Old Jan 27, 2010, 04:37 PM
meonflyer is offline
Find More Posts by meonflyer
Joined Jan 2010
Help - Propeak Sigma 2 EQ & NIMH Batteries
Hope someone can help. Just got a Sigma 2 EQ Charger to charge up my NIMH batteries that i use for my gliders. Have just received my new charger and want to test it. All of my batteries are 4.8v NIMH batteries with standard 3 pin (red, black, spare) male connectors, but not quite sure which port i connect the battery into or even if i need an additional lead. There are 5 ports in the chargers RH side marked 2 thro to 6 cells and a balancer board which looks like it must be for LIPOs. My batterys all have 3 connector male leads on but the only port on the right hand side with 3 pins is makred as 2 cells, im a tad confused. Can anybody advise as the last thing i want to do is knacker the charger of batteries.
meonflyer is offline Find More Posts by meonflyer
Old Jan 27, 2010, 07:30 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
You do not charge Ni packs by connecting to a chargers balancing ports. You use the main power output leads.
LiPoly are charged CC / CV and balanced Ni are peak charged.
Charles
Old Jan 29, 2010, 01:21 PM
Joined Jan 2010
Thanks Charles, finally sussed out the lead that came with the charger was for lipos, purchased some additional leads and now it all makes sense!!
Discussion Sigma II pro peak eq help ak79 Batteries and Chargers 4 Mar 04, 2010 06:03 AM
Discussion Sigma EQ Charger MALCOLM1943 Batteries and Chargers 2 Jan 22, 2010 03:59 PM
Discussion Having problems with NiMH C batteries. Help please Oreo Batteries and Chargers 6 Jan 13, 2010 03:24 PM
Yippee! Sigma eq charger fault and fix gloworm Batteries and Chargers 1 Jan 10, 2010 01:26 PM
Discussion propeak sigma memory card/temp sensor jantrit Batteries and Chargers 2 Oct 15, 2007 03:36 PM
