Old Jan 27, 2010, 04:08 PM
Joined Oct 2005
How do you DUll glossy Iron-on finish?
Hello ...... is there a etching fluid or some other substance that will dull the glossy finish of modern iron-films? Thanks!
Rocketman
Rocketman320 is offline Find More Posts by Rocketman320
Old Jan 28, 2010, 05:29 AM
Hamburger Eatin' Fool
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Try using 0000 steel wool and elbow grease.
TomCrump is offline Find More Posts by TomCrump
Old Jan 28, 2010, 10:03 PM
San Diego, Ca
Joined Oct 2007
You can also use "dull Coat" a flat laquor from testers. It looks best on darker colors. Looks GREAT on grey. very light colors show a tiny bit of splotching.
Steel wool works but oh boy the work
LAdams is offline Find More Posts by LAdams
Old Jan 29, 2010, 07:22 AM
Joined Oct 2005
Thanks for the info!
Old Jan 30, 2010, 02:03 PM
Queen of the air
Kimber's Avatar
USA
Joined Mar 2005
Don't you need to steel wool it before you spray on the dull coat?
Kimber is online now Find More Posts by Kimber
Old Jan 31, 2010, 04:40 AM
TomCrump's Avatar
Joined Dec 2005
Yup; For good adhesion, steel wool should be used. But by then, the covering is already dulled, so there is little need for the dull coat.
Old Jan 31, 2010, 10:09 AM
San Diego, Ca
Joined Oct 2007
I use the dullcote bare on the covering myself. It will scratch off if you try to or if you put tape on it and peel the tape off but otherwise is pretty durable. (unless this is a fuel plane then I don;t think I would use it at all...)
Steel wooling the covering gives it a nice satiny finsh which looks good if you are trying to make it look like silk or something but doesnt't completely dull it. Dullcote on grey ultracote for example gives a completely flat military finish.
So it sort of depends on exactly the look you want. Buy a can and then test on your exact covering material and see what it looks like. Different manufacturers and different colors have slightly different results too...
Discussion How to dull iron-on glossy finsih? Rocketman320 Free Flight 4 Jan 26, 2010 04:50 PM
Kudos Bless you Jim, how do you do it? arbilab Site Suggestions / Complaints 2 Jan 09, 2010 02:43 PM
Discussion Glossy finish on Hangar-9 birds?!?! Cured! woody429924 Fuel Warbirds 19 Aug 19, 2007 07:35 PM
How do you make the decals less glossy? TMO GWS (Grand Wing Servo) 3 Jun 23, 2004 10:11 AM
how do you make Krylon glossy p471701 Electric Plane Talk 6 Oct 06, 2001 06:22 PM
