Old Jan 27, 2010, 08:07 AM
peconic steam is offline
Find More Posts by peconic steam
peconic steam's Avatar
Long Island, NY
Joined Dec 2007
Idea
Midwest fantail launch + Kitchen rudder
-Not too sure where to post this, anyway- Thought I would try to build a Kitchen rudder, and since this fantail kit has been collecting dust for too long... I don't have much of an idea where this is going other than to see how a system like this might handle.
peconic steam is offline Find More Posts by peconic steam
Old Jan 27, 2010, 10:38 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Wow, you are quite an ingenious person. That looks great.
Kmot is offline Find More Posts by Kmot
Old Jan 27, 2010, 11:46 AM
Long Island, NY
Joined Dec 2007
! I think it's more like a lot of time on my hands this time of the year...
Old Jan 27, 2010, 12:51 PM
Subdave is offline
Find More Posts by Subdave
Semi-Official Tinkerer
Subdave's Avatar
Rochester NY
Joined Mar 2005
I like it!!
Will you have a bottom pivot point? Dave.
Subdave is offline Find More Posts by Subdave
Old Jan 27, 2010, 02:22 PM
Long Island, NY
Joined Dec 2007
Yes, the bottom points are secured to an extension at the keel
Old Jan 27, 2010, 03:09 PM
jda is offline
jda
Find More Posts by jda
jda
Fossil builder
Tennessee
Joined Apr 2006
The L shaped pieces and the round head screw, are they the bottom pieces for the keel attachment? I think the Kitchen rudder may be the answer to all single cylinder steam engines.... Am hopeful this works out well for you. Once tried rolling some brass sheets to make one of these rudders. No luck. I like your idea!
jda is offline Find More Posts by jda
Old Jan 27, 2010, 08:08 PM
steamboatmodel is offline
Find More Posts by steamboatmodel
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
For those who aren't too sure on how they work. I will try to take some shots of mine tomorrow.
Regards,
Gerald.
PS Should we have this thread in the Steam section?
steamboatmodel is offline Find More Posts by steamboatmodel
Old Jan 27, 2010, 08:10 PM
Long Island, NY
Joined Dec 2007
jd, I tried the roll method too and went the rigid tubing route as the end result was a much sturdier pair of rudder halves. I'm thinking electric power on this one as I want to see how some moderate prop wash affects the system.
Old Jan 27, 2010, 10:49 PM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
Had never heard of a kitchen rudder before, interesting idea for controlling a boat without throttle control (i.e. steam). Did a quick search and found this article in Wikipedia (or course) http://en.wikipedia.org/wiki/Kitchen_rudder
Now for a question or two; one channel for the swing of the rudder itself? second channel to run the clam shells? and how do you know what position the shells are in? lastly, how do you activate the clam shells, the pics do not really show the top (inside the transom of the boat) of the rudder and it mechanism?
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Jan 28, 2010, 06:12 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Here's a good explanation of the linkage:
http://www.boatdesign.net/gallery/sh...what/allfields
Search this site, you get about 3 pages of hits on Kitchen Rudder, including this image I took at Cabin Fever of a rolled set:
patmat2350 is offline Find More Posts by patmat2350
Old Jan 28, 2010, 07:11 AM
Long Island, NY
Joined Dec 2007
Foo, you've got it right concerning the servo action. The push / pull, or clam shells opening and closing are controlled by a servo which in turn will swing as a tiller so we have left and right rudder when the 2 halves are in the open or ahead position. Like a normal rudder, you won't actually see what it's doing, but see how it affects the maneuvering.
Old Jan 28, 2010, 01:21 PM
Toronto, Canada
Joined Nov 2004
Here are some shots of the top end that I found on the Internet.
The last four are the one I am working slowly on.
Regards,
Gerald.
Old Jan 28, 2010, 03:20 PM
jda is offline
jda
jda
Fossil builder
Tennessee
Joined Apr 2006
Peconic Steam, My thought when I tried this, was that the prop shaft/prop should be at a right angle to the clam shell. More like a Kort nozzle. Is this just a matter of effeciency?
jda
Old Jan 28, 2010, 05:47 PM
Long Island, NY
Joined Dec 2007
jda, Actually I can't tell you as I know very little about these rudders in real applications. I just saw one in a magazine and became interested enough to make one. So far everything looks like it should work on the one I'm building; will know for sure in about a week. pics. to follow-
Old Jan 28, 2010, 05:54 PM
Toronto, Canada
Joined Nov 2004
Ideally the prop shaft/prop should be at a right angle to the clam shell. More like a Kort nozzle, but with the Midwest Fantail Launch you are stuck with the original angle unless you want to do a lot of redesign. With mine the basic Hull was already assembled and I had to finish the fiberglass (actually strip off what was there and redo it). The angle on the Elliott Bay is better. It should also be inside the clams when they are fully open with the prop filling the opening like a Korts nozzle.
Regards,
Gerald.
Sold Midwest Fantail Launch captainfh Boats (FS/W) 3 Mar 01, 2009 07:39 PM
Discussion Midwest Fantail Launch photos and question ohm116 Scale Boats 15 Sep 16, 2008 04:51 AM
Question about Midwest Fantail Launch orenda635 Dock Talk 2 Oct 23, 2005 04:41 AM
ARR fantail launch ebay vett Boats (FS/W) 2 Sep 28, 2004 08:31 PM
Fantail Launch II and Steam Engine rpm3 Boats (FS/W) 0 Aug 03, 2004 10:08 PM
