Old Mar 14, 2010, 01:41 AM
HeavyCruser9 is offline
Find More Posts by HeavyCruser9
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
Wow haven't done anything on tug for a while about 2 order some gearboxes. the MP-Jet planetary type for 500-600 size motors they will be attached to 550 type motors.
Was wondering if I should go for the 3.3-1 ratio or the 3.8-1 ??? Any suggestions ??
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Mar 14, 2010, 12:25 PM
CaptLee is offline
Find More Posts by CaptLee
United States, CA, Hayward
Joined Feb 2006
Would checkout the RPM's of the motors and then figure to downsize to 2,500 to 4,500 turns on the prop. That would be well within the ballpark. I tend to go to the 3.8 to 1 to turn big props but have had to swap up to get the prop speed in the range.
CaptLee is offline Find More Posts by CaptLee
Old Mar 14, 2010, 05:24 PM
Adelaide,Australia
Joined Dec 2009
Thx CaptLee I was thinking same Rpm's too! props will be about 50mm in fixed Kort's
Cheers Bruce
Old Mar 16, 2010, 08:50 PM
Adelaide,Australia
Joined Dec 2009
Started Gluing the frames 2 the keel today, starting to look like a proper Tug!!
Cheers Bruce
Old Mar 17, 2010, 04:17 AM
Adelaide,Australia
Joined Dec 2009
6 hours later and all frames R attached 2 keel !!
Now 2 start skinning her!!
Cheers from 'Bottom of the World Shipyard's!!'
Bruce time for several #25's
Old Mar 17, 2010, 11:53 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Look'n good.
You can never have too many clamps.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Mar 18, 2010, 12:24 AM
Adelaide,Australia
Joined Dec 2009
Yes U can never have 2 many clamps!! shaped the stern ends today made em up out of scrap wood left over from USS Long Beach. Now I need a break and a #25.. Some pics of todays work plus Tug with LB for size comparison.
Cheers Bruce
Old Mar 23, 2010, 09:51 PM
Adelaide,Australia
Joined Dec 2009
Been doing some work on tug hull planking a little bit 2 do (some small strips, and bow bulwarks then some sanding) then I can start F/glassing her. The hull is 1.5mm balsa sheet with 1.5mm ply for upper sides and bow bulwarks.
Cheers Bruce
Old Mar 29, 2010, 08:38 AM
Adelaide,Australia
Joined Dec 2009
Been busy f/glassing and filling hull, did a ballast test in the bathtub tonight 2 C how much weight she will need for waterline. It took 5 x 12v7ah batteries (approx. 11kgs (22lbs)). when finished she will be powered by 2x 12v7ah the rest of ballast will be lead and weight of motors and equipment.
Cheers Bruce
Old Mar 31, 2010, 08:39 PM
TOWHOOK is offline
Find More Posts by TOWHOOK
TOWHOOK's Avatar
Tennessee
I tell ya Bruce your a boat building machine. I get on here one day and you have frames cut. The next, it seems like you are putting filler on one and another build is already getting wet. You guys must have more than 24 hours in a day down there in Aussieland or I just build slower than crap...I'm thinking its the latter though, haha. Great work as usual by the way.
TOWHOOK is offline Find More Posts by TOWHOOK
Old Apr 01, 2010, 12:41 AM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
no Heavy is just powered by #25! Like most Ausies!
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Apr 01, 2010, 01:34 AM
Adelaide,Australia
Joined Dec 2009
Just plenty of free time due 2 lack of a Job!! Plus the weather has been perfect for building boats and #25's!! although I only started this build 60 odd days ago!!
The tug will have too sit for a bit now until I can afford running gear for her, need 2 decide if I am going 2 put a bow thruster in or not.
Spent the afternoon fixing my jet boat so it don't leak like sieve around the drive unit!!
will have 2 wait 24 hrs for it 2 dry before testing...
Cheers Bruce
Old Apr 03, 2010, 03:26 AM
Adelaide,Australia
Joined Dec 2009
And some pic's of hull from Thursdays sanding and primering session!
Cheers Bruce
Old Aug 13, 2010, 01:43 AM
Adelaide,Australia
Joined Dec 2009
Did somemore!!
Wow I actually got some work done on the Salvage Tug today!! Haven't touched it for a couple of months, I have some Kort nozzles on the way from Uk. So I thought I would get the hull finished off before they turn up.
Have done the bilge keel and ribbing on Stbd side, now need 2 do other side!
Cheers Bruce
Old Aug 13, 2010, 03:46 AM
Ticonderoga is offline
Find More Posts by Ticonderoga
Ticonderoga's Avatar
Australia, QLD, Mudgeeraba
Joined Feb 2010
She is looking really nice Bruce.
I will have to get some "glassing" tips from you
Ticonderoga is offline Find More Posts by Ticonderoga
Build Log A Modern Harbor Tug toesup Dock Talk 514 Sep 06, 2011 01:46 PM
Build Log Project Gatika, Modern Voith Tug yacht boy Scale Boats 198 Feb 19, 2009 04:05 PM
Help! Building a Modern Tug Mast captain at the Scale Boats 15 Dec 23, 2007 07:58 PM
Build Log Ocean/Harbor Tug Based on Fiberglass Hull off eBay not_in_houston Scale Boats 53 Nov 12, 2007 10:27 AM
