Old Mar 19, 2012, 05:33 PM
HeavyCruser9 is offline
Find More Posts by HeavyCruser9
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
It should have a working winch eventually and fire hose pump too!
Cheers Bruce
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Aug 03, 2012, 03:17 AM
Adelaide,Australia
Joined Dec 2009
Some progress has been made on the Titan! Hull has been resprayed a Dark blue with Indian red antifouling. Got the deck redone today while the sun was out and painted the Aft deck fittings tiger yellow. Then fitted the aft bollards and bits...now I need to stuff all the electronics back in...
Still a bit of work to go on the bridge and main mast....
Bruce
Old Aug 03, 2012, 08:03 AM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
I like the dark blue.
Jerome Morris is offline Find More Posts by Jerome Morris
Old Aug 03, 2012, 10:59 AM
Adelaide,Australia
Joined Dec 2009
Thx Mate! Yeah I like it much nicer than the black. Now I need to scratch build a crane and davits for a 26' RHIB... and and finish interior of bridge plus lights and mast....
Old Aug 09, 2012, 09:54 PM
Adelaide,Australia
Joined Dec 2009
Stuffed all the Rc bitz back in (picture a rats nest of wiring!!) and Tested her in bathroom test facility... bowthruster works nicely and motors running much better after I reconfig the Hobby King 6ch Tx with software on PC.
Took her down to the pond for a test run and she has good speed, turns well and bowthruster spins her around nicely. I will get some pix of her running next time as the Tx batteries went flat just as I wanted to get some pix!
Also will do a bollard pull test with my digital scales ($12ish fromHking!)
Cheers Bruce
Old Aug 10, 2012, 07:18 AM
Ticonderoga is offline
Find More Posts by Ticonderoga
Ticonderoga's Avatar
Australia, QLD, Mudgeeraba
Joined Feb 2010
Originally Posted by HeavyCruser9 View Post
..... motors running much better after I reconfig the Hobby King 6ch Tx with software on PC.
Cheers Bruce
Hi Bruce,
What was the software upgrade to the Hobby King all about?
Andrew
Ticonderoga is offline Find More Posts by Ticonderoga
Old Aug 10, 2012, 09:16 AM
Adelaide,Australia
Joined Dec 2009
On the cheapy HK 6ch set you can plug it on to the PC (after you download the software) to do the adjustments such as stick endpoints, Servo reversing....the same as the stuff you can adjust on the Turnigy 9X thru the menu on board.
The 6ch I needed to re calibrate the sticks as they were all over the place for the 2 throttles (example ch3 Port throttle was 65% fwd and 78% rev Stbd was 68%fwd and 82%rev) after doing the recalibration they are now all 68% each way (atleast thats what the Software says!)
Cheers Bruce
Old Aug 10, 2012, 03:49 PM
delboyandrodney is online now
Find More Posts by delboyandrodney
New Zealand, Otago, Dunedin
Joined Feb 2012
She's looking great! What are your ideas for building the rhib? I have to scratch build 2 for my hmnzs otago and I'm scratching my head for where to start
delboyandrodney is online now Find More Posts by delboyandrodney
Old Aug 10, 2012, 04:35 PM
Guard-Officer is offline
Find More Posts by Guard-Officer
Guard-Officer's Avatar
Canada, ON, Quinte West
Joined Feb 2009
I have some drawings of a Coast Guard Diesel I\O Zodiac that we use on our ships. Its almost identical to the ones the navy uses. If i can scan it, I'llpost it for you. I think the drawing is in pretty close to the scale 1:48.
Guard-Officer is offline Find More Posts by Guard-Officer
Old Aug 10, 2012, 09:31 PM
Adelaide,Australia
Joined Dec 2009
What scale are you after? I am using (when it turns up) a 1/72 fleetscale 26'Pacific RHIB on tug and a smaller Gemini. If you are doing a larger scale like 1/48 you might be able to find one as part of a diecast car and boat set (plastic boat) such as the ones by Carama (or similar) and detail it to suit.
Cheers Bruce
Old Aug 12, 2012, 03:46 AM
Adelaide,Australia
Joined Dec 2009
I squeezed a quick test sail in this afternoon, so I could do a bollard pull test with my electronic scales. After some swearing at the controller (somehow the throttles have reversed themselves from the settings programmed in last week!!! I reckon when I put fresh Batt's in the Tx it lost the settings....??) I managed to chip the aft port corner
But eventually got a reading off the scales she pulled 0.47kg(1.03lbs) in test 1, 0.89kg(1.96lbs) in test 2 and 0.49kg(1.08lbs) in test 3 I think the angle I was holding the scales influenced how well they read (they are supposed to be used vertically not horizontally...) I will try again when I have someone to drive her for me, while I hold the scales....
Here R some pix....
Cheers Bruce
Old Aug 12, 2012, 07:22 AM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
I like the entire boat. Great job, Bruce---.
der kapitan is offline Find More Posts by der kapitan
Old Aug 12, 2012, 07:49 AM
louie R/C NUT is offline
Find More Posts by louie R/C NUT
no such thing as to many boats
louie R/C NUT's Avatar
United States, NY, New York
Joined May 2010
Very well done
louie R/C NUT is offline Find More Posts by louie R/C NUT
Old Aug 12, 2012, 08:37 AM
Adelaide,Australia
Joined Dec 2009
Thanks fellas,
I hope to get her finished soon, just waiting on some resin fittings to turn up. Then I can do some exterior work on the superstructure to finish it off... then I need 2 do lights....
Old Aug 12, 2012, 12:39 PM
Joined Feb 2009
She looks great already! It really sets to the head when your under full power doesn't it. That's gonna be a sharp one when you get all your fittings on!
Cheers
G-O
Build Log A Modern Harbor Tug toesup Dock Talk 514 Sep 06, 2011 01:46 PM
Build Log Project Gatika, Modern Voith Tug yacht boy Scale Boats 198 Feb 19, 2009 04:05 PM
Help! Building a Modern Tug Mast captain at the Scale Boats 15 Dec 23, 2007 07:58 PM
Build Log Ocean/Harbor Tug Based on Fiberglass Hull off eBay not_in_houston Scale Boats 53 Nov 12, 2007 10:27 AM
