Old Jan 28, 2010, 02:49 AM
DrFragnasty is offline
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Scratch-building a Nexor Pro
The Nexor is the product of the fertile minds of Bruce Nye, Steve Boag, Marcus Stent, Tim Lennon and occasional elbow grease from me.
The Nexor is based on Supra foils but using a different planform and different everything else.
It's flown for a year and it works well but can always be improved upon. The molds worked well, the lay-ups, templates and procedures worked well so the effort to produce a molded glider is greatly reduced. Reduced enough for me to have a go!
First-up the balsa skins are 1mm medium soft. The joiner boxes and joiners are done. The balsa shear webs are cut and the sub-spars done.
Chris Adams
DrFragnasty is offline Find More Posts by DrFragnasty
Old Jan 28, 2010, 02:52 PM
Thermal Wrangler
Launceston Tasmania
Joined Mar 2004
Poraver & MDF
The mold filler is Poraver. Cheap. Lightweight. Works. We'll use it again.
MDF is "medium density fibreboard":
http://en.wikipedia.org/wiki/Medium-density_fibreboard
Not sure if you can get the exact product in the US. It's a high-density wood product (Radiata Pine is used in Australia). Fibres are mashed-up then re-combined with resin and wax at high temps/pressure.
Chris.
Old Jan 28, 2010, 04:40 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Chris,
Watchin' with interest.
S
PS Did you give 'she who must be obeyed' the poraver bowl back?
Shedofdread is offline Find More Posts by Shedofdread
Old Jan 28, 2010, 05:32 PM
jirvin_4505 is offline
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
Mixing poraver
Hi Chris great to see the SEAT team posting on Rcgroups.
Following with interest.
My shedbuddy Shane used Poraver to make a fuz mold - awesome stuff!
He used a battery drill to drive a paint mixer and reported it was a 'piece of cake' to mix...
cheers jeff
jirvin_4505 is offline Find More Posts by jirvin_4505
Old Jan 28, 2010, 06:10 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Nice work guys.
I always use glass bowls from the kitchen rather than the metal ones. That way when the wife is looking for it I can just say that I broke it while doing the dishes .
Adam
wyowindworks is offline Find More Posts by wyowindworks
Old Jan 28, 2010, 06:46 PM
Thermal Wrangler
Launceston Tasmania
Joined Mar 2004
Tah for the mixer tip Jeff. Dunno about the bowl Shed...that was a matter for Bruce and his SWMBO. Adam; cunning solution!
Chris.
Old Jan 28, 2010, 09:31 PM
cynjon is offline
Find More Posts by cynjon
Retired USAF
cynjon's Avatar
USA, SD, Piedmont
Joined Jul 2005
You do nice work Chris...wish I had the skills/time/money/workshop to do stuff like that. Keep the build threads coming!
cynjon is offline Find More Posts by cynjon
Old Jan 28, 2010, 10:13 PM
Thermal Wrangler
Launceston Tasmania
Joined Mar 2004
I can't take much credit for the accuracy/ fidelity of the process Jon.
Bruce & Steve are both gifted in that regard. I just slop the resin in and hope for the best ;0)
Old Jan 29, 2010, 02:02 AM
Boagy is offline
Find More Posts by Boagy
mmmmm....BEER
Launceston, Tasmania
Joined Jan 2010
Hi Guys,
Just to add a bit more info to the thread, we are also working on a modular fuz design. We are only in the early stages at the moment. Tailplanes and F3B pod have been modelled up in the CAD program. F3J pod for the Nexor is next. No CNC plugs/moulds have been produced yet.
We want a fuz system that allows us more flexibility when coming up with new models/concepts and parts/moulds that are easy and quick to produce or modify. We don't want to have to make new fuz moulds every time we want to produce a different model.
It is basically a pod and boom system but with the all carbon boom extending forward of the wing seat. The pod (different for F3B/J) then goes in front. Size and wetted area has been kept to a minimum but not to the extent where structural strength is compromised. Tail groups (x-tail, plug on v-tai) will essentially be the same as the Baudis Trinity concept. A small wing seat mould will be produced to sit on the top of the boom.
New wing designs will only require a new wing seat to be produced to allow for different airfoils, wing chord etc. The wing seat and tail groups can be easily moved to adjust moments as the boom mandrel is longer than necessary.
It probably won't be as sexy as some of the commercial (or home grown) fuz's, but the ease of manufacture and flexibility of this system should make it worthwhile. The CNC machined 2-piece steel mandrel is finished and can be viewed at http://seat.org.au/
Chris can post pics when we have made further progress.
cheers
Steve
Boagy is offline Find More Posts by Boagy
Old Jan 29, 2010, 03:21 AM
dimadee is offline
Find More Posts by dimadee
Melbourne, Australia
Joined Mar 2004
subscribed
dimadee is offline Find More Posts by dimadee
Old Jan 29, 2010, 03:40 AM
Thermal Wrangler
Launceston Tasmania
Joined Mar 2004
Nexor
Apologies for the timewarp photo-sequence; here's the Nexor in it's element at Milang F3J (Sth. Australia) last yr.
Maiden flight with the glue still drying ;0)
Chris.
Old Jan 29, 2010, 07:20 PM
Larrikin is offline
Find More Posts by Larrikin
Everything's A Compromise
Larrikin's Avatar
Joined Jan 2005
Chris.
Thanks for posting all the photos. We all love photos "Maiden flight with the glue still drying " I wouldn't mind betting that it'll be the same for Evan's Sniper at Milang too.
D.
Larrikin is offline Find More Posts by Larrikin
Latest blog entry: The Rubicon
Old Jan 30, 2010, 04:41 AM
Thermal Wrangler
Launceston Tasmania
Joined Mar 2004
Tah David, hope your Sniper claims a few scalps at Milang ;0)
Chris.
Discussion Building RC Helicopter from Scratch hidavi Electric Heli Talk 19 Mar 12, 2010 07:07 PM
Discussion workshop for scratch building skyguy04 The Builders Workshop 5 Sep 21, 2009 08:43 PM
Discussion Scratch building F-18 D - Styrofoam Impy Foamies (Scratchbuilt) 2 Sep 07, 2009 08:57 PM
Discussion First scratch building project Impy Foamy EDFs 3 Sep 04, 2009 09:56 AM
Discussion Scratch building with the wild hawk daveyedgar Beginner Training Area (Aircraft-Electric) 0 Aug 30, 2009 10:03 PM
