Old Jan 27, 2010, 10:03 AM
soarluck is offline
Find More Posts by soarluck
soarluck's Avatar
Canada .the great
question concerning shielding of rf signal in dlg pods
I have been putting together pods for dlg and I havent yet concerned myself much with 2.4 mhz but I got wondering if I should be more concerned about where I place my Carbon in my fuses.
Im curious to know what you guys think about the carbon that I have down the side of my kevlar pods in respect to 2.4mhz
Do you think the CF in my pod will be a concern
thanks
SL
soarluck is offline Find More Posts by soarluck
Old Jan 27, 2010, 11:04 AM
cptsnoopy is offline
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Just my un-educated opinion. Yes, I think it will make a difference compared to having no carbon but I also believe this is a time for trial and error. If the owner decides to try and have the antenna within the pod then that person might want to do extensive range testing before committing it to the sky. If they don't mind doing the "whisker" thing, then it probably is better off than a full carbon pod but it should have zero issues. Don't know if that helps at all...
Charlie
cptsnoopy is offline Find More Posts by cptsnoopy
Old Jan 27, 2010, 11:15 AM
soarluck is offline
soarluck's Avatar
Canada .the great
Thks Charlie It does help because I know very little about the different installations.
Im thinking I might be best to cut the carbon another 2 inches shorter .
Thanks again..hopefully others will reply and help me form a opinion as well
thks
SL
Old Jan 27, 2010, 04:05 PM
Thermaln2 is offline
Find More Posts by Thermaln2
Transplant Chey WY from Reno
Thermaln2's Avatar
Reno Nevada
Joined Oct 2007
SL,
Looking at the pod, I am not sure you really need the CF there. Pod looks solid. I have built kevlar pods and have not seen a need.
If you need to add strength, why not just use some Kevlar Uni? Ping me if you want a sample. I get some as scrap.
Chris
Thermaln2 is offline Find More Posts by Thermaln2
Old Jan 27, 2010, 05:39 PM
soarluck is offline
soarluck's Avatar
Canada .the great
Originally Posted by Thermaln2 View Post
SL,
Chris
Kevlar uni?? oh my!! yet another material I need to try lolol
I agree .I dont think I need the carbon either ..
My lay-up is two layers of 1.7 kevlar 1 layer .075 glass and doubler toward the rear and up the pylon .
As you would assume the boom cements in the rear so Im likely good to go.
the kevlar pod is 18.5 -19 grams so I may drop the weight even more yet ..I was surprised to see my weights that low ..iM very happy with my results
THANK YOU to many of you fine folks for your help ..
Thanks Chris for your offer on the uni ...I may have to let that slide for now because Im swamped with ideas but I would appreciate a link if you have one
SL
Old Jan 27, 2010, 05:50 PM
bbbp is offline
Find More Posts by bbbp
a.k.a. Bob Parks
United States, AZ, Glendale
Joined Jun 2008
Carbon in Pod
Your kevlar pod looks similar to the Lighthawk pod as far as carbon placement. The LH carbon is not as wide. I use an AR500 in my LH and keep its antenna looped around inside the pod, no issues at all, it will range check to over 300 ft in any position, and I've had it as far away as I would ever want to fly it without problems.
Bob P
bbbp is offline Find More Posts by bbbp
Old Jan 27, 2010, 06:29 PM
soarluck is offline
soarluck's Avatar
Canada .the great
thank you Bob ..I noticed the light hawk also
Time to experiment I guess although I may just build one without the cf and see how it feels ..Im thinking the larger dia has bought me some strength ...I wanted to be able to use a d60 dymond servo standing uprite for the rudder OR all four servos in the pod..The pod is short and pretty roomy for more selection in relation to li-po`s also ..I think Im close to hitting my mark ..thks again
SL
Old Jan 27, 2010, 06:30 PM
Sweet-ole-Bob is offline
Find More Posts by Sweet-ole-Bob
Chandler, Az.
Joined Mar 2008
R-F shielding
S-L:
whether you need the cf or not is something you can figure out for yourself, but to answer your question (is the carbon a concern for a 2.4Ghz installation?), any conductor in the R-F path is a concern, but we have been dealing with that for years. In the "old days" we had a 30 inch antenna hanging out and didn't think much about it, now we have 2.5 cm antennas, and can't figure out what to do with them-I strongly suggest that you lead them to clear air as soon as possible.
The best way to tell if you installation works is to range test.
Bob
Sweet-ole-Bob is offline Find More Posts by Sweet-ole-Bob
Old Jan 27, 2010, 06:50 PM
David Forbes is offline
Find More Posts by David Forbes
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
See if you can find some S-glass. I've replaced the carbon in my pods with S-glass and it seems to be reasonably equivalent (or at least good enough for who it's for).
I'm in the process of making the jump to 2.4 in the few planes I can afford receivers for.
Dave
David Forbes is offline Find More Posts by David Forbes
Old Jan 27, 2010, 06:53 PM
soarluck is offline
soarluck's Avatar
Canada .the great
Originally Posted by Sweet-ole-Bob View Post
S-L:
Bob
thks BOB ..I dont have a 2.4 so I cant range test but I think im best to do away with the carbon
thks again
SL
Old Jan 27, 2010, 07:06 PM
soarluck is offline
soarluck's Avatar
Canada .the great
Dave
I may make a few pod completely out of glass ..Any lay-up suggestions .S glass would be nice although might not drape to well ..Its in the 5 oz range ..thanks Dave ..I dont really need to go to 2.4 and love my evo but its being forced on us with the low stock in fm rx these days ..bummer
I just dont care to sell guys pods with false assumptions on my part
thks guys
SL
Old Jan 27, 2010, 08:09 PM
Buddy Roos is offline
Find More Posts by Buddy Roos
It's a mere flesh wound!
Buddy Roos's Avatar
Woodstock,Ga.
Joined Jun 2004
You could check with Will Newton. He makes the 2.4 pods for Oleg's TabooGT and they are all fiberglass.
Buddy
Buddy Roos is offline Find More Posts by Buddy Roos
Old Jan 28, 2010, 09:28 AM
wzg_zxl is offline
Find More Posts by wzg_zxl
wzg_zxl's Avatar
Beijing
Joined Sep 2007
Hi,soarluck
moved by what you've done!I think kevlar with uni-carbon is a good chioce,and friendly to 2.4G radio.uni-carbon maybe should be from top to the end of the pod.
wzg_zxl is offline Find More Posts by wzg_zxl
Old Jan 28, 2010, 10:31 AM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
Kevlar uni would not be a good materials choice. It will have poor compression strength. Fine in tension though..
Gerald
G_T is offline Find More Posts by G_T
Old Jan 28, 2010, 11:49 AM
mpodder is offline
Find More Posts by mpodder
Maurice
mpodder's Avatar
Bakersfield, Cal.
Joined Jul 2004
I have an Aspirin (carbon only pod) and a Predator II (carbon/kevlar pod) both on Futaba FASST 2.4, both with the antennas inside the pod and both with the antennas parallel not at 90 deg. I get a 60 pace range check on both (30 to 50 pace spec) and have had no problems flying with other peps or as far away as these old eyes can see. I'm using a 12Z trans and the older R606 recievers. They are realy cheap when you can find them because they had compatibility problems with some trans. I will be using a R617 in my next plane because there is no more R606s on ebay :-)
Just what works for me
Maurice
mpodder is offline Find More Posts by mpodder
Discussion RF Shielding vs. Separation chickenblender FPV Talk 47 Feb 04, 2009 05:39 PM
Discussion Potential RF interference - Shielding? Red-Rx7 FPV Talk 2 Jan 19, 2009 12:33 PM
Discussion rf shielding spray dalbert02 UAV - Unmanned Aerial Vehicles 22 Sep 14, 2007 09:21 PM
Discussion RF shielding for Electric Senior Telemaster + UNAV2R + CPD4 Brio3 UAV - Unmanned Aerial Vehicles 26 Mar 28, 2007 08:05 AM
