Old Jan 27, 2010, 07:25 AM
Gadflyii is offline
Find More Posts by Gadflyii
Joined Jan 2010
Help with mCX? Servo's sticking (Horizon Hobby Support is Terrible)
My daughter's 2 week old mCX is not working right. Both the servos stick.
Her mCX has never been right, since day one it was touchy about binding, and now completely out of the blue, her servos are sticking. they will move to the end of travel in one direction then just stop. and not move again.
I contacted Horizon hobby support and they are no help at all, perhaps someone here can help me figure out a solution?
Gadflyii is offline Find More Posts by Gadflyii
Old Jan 27, 2010, 07:55 AM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
See if the gears on the servos have become nicked from crashes. Rotate each of them with your fingertip, they should turn easy all the way around. If there are ANY slightly sticky or slow spots in the gears, they will jam. Also, the mCX canopy has a tendency to drag on the servo gear if it's deformed.
Binding should only need to occur once. After that, the start procedure is always the same:
Turn on the Tx, wait 10 seconds, plug in the heli, leave it flat and still for 6 seconds till the light comes on, then FLY!
hydro_pyro is offline Find More Posts by hydro_pyro
Old Jan 27, 2010, 08:07 AM
Gadflyii is offline
Joined Jan 2010
All the gears are fine, with the power off you can freely rotate both servos with no sticking or resistance, and the servos stick with or without the canopy.
I have removed the servos from the board and cleaned the contacts with contact cleaner, blow all the dust out of the servos, checked the gears, checked the motors (which are fine), lubed the worm rod and slider, and put it all back together. It work ok for about 5 min, then the servos stuck again.
You should only have to bind once, but not on hers. It needs to be rebound almost every few battery changes. You turn the transmitter on and then plug in the battery and then light will just flash on the heli, so we have to repeat the process a few times. and it might finally link up, but most of the time we have to put the transmitter back into bind mode, and attempt to rebind, which normally takes 4-6 attempts before it will rebind. (We have the same behavior on both the RTF transmissiters we have, my frieds DX6i, and my DX7.)
She will get a few batteries though it, and then it will loose it's binding again.
Old Jan 27, 2010, 08:27 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
So you paid top dollar so would you get the great HH service and you are not getting it?? Call them again.. As sounds like you have a bad board.. And they should send you a new one..
livonia bob is offline Find More Posts by livonia bob
Old Jan 27, 2010, 10:51 AM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
I've been waiting for a few weeks on my warranty replacement board. They don't have any. So I bought one from an Ebay seller while I grow gray hairs waiting for my new one.
Old Jan 27, 2010, 11:14 AM
dimastep is offline
Find More Posts by dimastep
Joined Jul 2009
I was not very impressed with HH support on the phone. The person was not supportive and played the "item is not defective" card.
Then I emailed the support and told them in the email exactly the same thing as on the phone and without questions they shipped me a replacement 5-in-1.
So try emailing them and describe exactly what happens and what you have done to try and resolve the issue. You may be surprised!
dimastep is offline Find More Posts by dimastep
Old Jan 27, 2010, 11:30 AM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
I sent Horizon a two-page e-mail with my contact info, regarding a half-dozen different specific design and defect-related issues, complete with fixes, and all I got was an automatic "form" reply.
I tried calling first, and the guy basically told me "we're not going to change or improve them".
In other words, as long as they're making money, and the Chinese factory is building them fast enough, it's all good...
Old Jan 27, 2010, 04:24 PM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
THREE different transmitters lose binding? Bad receiver, which can also drive servos all the way one way (I've got one like that).
Explain it to them that way. Horizon may not always be perfect but they're known for the most responsive support in the business, once they understand the situation.
arbilab is offline Find More Posts by arbilab
Old Jan 27, 2010, 08:15 PM
Gadflyii is offline
Joined Jan 2010
I explained it, they want me to send the 5-in-1 in.
How long you think it will take them to replace it?
Old Jan 27, 2010, 09:46 PM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
...How long you think it will take them to replace it?
Maybe they'll have some for your mCX...
Old Jan 27, 2010, 10:09 PM
Gadflyii is offline
Joined Jan 2010
hmm.... well that sucks
Let me know if you get yours in!
Old Jan 27, 2010, 10:16 PM
arbilab is offline
Fly Runaway Fans
Joined Jan 2009
Bad time of year for Chinese parts. They officially shutdown for a month (April?) and you can't get much out of them for 2 months before or 1 month after that.
Dunno how long you have to wait. But they WILL fix it, and it's not working the way it is, so might as well send it in.
Old Jan 27, 2010, 10:40 PM
Heli collector
Joined Apr 2009
It starts on February 14th this year and only lasts 15 days to a month..
Old Jan 27, 2010, 11:22 PM
Ronon is offline
Find More Posts by Ronon
Joined Jan 2009
The Year of the Tiger. Great. This explains where my yet to be purchased UFO #8 is.
Ronon is offline Find More Posts by Ronon
Old Jan 27, 2010, 11:36 PM
arbilab is offline
Fly Runaway Fans
Joined Jan 2009
I dunno when it started/ended last year, but stuff I ordered in late Feb didn't get delivered until April.
Discussion new DX5e, servo's sticking? RafiS Radios 7 Jan 21, 2010 09:49 AM
Rave Horizon Hobby Customer Support!!!!! skyline223 Radios 3 Dec 25, 2009 08:36 PM
Discussion Horizon Hobby Support nyflyer1 Vendor Talk 1 Nov 11, 2009 11:21 AM
Discussion MCX on sale at Hobby Lobby, $20 off with full support arbilab Coaxial Helicopters 3 Jul 31, 2009 11:53 PM
Discussion mcx with sticking servo's? igotit Micro Helis 3 Jul 12, 2009 04:33 AM
