Old May 17, 2003, 08:41 AM
Lusha is offline
Find More Posts by Lusha
Field Marshal
Lusha's Avatar
Jakobstad,Finland
Joined Apr 2002
Ampdraw in Eolo?
Has anybody measured the static ampdraw for the stock Eolo with 8 cells? I have a Kontronik sun 4000 ESC I intend to use on mine. This one can handle 35A cont./6-16V, so I think it will be enough.
Lusha is offline Find More Posts by Lusha
Old May 18, 2003, 01:45 AM
RJ is offline
RJ
Find More Posts by RJ
RJ
RJ's Avatar
San Francisco Peninsula, CA
Joined Jan 2001
I measured 15-16 Amps, 136Watts to hover 1300g flying weight with Astro 020 4T brushless, moderate headspeed. I did not measure maximum Amp draw.
It is my understanding that it is not the maximum current that was causing some problems, but exceeding the maximum current for the BEC causing the ESC to shut down (anyone confirm?). You may want to check the maximum current allowed if your ESC has BEC. 3 Amp BEC is good.
RJ is offline Find More Posts by RJ
Old May 18, 2003, 02:50 AM
Lusha is offline
Field Marshal
Lusha's Avatar
Jakobstad,Finland
Joined Apr 2002
Ok. The ESC I have has the shutdow function disabled. 3 servos is no problem, 4 might work also. Figured it would be good in the heli since it doesn't shut off at all.
Old Jun 15, 2003, 11:04 AM
Lusha is offline
Field Marshal
Lusha's Avatar
Jakobstad,Finland
Joined Apr 2002
Soo, I finally got to do some testing on the Eolo. With a Kontronik Twist-33 / Smile 40-6-12/8x1700scr the static Amp draw was: 75% governor, 4 deg. pitch=13,5 A, 14 deg. pitch=26,5A. Could not measure hovering draw cause I used a clamp meter. The result in non governor mode was 27A at max pitch...hope this is of use for somebody!
Old Jun 15, 2003, 12:28 PM
Arp is offline
Arp
Find More Posts by Arp
Arp
Arp's Avatar
On ground
Joined Feb 2003
Of remarkable use. Thanks for measuring.
I finally know my LiPo pack is safe.
Arp is offline Find More Posts by Arp
Old Jun 15, 2003, 09:33 PM
Hifly is offline
Find More Posts by Hifly
NJ
Joined Jan 2002
Lusha
Great info .. how much flying you got from those packs?
Hifly is offline Find More Posts by Hifly
Old Jun 16, 2003, 08:53 AM
Mckoi is offline
Find More Posts by Mckoi
rchover
Mckoi's Avatar
Foxboro , MA
Joined Jan 2003
I measured 20-30 amps on 10 cells with the twist 3700 in a hover
hope that helps
Jeremy
www.rchover.com
Mckoi is offline Find More Posts by Mckoi
Axi 2820-10 in Eolo? new2heli Electric Heli Talk 1 Jan 12, 2004 11:59 AM
What motors in Eolo everyone? EP heli freak! Electric Heli Talk 5 Nov 12, 2003 12:24 PM
Shulze 32.40k in eolo EP heli freak! Electric Heli Talk 2 Oct 26, 2003 07:30 AM
Estim. AmpDraw in Eolo? Lusha Electric Heli Talk 6 May 22, 2003 10:33 AM
What servos in a EOLO? and MOtor? peterg Electric Heli Talk 6 May 17, 2003 08:09 AM
