 13, 2010, 10:50 AM
Adelaide,Australia
Joined Dec 2009
P.s All up the most expensive part of this build has been the Fibre glass resin and cloth!! Total cost so far in wood and resin has been approx. $70AU !!
Here is a pic of the ship "Salvanguard" that she is loosely based on.
Old Aug 13, 2010, 01:42 PM
bc850's Avatar
Slidell, La.
Joined Aug 2008
Bruce, here is a newer pic of her. I'm thinking of doing a build similar to this after I finish the Hunter. Your boat is looking very good, I admire your skills converting a PDF file into a working model!
bc850 is offline Find More Posts by bc850
Old Aug 13, 2010, 04:14 PM
cos918's Avatar
abingdon england
Joined Feb 2008
Cheers Bruce
Hi Bruce
The tug is looking good. Have you thought of Graupner 720 BB Torque on a direct drive. Loads of power low RPM and low current draw
John
cos918 is offline Find More Posts by cos918
Old Aug 13, 2010, 05:17 PM
Joined Apr 2009
Great work yours.
Only to give inspiration.
José MOta is offline Find More Posts by José MOta
Old Aug 13, 2010, 09:27 PM
Adelaide,Australia
Joined Dec 2009
bc850 It looks like as well as new hull color they have taken all the tires off the sides.
Jose That is a very RED boat great pic mate!
Cos918 I considered 720torque's but the cost is too high for my budget at the moment and I can get the proposed drive setup(motors,ESC's and gearboxes) for less than the price of the pair of 720's
Cheers Bruce
Old Aug 14, 2010, 06:35 AM
cos918's Avatar
abingdon england
Joined Feb 2008
Hi Bruce
I hear what you mean on Graupner prices,they have sky rocketed in the last few years.
John
Old Aug 14, 2010, 06:42 AM
Adelaide,Australia
Joined Dec 2009
Yeah mate I luv the quality of em (and the grunt!!) but the prices on the larger size motor's R 2 high. I should be able 2 finish the tug within a reasonable budget( maybe!!LOL) which was always the plan (build a nice tug for under $300) total cost looks like will come to about $250ish.
Cheers Bruce
Old Aug 15, 2010, 10:51 AM
Adelaide,Australia
Joined Dec 2009
YIPPEE!!
Just discovered a pair of Geared Pittman motors in the Shed that I had forgotten about they will do nicely for the Tug!!. They R geared 5.6:1 but can be run up to 24volts if necessary they will be turning 60mm 4-bladed props in Kort nozzles.
Best of all I don't have 2 spend money on motors! can spend it on the ESC's instead!!
Cheers Bruce
Old Aug 15, 2010, 11:29 AM
Joined Feb 2009
Ace in the Hole!
Old Aug 15, 2010, 07:43 PM
Adelaide,Australia
Joined Dec 2009
Ya Mate!! I will probably get a pair of Electronize FR15 ESC's (max 24v) and set tug up on 12v first see how much power it has, if more needed then try 18v!!
Cheers Bruce
Build Log A Modern Harbor Tug toesup Dock Talk 514 Sep 06, 2011 01:46 PM
Build Log Project Gatika, Modern Voith Tug yacht boy Scale Boats 198 Feb 19, 2009 04:05 PM
Help! Building a Modern Tug Mast captain at the Scale Boats 15 Dec 23, 2007 07:58 PM
Build Log Ocean/Harbor Tug Based on Fiberglass Hull off eBay not_in_houston Scale Boats 53 Nov 12, 2007 10:27 AM
