Old Jul 10, 2011, 12:56 AM
HeavyCruser9 is offline
Find More Posts by HeavyCruser9
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
Got new props for the tug in post on Friday just in time for a test run today at the pond! here are some pic's of the new 4bladed Kort props from GT Sitek.
Now I just need 2 do a new watt meter test 2 C what sort of Amp and Wattage the motors are pulling now.
Bruce
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Jul 12, 2011, 11:12 PM
Guard-Officer is offline
Find More Posts by Guard-Officer
Guard-Officer's Avatar
Canada, ON, Quinte West
Joined Feb 2009
Looks sharp!! how did it run with the new props? The usual demand... show us the pictures!
Cheers
G-O
Guard-Officer is offline Find More Posts by Guard-Officer
Old Jul 13, 2011, 08:49 PM
Adelaide,Australia
Joined Dec 2009
It ran really well mate, no one had a camera out when I had the tug in for a test DOH! I will take her back down the pond this afternoon (weather permitting) and get some running shots.
She has more power and is visibly faster with the brass props was very pleased with the performance, not happy with the cheap ESC's in her (very poor low speed control) and will replace them with a pair of Mtroniks Viper15's later. I need to get stuck in to building her decks and finish her superstructure.
Cheers Bruce
Old Jul 14, 2011, 02:48 AM
Adelaide,Australia
Joined Dec 2009
Here are some pix of the Titan having a test run today...damn hard to take decent pix and drive her at same time!
Cheers Bruce
Old Jul 14, 2011, 07:31 AM
more coffee is offline
Find More Posts by more coffee
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
Goes like stink..Her prop wash is similar to a trolling motor..
May want to make sure your tow bollards are well secured..both on the tug and what ever you tow.
more coffee is offline Find More Posts by more coffee
Old Jul 14, 2011, 05:38 PM
Adelaide,Australia
Joined Dec 2009
Ya mate! Oztruck said the same on Sunday!! 1st pay from new job next week so I shall be able 2 get some materials to finish fitting decks 2 her and order a bowthruster...
Bruce
Old Jul 15, 2011, 01:25 AM
nick_75au is online now
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Looks great Bruce,
I never saw the bottom of the boating pond when I use to sail there
Cheers
Nick
nick_75au is online now Find More Posts by nick_75au
Old Jul 15, 2011, 05:16 AM
Joined Feb 2009
Thats some wicked clear water there!, i would bet its great for the subs'
Make sure you seal that aft deck up eh! looks a mite wet...
lookin sharp!
Cheers
G-O
Old Jul 15, 2011, 08:01 PM
Adelaide,Australia
Joined Dec 2009
Nick I'm sure the ducks will rectify that situation shortly!!
G-O check out the pix of Oztrucks IJN sub and Russian Alfa at the pond in the TF72 update in docktalk!!
Cheers Bruce
Old Oct 07, 2011, 02:09 AM
Adelaide,Australia
Joined Dec 2009
Been busy with work and building USS Long Beach's new bow but finally did some work on my Tug!! Need new ESC's as I 'borrowed' one for my cabin cruiser and had it turn into a smoke unit!! A pair of Mtroniks Viper20's are on order as replacements.
Anyway took the jigsaw 2 her stern the other day and cut out the fixed stern roller, I have built up a working/turning one out of some pvc pipe scrap styrene and a brass rod for the axle. Then fixed the mounting in with glass reinforced filler.
Also began fitting deck supports for her and cutting some new 3mm ply decks for the midship section.
Next I need 2 do deck supports for stern area and work out access hatch for rudders and servo.
Cheers Bruce
Old Oct 11, 2011, 01:40 AM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
Bruce, if you can find some, get a couple of pieces of thin nylon, (like a washer almost) and put them at the ends of the roller and it will keep it from binding on the ends of the PVC. They sell sheets of teflon (really expensive) and then just cut it out of that, or just find some nylon.
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Oct 12, 2011, 02:05 AM
Adelaide,Australia
Joined Dec 2009
Its cool mate, it free spins nicely (the roller is pvc, the 'ends' on it are 1.5mm styrene CA'd on) the roller is not glued in yet until the area around it gets repainted.
Bruce
Old Nov 06, 2011, 02:52 AM
Adelaide,Australia
Joined Dec 2009
Last weekend while waiting for the paint to dry on USS Long Beach I got stuck into making up deck sections and the lower part of the superstructure on Southern Titan. The deck sections are cut from different sheets of 3mm ply and looks like a patchwork quilt!! New bit of superstructure is 2mm styrene normally I would have drawn up a plan but this time just made it up as I went...
Bruce
Old Nov 07, 2011, 01:42 PM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
looks good and patch work deck always works fine once it is painted and sealed.
keith S is offline Find More Posts by keith S
Old Nov 08, 2011, 08:33 PM
Adelaide,Australia
Joined Dec 2009
Thanks Mate!!
Yeah once its all painted you'd never know!! New Mtroniks 20amp ESC's turned up in the Post last week too, so I can work on the drive line wiring layout soon too.
Cheers Bruce
Build Log A Modern Harbor Tug toesup Dock Talk 514 Sep 06, 2011 01:46 PM
Build Log Project Gatika, Modern Voith Tug yacht boy Scale Boats 198 Feb 19, 2009 04:05 PM
Help! Building a Modern Tug Mast captain at the Scale Boats 15 Dec 23, 2007 07:58 PM
Build Log Ocean/Harbor Tug Based on Fiberglass Hull off eBay not_in_houston Scale Boats 53 Nov 12, 2007 10:27 AM
